Like Tree36Likes
Old 11-08-2015, 09:55 AM   #9211
seth556's Avatar
Trader Rating: 42 (100%+)
Thanks Bent! Maybe we can get some of this info put on the first post or a PetitRC page.
seth556 is offline   Reply With Quote
Old 11-08-2015, 09:59 AM   #9212
Gertsch's Avatar
Originally Posted by BentKa View Post
Took the time out of my day to measure the different track widths using the new Xray 12mm hex wheels with the Xray 12mm wheel hexes. Bent
Awesome, thanks a lot Bent, much appreciated your help!
#runmod
Gertsch is offline   Reply With Quote
Old 11-08-2015, 12:02 PM   #9213
Decided to take the time to measure (almost) every combination of Xray 12mm wheels and hexes………….you're welcome !
Bent
Top man!
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 11-08-2015, 02:34 PM   #9214
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
For the servo saver, there's no way I can get the 3-4 mm clearance. Most is around 2mm
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 11-08-2015, 02:37 PM   #9215
teeforb's Avatar
Sorry. Was looking at in lol
Old 11-08-2015, 03:07 PM   #9216
teeforb's Avatar
On this sucks. One of the turnbuckle won't screw on to the rod. I'm pushing and screwing at the same time. I tried both directions and it won't catch all the other turn buckles scewed on fine. It's the actual rod that's the issue. No ends will screw on it. But those same ends will screw on the other rods
Old 11-08-2015, 05:21 PM   #9217
bd581's Avatar
1st time assembling the servo saver, as above, was near impossible to get it to 4mm. Required a clamp on the nut to get it there.
Next day after realising I buggered up something (that's what I get for staying up too late building!) had to pull the front end apart and on reassembly the servo saver was easy to get the required setup.
Maybe, just maybe, the spring needs to be compressed before assembly like some slipper clutch springs?
Other than that, can't wait to give mine a run, typically xray quality.
Going to be a shame to get it dirty - yes dirt, remember racing on that? Lol
Brad
Xray T4 '16, Xray X1, Tamiya M05 Ver.II Pro.
X-ray XB4 '16, TLR 22 3.0, TLR/Exotek 22T 2.0, Mugen MBX7R Eco.
bd581 is offline   Reply With Quote
Old 11-09-2015, 05:27 AM   #9218
John.C's Avatar
Trader Rating: 36 (100%+)
Bent
Your effort is greatly appreciated. Thank you very much!
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 11-09-2015, 06:41 AM   #9219
teeforb's Avatar
looks like I can't complete the kit without this turnbuckle rod now I have to order it and wait til it come. This blows!
Old 11-09-2015, 07:01 AM   #9220
BentKa's Avatar
Is the turnbuckle not threaded ?
The short end is the normal right handed (clock wise) side.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 11-09-2015, 08:51 AM   #9221
teeforb's Avatar
Bent
it is threaded, but i've tried various ball cup ends and none of them catch. however, those same ball cup ends catch on the other tie rod ends. For sure there's a defect someway, somehow on this one particular rod end. I've put together over 40 kits new. So i'm no rookie at this (just clarifying).
Old 11-09-2015, 09:56 AM   #9222
BentKa's Avatar
So if you pre-thread a rod end using a 3mm screw you can not get the turnbuckle to enter that rod end at all (short end being the right hand thread) ?
Have you tried a 3mm nut to see if one end is indeed a normal right hand thread ?
You have a picture of the turnbuckle ?
If it's indeed threaded is should at least have either right hand or left hand threads…..ideally one of each though
Bent
Old 11-09-2015, 11:59 AM   #9223
teeforb's Avatar
Bent
Yes i tried an m3 nut. It doesn't work but the m3 nut will work on other rod ends that does not have this problem
Old 11-09-2015, 12:09 PM   #9224
BentKa's Avatar
So does it have left hand threads on both sides then ?
Do you have a picture of it to show the threads ?
Bent
Old 11-09-2015, 12:11 PM   #9225
so look.. I don't normally suggest this but if it keeps you from waiting on a replacement then so be it.
if the threads the rest of the way up look fine, then get the dremel out and cut a mm or two off the end.... purely speculation but maybe the threads aren't finished on the end??? that way if you cut it bit you can still race and won't be caught a week out without a replacement.
Also, like Bent said, we need some pictures :-)
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
