Like Tree39Likes
Old 11-07-2015, 12:06 PM   #9196
Trader Rating: 30 (100%+)
Originally Posted by teeforb View Post
I see the gears for the diff are plastic? Do they hold up ok? Do they wear?
Suby is right on point, as the composite diff gears are very durable. Even better the 16 XB4 Kit comes standard with the upgraded graphite 4 + 2 diff gears.
Super smooth, super quiet and very very durable.
I ran the upgraded graphite 4 + 2 diff gears f/r/c in my 15 and they worked flawlessly. Ninja silent, super smooth. Nice to know there standard for the 16 as they normally run $29 per diff.
Norse is offline   Reply With Quote
Old 11-07-2015, 12:18 PM   #9197
Anyone using any off the following: XRAY, EXOTEK, or SPEC R aluminum shock caps on their 16? If so how is the fit/seal?
Old 11-07-2015, 01:42 PM   #9198
Default xray xb4 2016 saddle pack batteries
Hello everyone
I want to buy xray Xb4 2016 but I noticed that the vehicle can be mounted is adjusted the saddle pack batteries.
I would like to know if you can put together a saddle pack batteries and how? What should I buy?
Thanks in advance
zikarie is offline   Reply With Quote
Old 11-07-2015, 01:49 PM   #9199
EricW's Avatar
Originally Posted by zikarie View Post
Hello everyone
Thanks in advance
The 2016 is a shorty pack only.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 11-07-2015, 02:55 PM   #9200
Just finished building the new XB4 went together perfectly as all the other XB4 I have built.
Catzilla is offline   Reply With Quote
Old 11-07-2015, 06:30 PM   #9201
Sweet!!!
Old 11-07-2015, 10:57 PM   #9202
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Norse View Post
Big thanks to Suby for hooking me up with a Bugle Boy front bumper
Great looking bumper. Lasted me a month beforeit depleted. .
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 11-08-2015, 01:02 AM   #9203
BentKa's Avatar
No…..we run stock Xray composite
Seals better, wears better and performs better
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 11-08-2015, 07:10 AM   #9204
John.C's Avatar
Trader Rating: 36 (100%+)
Originally Posted by John.C View Post
I would like to run the stock composite rear hubs and upgrade to the Xray 12mm hex and 12mm wheels. Will the 0mm offset 12mm hex (XRA365353) and 12mm wheels (#369912 and #369913) offer the same track width as a stock 2016 XB4 setup using the kit supplied 14mm hex and 14mm wheels?
Can anyone answer the question above? I would like to run the Xray 12mm hex/wheel combo while maintaining the stock track width.
John.C is offline   Reply With Quote
Old 11-08-2015, 08:43 AM   #9205
BentKa's Avatar
Took the time out of my day to measure the different track widths using the new Xray 12mm hex wheels with the Xray 12mm wheel hexes.
All measurement are done on the '16 XB4 using:
  • 20mm ride height (placed on Hudy 20mm droop blocks)
  • 3 degree toe-in in the rear
  • 1 degree toe-out in the front
  • Hinge pin inserts in the middle position front and rear.
  • Measured on the rear of the rear wheels (no tires)
  • Measured on the front of the front wheels (no tires)
Width using stock 14mm wheel hexes and Xray V2 14mm wheels:
  • Front: 245mm
  • Rear: 245mm
Width using 12mm wheel hexes and Xray 12mm wheels:
Front:
  • #365354 -0.75mm = 242mm
  • #365353 0mm = 243,5mm
  • #365355 +0.75mm (1 stripe) = 245mm
  • #365356 +1.5mm (2 stripe) = 246,5mm
  • #365357 +2.25mm (3 stripe) = 248mm
  • #365358 +3.00mm (4 stripe) = Not enough threads on axle to secure the wheel nut.
Rear:
  • #365353 0mm = 243mm
  • #365356 +1.5mm (2 stripe) = 247mm
  • #365357 +2.25mm (3 stripe) = 249mm
  • #365358 +3.00mm (4 stripe) = 251mm
Bent
Old 11-08-2015, 08:47 AM   #9206
BentKa's Avatar
Decided to take the time to measure (almost) every combination of Xray 12mm wheels and hexes………….you're welcome !
Bent
Old 11-08-2015, 08:54 AM   #9207
advpball's Avatar
Trader Rating: 27 (100%+)
Your dedication to helping others is beyond most peoples expectation,and patience for helping is GREATLY appreciated!!!
Thanks BENTKA
xray xb2 de and xsc2,eb410
eb 48.3 for sale artr 500
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 11-08-2015, 09:05 AM   #9208
I never had any issues with my Bugle Boy bumper on my 15 XB4 and it was subjected to tons of outdoor track abuse. I even cut the back 1/3rd of it off for a nicer looking fit.
Old 11-08-2015, 09:11 AM   #9209
Bent
Thanks Bentka! Much appreciated and makes sense.
Old 11-08-2015, 09:12 AM   #9210
Thanks BENTKA
+1
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Pintopint
