Like Tree44Likes
Old 11-03-2015, 12:19 PM   #9106
Trader Rating: 30 (100%+)
Thanks Brudda! I appreciate the help.
Norse is offline   Reply With Quote
Old 11-03-2015, 12:54 PM   #9107
The One They Call Dirty's Avatar
Trader Rating: 57 (100%+)
Default Wheels using 12mm hex
Which offset wheels work best on this buggy when using 12mm hex? Losi, kyosho, yokomo, ae?
Chris Sanchez, Chicago, IL
92zero Designs - Diggity Designs
Fantom Racing - Fenix Racing - Hobbywing
Lunsford - MIP - Windy City RC
The One They Call Dirty is offline   Reply With Quote
Old 11-03-2015, 01:18 PM   #9108
Default Wheels for XB4
I believe Kyosho Lazer ZX6 front/rears RB6 rears. Not positive for sure as I have always used 14mm Xray rims and 14mm DEX410 V3,V4 front and rears.
Old 11-03-2015, 02:35 PM   #9109
Can anyone verify wether the 16 can be set up in saddl config. I am assuming it could fairly easily. Just wondering as the 16 spec kit box pictures it in saddle config.
Old 11-03-2015, 02:45 PM   #9110
The picture on the box is not a pic of the 2016 car. They used an old pic.
As far as putting the 2016 into saddle configuration, the 2016 car only has the option for shorty.
Freeski is offline   Reply With Quote
Old 11-03-2015, 02:54 PM   #9111
freakshow__'s Avatar
where can you get spare front suspension arms? A-main does not have the new part numbers....I assume they are different than the 2014-2015 ones? Anyone?
I hope no one breaks one...they don't seem to be available?
freakshow__ is offline   Reply With Quote
Old 11-03-2015, 03:02 PM   #9112
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
rears are reinforced around the shock hole, from the older versions..
Not sure where the front would be different.
I would be sure they older arms still fit, as the 13's will fit on a 15 without the spacer.
MaricopaAgent is offline   Reply With Quote
Old 11-03-2015, 03:09 PM   #9113
got my xray xb4 in today and was able to get working on it. still waiting on my avid pistons to come in and then ill be able to finish her up. kit went together like the glove on Oj Simpon's hand, super tight and smooth. cant wait to take her to the track this friday
Xray XB4 thread-12212030_1008611619180247_516030584_n.jpg   Xray XB4 thread-12212209_1008659169175492_1735819447_n.jpg
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 11-03-2015, 03:13 PM   #9114
Front and rear arms the same, with some reinforcement around the shock bolts?
Old 11-03-2015, 03:14 PM   #9115
gticlay's Avatar
Part numbers are:
REAR
L - 363111
R - 363121
F 362112
Add a G to the part number for the "hard" graphite part
If you do a web search there's some out there.
You can pretty much find any part number by downloading the pdf manual from the website and many of the optional parts are there as well.
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 11-03-2015, 03:17 PM   #9116
it looks like the new 2016 front arms are different...look at where they mount to the inner hinge pins...it looks narrower and slightly more forward now...I could be wrong....Bentka?
Old 11-03-2015, 03:18 PM   #9117
BentKa's Avatar
All a-arms have the shock mounting holes moved 0.3mm outwards to match the new geometry of the shock towers.
The front arms are also redesigned to move the shock further forward to increase overall steering.
'16 arms also have the screw holes for the carbon plates removed to increase overall strength. Optional graphite arms are being used instead.
The older '15 arms will still fit but will alter the shock geometry as well as reduce overall steering.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 11-03-2015, 03:25 PM   #9118
In the US try discount RC for a arms or call RCAmerica In Dallas.
You could always order from the XRAY-shop Austria which takes about 10 days to arrive to your door. Oh! MB models out of London they are lightning quick being 3 to 4 days to your door.
Old 11-03-2015, 03:26 PM   #9119
BentKa's Avatar
We use the optional Xray Aerodisk 12mm hex wheels which are softer and provide more grip than standard 14mm wheels.
#369912 4WD Front Wheel 12mm with +0.75mm wheel hex #365355
#369913 2WD/4WD Rear Wheel 12mm with +1.5mm wheel hex #365356
Bent
Old 11-03-2015, 03:28 PM   #9120
Thanks Brudda! My kit arrived from RCAmerica today thus I was a little confused by the picture.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
