Like Tree39Likes
Old 11-11-2015, 10:24 PM   #9286
HSV427's Avatar
Trader Rating: 21 (96%+)
BOZ I'm surprised you struggled with space for the electronics, with my motor in the rear position i had more space than my 15.
Serpent 977 35th anniversary. Serpent 977 evo2, Shepherd Velox, Motonica p81rs2, OS speed shimo edition.
HSV427 is offline   Reply With Quote
Old 11-11-2015, 10:43 PM   #9287
Boz
Trader Rating: 23 (100%+)
It's probable more the esc side. It hard to layout neatly when the capacitor doesn't stretch to far.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 11-11-2015, 10:50 PM   #9288
Nat Maniac's Avatar
Originally Posted by HSV427 View Post
Wondering if any one else has the same problem, i set my car up with the motor in the rear position but the nut and screw that holds the side pod to the chassis just behind the motor is stoping me from fitting my motor, the only way i can get my motor in is not to run that screw which means that the side pod will only be held by 2 screws the one at the front and the one at the rear, any ideas would be greatly appreciated.
You raise a pretty good point Looking at Bozs picture it looks pretty tight and I assume that's in the front position
Be interested to hear other people's experience.
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 11-11-2015, 10:59 PM   #9289
BentKa's Avatar
When running the motor in the rear position the nut will interfere with the motor.
As the rearward position is meant for really loose low grip conditions you can run it without the screw/nut without issues
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 11-11-2015, 11:03 PM   #9290
BentKa's Avatar
Originally Posted by Boz View Post
I mounted the radio gear last night. Unfortunately, it's like installing radio gear into a Durango. but it's not quite as hard as a Durango.
I got their in the end and I'm happy with it now.
Time to hit the track. I'm excited.
It would help greatly if you rotate the ESC 90* to the right, run smaller wires and run them through the lower front brace for the battery and esc.
We're running full size servo, 2 x capacitor banks and extra fan for the 4.5T motor with space to spare. The '15 and '16 have a lot more space for electronics than the '13 and '14 had
Bent
Old 11-11-2015, 11:10 PM   #9291
Boz
Yeah, I noticed it too.
Why put 2 holes in for the battery position and not motor position. ops.
I hope they do a rolling update on the chassis one day. I think we can manage to drill a 3mm hole in the side guard.
Chris Bozich
Xray XB8 XB4 XB2
Old 11-11-2015, 11:30 PM   #9292
BentKa's Avatar
Originally Posted by freakshow__ View Post
Is it normal for the 2016 xb4 to be very loud when you use it? I had a 2014 one and it was pretty quiet when i raced it.
I was curious if the newer steel ring/pinion gears are what makes it so loud...or do i need to look at things closer? My gear mesh is perfect. It just sounds really loud compared to all the other cars at the track.
Anyone?
Originally Posted by likea45 View Post
discountrcstore.com
It is louder than the composite gears. It sounds just like my 15 with the same gears in it. As long as nothing is grinding it should be normal. Make sure that slipper is set exactly to the manual or it can kill the gears if you're running it.
As likea45 says the steel gears are louder than the composite gears that were standard in the '13 and '14.
The '16 should however be comparable to the '15 in terms of how it sounds.
Just remember to grease the gears and make sure gear mesh is okay for the pinion/spur.
I've also witnessed some managing to not have the bearings for the spur entirely seated causing the spur to not track straight
Bent
Old 11-11-2015, 11:37 PM   #9293
BentKa's Avatar
As mentioned the rear motor position is only used for really loose and blown out tracks and then you run it without the 4th screw (front, ESC tray and back).so not really an issue.
If you really want to run that last screw either drill a new 3mm hole (takes 30 seconds including countersinking it) or use a low profile nut instead of the standard one (or just Dremel it down).
Bent
Old 11-12-2015, 12:23 AM   #9294
Boz
Bent
Cheers.
I finally found the pictures of Bruno's car (body off) again. Turning around the ESC by 90* didn't work for me last night as one of motor wires were hitting the motor mount. I did notice that Bruno positions his ESC towards the outer of the chassis where I had mine closer to the centre line of the chassis. I think when I tried it, the steering bellcrank was hitting the wires coming out of the ESC and that's why I didn't like it facing that way.
I'll has look at it again.
I have never been a fan of running the battery wires via the brace. Having to unsoldering a brand new ESC just sounds like a silly thing to do. I'm always worried about blowing it up before I use it.
Chris Bozich
Xray XB8 XB4 XB2
Old 11-12-2015, 01:17 AM   #9295
HSV427's Avatar
Bent
As you can see in my photo I'm running my wires under the front brace but with the motor in rear position it comes up 5mm short so the wires keep piping out, i was wondering if you (bentka) could give me a suggestion what to do cause at the moment if they pop out they will go straight into my spur gear which will eventually lead to a DNF or even worse a short circuit. Thanks in advance.
Old 11-12-2015, 06:42 AM   #9296
John.C's Avatar
Trader Rating: 36 (100%+)
The part # for the medium side pods (XRA361265) was readily available. Does anyone have the part # for the medium chassis brace/s?
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 11-12-2015, 06:50 AM   #9297
For those that are running 13.5 class with your XB4, what are you running for gearing? I've searched, and seen most are dropping their spur gears down a few teeth. Is this 100% necessary? Can you reach good gearing & speed with the stock spur? If it matters, I have a 2014 xb4. And have a speed passion 13.5 motor I'm throwing in to try the class out.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 11-12-2015, 07:02 AM   #9298
jmcelroy42's Avatar
I don't run 13.5 in wheeler but I run 17.5 in 2wd buggy and usually you can get the same or nearly the same gear ratios with the larger spur, but going to the smaller one will change motor position. so you could get the motor a little closer to the center of the chassis with the smaller spur, since balance and weight is more critical with 17.5 & 13.5 classes.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 11-12-2015, 08:50 AM   #9299
BentKa's Avatar
Composite chassis brace Front - Medium #361294
Composite chassis brace Rear - Medium #361295
Should be in stock with distributors/dealers that ordered when they first became available
Bent
Old 11-12-2015, 08:55 AM   #9300
BentKa's Avatar
You don't want to swap out for thinner and more flexible wires ?
We use thinner and more flexible 13ga ORCA wire (TQ Racing also have this) and direct the wires straight out from the esc instead of straight up.
The thinner and more flexible wire also don't have any pull to them so they stay in place.
Bent
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Mikeyme84
