Like Tree52Likes
Old 10-25-2015, 09:46 PM   #9031
HulkNT1's Avatar
Originally Posted by suby723 View Post
Are you adjusting with the car turned on? That is a must. Set camber first then adjust toe. Camber affects toe.
The car is on but I don't use the chassis blocks..
HulkNT1 is offline   Reply With Quote
Old 10-25-2015, 09:55 PM   #9032
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Boz View Post
I run a 7.5t boosted (composite gear).
The driver having issues is running a 17.5t (steel gears). I did notice he had screwed the slipper nut all the way up a few weeks ago. He also has a lot of rounded screw heads on his car. Something for me to check next time. He has broken one steel gear 14t. Busted 2 teeth off. He put a new one in and on the next run the diff gear broke. He has the habit of not backing off when he looks like crashing and he uses the 1/8th nitro method of pin the throttle and it will flip back onto it's wheels.
He sounds more like a basher, than a racer.. Rounded screws, replaced one side of the gear set, over tight slipper..
MaricopaAgent is offline   Reply With Quote
Old 10-25-2015, 10:16 PM   #9033
It is strange Some people are not having gear issues. I think it may be tracks that have good size jumps that is beating on car more than it can handle. There is no way. Torque value could be set for tiny screws in plastic reliably. X-ray has made new bulkheads for the 16 so they know their is. Issue. As the other guy stated I don't mind buying 20 bucks in gears once in a while. I do however mind when the issue is so bad that gears are on back order everywhere all over the world and I now have a useless car and miss races.
None of these companies ever admit a issue. Always side step it. That's par for the course. But at least the others keep good stock in their parts that fail often.
ResultsRC is offline   Reply With Quote
Old 10-25-2015, 10:25 PM   #9034
HSV427's Avatar
Trader Rating: 22 (96%+)
+1 well said.
If the 16 bulkheads fix the problem i can honestly say my car is bullet proof and i no that saying is thrown around a lot but you tell me one other kit that can race a full season without breaking one single part.
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 10-26-2015, 02:54 AM   #9035
onekiwi's Avatar
Can't wait to test mine
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 10-26-2015, 03:24 AM   #9036
dMITIj's Avatar
what will ppl recommend for a pinion for a 13.5T?
TLR 22-4.
ORION VORTEX R10.1 Pro ESC.
ORION VORTEX VST2 PRO 7.5T.
ORION CARBON PRO 4500 100C 7.4V SHORTY PACK x3.
Sanwa MT4S Radio/RX-481 receiver & Xpert RC PI-3402 Brushless Servo.
dMITIj is offline   Reply With Quote
Old 10-26-2015, 08:25 AM   #9037
Trader Rating: 31 (100%+)
I was running 6.5t and all graphite/comp gears throughout with no issues. Only break I had was a bent right rear axle clearing an 8th scale tracks triple. My fault as my shock oils and springs were not set up for the track.
In a world were very few businesses fully manufacture and produce their own products, Xray is amazing as they are doing it all in house.
Norse is offline   Reply With Quote
Old 10-26-2015, 10:57 AM   #9038
I race my 13 and 14 a lot, did put regularly some copper grease on gears but never broke one (composite gears).
Did race the 15, in fact 3 days non stop 10h a day then 2 days of racing and didn't have any issue.
Gears are slightly worn after a while, just keep lubbing them, check often and replace both before they break.
Besides getting the slipper not too tight there are 2 things that may require attention :
- I try to avoid landing big jumps on full power (6.5 plus boost)
- Even more important is how you set the brakes. Off course you need some but too much hard braking could arm the gears a lot, even worst if your slipper is too tight obviously..
mojo tom is offline   Reply With Quote
Old 10-26-2015, 11:11 AM   #9039
I probably have 10 new of each plastic gear that I am not using.. I can go through my parts if you are interested.
Old 10-26-2015, 04:24 PM   #9040
Boz
Trader Rating: 23 (100%+)
He is fast, just young.
Rounded screws, poor tips on his arrowmax tools.
I only asked him to replace one gear because he only had a few meets on his steel gears. It must have bent the diff gear when the teeth broke off because he said it sounded noisy and then it stopped within the first 2minutes. I bet if I have a closer look, the diff housing may have striped threads in it too.
Slipper!!! New drivers just done understand what a slipper is for.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 10-26-2015, 04:34 PM   #9041
suby723's Avatar
Trader Rating: 21 (100%+)
The 16 kits are going to be in the states this week!
suby723 is offline   Reply With Quote
Old 10-26-2015, 09:44 PM   #9042
A2Racing's Avatar
Default Offset Question
I know a lot of questions have been asked about the XB4 Offset but I wasn't able to determine what kind of rims I need to purchase to fit my 2015 XRay XB4 buggy. I bought it used and it has Exotek 12mm Rear Hex adapters that are 9mm wide, the previous owner gave me some JConcept rims with tires but I can't find a part number to compare the offsets.
I have a lot of Pro-Line Velocity 2.2" wheels (Part # 2736-02) for TLR 22, RB6 and B4.1buggies but I believe they are the wrong offset since there is barely any thread available for the wheel nut. I was thinking of maybe purchasing the Exotek rear hex adapters that are 7mm wide but even then I don't know if that would give me the correct offset.
So if anyone has any advice that would be greatly appreciate, I am looking for rear rims that will work with the 9mm hex adapters or if anyone runs pro-line rims with their XB4 what adapters are they using.
Thanks!!!
A2Racing is offline   Reply With Quote
Old 10-27-2015, 08:22 AM   #9043
The Front wheels listed are 2wd. Not 4wd.. You need a ZX6 or 22-4 for 12mm Hex.
Old 10-27-2015, 09:00 AM   #9044
I have been driving the 14spec and then upgraded to the 15 spec when it came out. I never had a single issue with gears in my 15 spec as I run a Orion r10.1 with the Orion VST2 6.5t motor and center diff upto 100k. In fact the only thing i have broke in more then a year of racing is 2 front bulkheads (which i heard was fixed in the 16spec). so with all that being said I would try and point out the good/great things about a car rather then the faults which in my opinion are none. I have had the b44.3, ZX6, and d410v4 and cant say the same for those cars.
as for my gears in the 14spec I did blow 2 sets but after fixing my slipper I never had another issue. I mean they are composite gears, if you are on full power when landing a jump which we ALL Do from time to time or break really hard into a corner then you should expect to blow a set from time to time.
with all this said I hear Rc America will have the 16specs in by the end of the week so I should have mine by monday or tuesday hopefully. Cant Wait
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 10-27-2015, 10:14 AM   #9045
A2Racing's Avatar
Not sure I am following your response. The PRO2736-02 rims are rear wheels not front and I was under the assumption 2wd and 4wd Buggies use the same rear tires so I am not following.
Maybe I am confused but I believe I have rear wheels that will work though I am not sure about the offsets.
Thanks,
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
