Like Tree36Likes
Old 11-04-2015, 09:58 AM   #9136
Trader Rating: 32 (100%+)
I have a question i have front spring 3 dots #368185 and rear spring 2 dots #368285 do you know how many spring rate/lbs? Any input kindly appreciated
raved007 is offline   Reply With Quote
Old 11-04-2015, 10:11 AM   #9137
Originally Posted by teeforb View Post
should i just stick with stock 14mm hex and wheels? the xb4 does come with wheels and body right?
Unless you have loads of 12mm wheels from another car, I'd say yes, stick with the 14mm wheels for now, until hex widths are nailed down more.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 11-04-2015, 10:13 AM   #9138
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
sounds good! i'll do that!
the wheels that comes with the xb4, white or yellow?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 11-04-2015, 10:18 AM   #9139
BentKa's Avatar
Kit comes with 1 set of white 14mm hex wheels and an unpainted body
There's nothing wrong with the standard 14mm wheels
But if you want to go with the new Xray 12mm wheels hex widths are already tried and tested
Xray wheels only come in white though.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 11-04-2015, 10:19 AM   #9140
teeforb's Avatar
I do not see any yellow wheels from xray... is this the case?
Old 11-04-2015, 10:20 AM   #9141
BentKa's Avatar
Already answered a few times the last couple of pages
Xray wheels only come in white.
Bent
Old 11-04-2015, 11:22 AM   #9142
teeforb's Avatar
Do you need the reemer for the arms?
Old 11-04-2015, 11:27 AM   #9143
BentKa's Avatar
Very rarely for the composite arms.
The graphite arms can sometimes be a bit tight though.
Bent
Old 11-04-2015, 11:39 AM   #9144
teeforb's Avatar
Bent
Ok I'm assuming the kit comes with composit arms.
Just ordered.
If someone can link me to a setup sheet to like ocrc (west coast track), that'll be great!
Thx
Old 11-04-2015, 11:51 AM   #9145
BentKa's Avatar
Just ordered.
Thx
Yes composite arms are standard
You can download the entire manual here:
http://www.teamxray.com/xb4/2016/download/
Part numbers for stock and option parts are all in there
Bent
Old 11-04-2015, 12:33 PM   #9146
teeforb's Avatar
thanks!
I was looking at the clay setup sheet. It says 2 1.4mm hole and 3 1.3mm hole piston, 3 and 2 dot springs, with 600 and 450 cst... does this come in the kit?
thx
Old 11-04-2015, 01:13 PM   #9147
BentKa's Avatar
thanks!
thx
Page 30 and 31 in the manual has all the info you need (but in short….YES).
We use the Xray pistons drilled to 2x1.6 and 2x1.7.
Either drill the 2x1.4 or the blanks that come with the kit.
600-750cst in front and 500-550cst in rear depending on grip level.
1 dot springs front and rear for low to medium grip or stiffer if higher grip.
Bent
Old 11-04-2015, 02:10 PM   #9148
Trader Rating: 30 (100%+)
Default Yellow rims XB4
You can always die the white rims using rite die. You tube dying plastic RC rims as there are a lot of videos showing how to properly die plastics to the desired color one may want. White rims are perfect for obtaining the color one may want when using rite dye.
Norse is offline   Reply With Quote
Old 11-04-2015, 02:16 PM   #9149
Bentka,
Do you know if the 81mm front drive shaft will work when setting the 16 XB4 motor config. in the optional farther back position. I was able to purchase the 95mm cvd from the XRAY-shop Austria and thought they would have the 82mm CVD, however they are not positive when they will obtain new 82mm cvd stock.
Thus wondering if the 81mm front drive shaft will work only being 1mm shorter.
Thank you as always for your help.
Best
Old 11-04-2015, 03:36 PM   #9150
Boz
Trader Rating: 23 (100%+)
The rear hubs are different on the '16. Only one pivot hole and it looks like it has been moved a little.
Malin uses the aluminum hubs, which are more like the '15 hubs. This maybe why they are using the +1.50mm offset on the rear. Am I right Bent? Or do the two wheels actually have different off sets?
I have not had time either to do measuring but i recon if you use the '16 plastic hubs with 0.00mm off set (#365353) you may have the same rear track width as the '15 car. I have some of the hubs, just not the 1.50mm ones.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
carpetburner
