Like Tree39Likes
Old 10-22-2015, 08:18 PM   #8986
Originally Posted by BentKa View Post
One major flaw with forums like this is that every backyard basher out there is an expert…….
The Xray shocks……when built properly…….are some of the best out there…….in fact they are currently THE best shocks in the world at the moment if you should follow the logic of some people on here.
They blame the shocks for their shortcomings on the track………well I praise the shocks for helping Xray win the World Championship this year
We've raced the XB4 for 3 years now both nationally and internationally and I still haven't had the need to shim the diffs or change anything in the shocks.
We run the stock o-rings and stock pistons (drilled to spec) with only regular Hudy oil for sealing and have never had a problem.
We trash on the gears month after month on high grip astro and carpet tracks with 1.000.000 cst in the center diff without any issues at all………..we run in the dirt…..on clay…….and in the mud when it rains………
Of course the buggy needs maintenance……..just like every other buggy out there
These are race kits designed to give you the edge on the track.
If you want a basher……..then a Traxxas might actually be a better choice for you.
If you want a buggy to get into racing then the XB4 is one of the best choices out there at the moment
Bent
The xb4 is a awesome car. Shocks seem fine to me. They do get dirty quick but so do all the other brands. I hear all the time kyosho makes the best shocks but they feel about the same to me. Rc is such a fickle world everyone has a weird opinion. If love to hear the presice details on how the pros build these shocks for best performance
So far as the gears go though when I see everyone at the track replacing gears in them often and seeing gears are on back order at Rc America for ever now. I'm thinking the pros are a bit tongue in cheek saying they are not changing them out also.
ResultsRC is offline   Reply With Quote
Old 10-22-2015, 08:58 PM   #8987
I want to use the 12mm on the 16 xb4 what of the 12mm hex offset do I need to keep the stock track with using jconcepts wheels
billsharp34 is offline   Reply With Quote
Old 10-22-2015, 09:22 PM   #8988
likea45's Avatar
Originally Posted by Troy Mckune View Post
So the Kyosho X rings fit good?
I run the Avid pistons and they work great. I do get dirt in the oil pretty quick when running on a dusty out door track. Inside on the turf or carpet no problems.
They do. It helps keep some of the dirt and dust out as well prolonging oil life.
You don't need to soak the xrings either.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 10-22-2015, 09:32 PM   #8989
COP4's Avatar
Why not use shock shaft protective sleeves since the fluid gets so contaminated as "some" say they do? I'm assuming the shocks are the same on the new XB4 as it was on the last XB4 chassis?
3908 Emaxx (All RPM Suspension, Custom setup shocks by me, Tacon 4074, Xerun 150a, SPC Racing 2s & 3s 70C 7200 Lipos, Proline Desperado's, T-Bone front & rear bumpers, steel skids w/ custom cut oem skids on top, and a destroyed drive train under construction...) & lots of Nitro and Electric Airplanes.
COP4 is offline   Reply With Quote
Old 10-22-2015, 10:59 PM   #8990
Aside from changing oil, I've not rebuilt my shocks in the 3 years I've had the car, I didn't even put the extra o ring in the shock cap that came out after the car was launched.
As Bent said already, they're easily up with the best shocks on the market, the only thing I'd change is to put a hex or something similar into the body to make tightening it up easier.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 10-22-2015, 11:24 PM   #8991
Be interested to know those complaining of quality with the shocks, how often are you rebuilding and replacing wear items like o-rings and other seals.
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
Old 10-23-2015, 12:46 AM   #8992
bd581's Avatar
Will the slipper and new pads still work with a drilled out 69T associated spur?
Planning on running 17.5 in my '16 (when it arrives) will leave my '15 for mod
And when you do run that size spur, what range of pinion fits?
Brad
Xray T4 '16, Xray X1, Tamiya M05 Ver.II Pro.
X-ray XB4 '16, TLR 22 3.0, TLR/Exotek 22T 2.0, Mugen MBX7R Eco.
bd581 is offline   Reply With Quote
Old 10-23-2015, 02:45 AM   #8993
BentKa's Avatar
No idea if the AE spur will work with the new 3 pad slipper or not but the new spur gear is available in 4 sizes:
  • 75T / 48P #365875
  • 78T / 48P #365878
  • 81T / 48P #365881 (standard)
  • 84T / 48P #365884
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 10-23-2015, 02:48 AM   #8994
BentKa's Avatar
Shocks are the same, just with a bit different coating and the tolerances on the pistons are better than ever.
Feel free to use shock boots if you want to……..they're not needed…….but absolutely an option for those who want to
Bent
Old 10-23-2015, 02:52 AM   #8995
BentKa's Avatar
Originally Posted by billsharp34 View Post
I want to use the 12mm on the 16 xb4 what of the 12mm hex offset do I need to keep the stock track with using concepts wheels
I can check when we get the next shipment from JConcepts in 1.5-2 weeks time
Bent
Old 10-23-2015, 03:19 AM   #8996
BentKa's Avatar
We run the same bevel and pinion gear for a full season with no issues.
There's a reason why when we go to the track to practice and do setup testing we get 600+ laps done in an evening and the other guys get maybe 150-200 and spend the rest of the time wrenching.
  • Over-tightened screws for bulkhead cover
  • Over-tightened screws for diff housing
  • Worn out bulkhead
  • Already stripped one of the gears and only replaced one of them
  • Shot bearings
  • Slipper cranked down way too hard (we run 0mm on the spring)
In 98 out of the 100 times I help people at the track with stripped gears one of these things are the culprit.
For the remaining 2 out of 100 we change parts, problem goes away and we never actually pin pointed the exact issue.
What I'm trying to say is……..I'm always told by the owner that everything's perfect and every part has been inspected before I start disassembling…….but almost every single time I find one of the top 4 things on the list to be the culprit……why is that
Race kits with todays high powered motors (we run a boosted 4.5T) DO demand some actual maintenance from the owner to be able to withstand the abuse we throw at them.
Sometimes I wish everyone should have been forced to own a late 80's or early 90's race car running brushed motors and Nimh batteries before owning any R/C car at all so you would actually know the real struggle of keeping a car race ready
Here's Malin running at the worlds with her XB4 '16 with boosted 4.5T and slipper set to absolute minimum = 0mm gap.
So I can't for the life of me understand why people at the track need to run their slippers cranked down……..and then proceed to cry about why their gears wear out
The answer I usually get is; "I'm having problems clearing that jump……"
Rant over
+ YouTube Video
PS! Not aimed at you personally ResultsRC
Bent
Old 10-23-2015, 03:30 AM   #8997
bd581's Avatar
  • 75T / 48P #365875
  • 78T / 48P #365878
  • 84T / 48P #365884
Bent
Thanks for that, but can you (or anyone) confirm what pinion size range will fit if I was to run 75T?
Looking for a FDR in the 5.5-6 range
Brad
Old 10-23-2015, 05:55 AM   #8998
symmetricon's Avatar
Trader Rating: 27 (100%+)
I had the pleasure of watching Malin run he main live in Japan at worlds and let me tell you she is an excellent driver (car looked excellent also), in her main she was definitely faster than half her heat, she got hacked badly by the big boys....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is online now   Reply With Quote
Old 10-23-2015, 07:59 AM   #8999
dMITIj's Avatar
  • Worn out bulkhead
  • Shot bearings
Rant over
Bent
what is "culprit"?
and what do you mean by "Hacked"?
TLR 22-4.
ORION VORTEX R10.1 Pro ESC.
ORION VORTEX VST2 PRO 7.5T.
ORION CARBON PRO 4500 100C 7.4V SHORTY PACK x3.
Sanwa MT4S Radio/RX-481 receiver & Xpert RC PI-3402 Brushless Servo.
dMITIj is offline   Reply With Quote
Old 10-23-2015, 08:09 AM   #9000
  • Worn out bulkhead
  • Shot bearings
Rant over
+ YouTube Video
Bent
To be fair I do run the slipper tight but on med bite clay track it has been this way since beginning in both cars.and never caused issue till bulkheads were broken and replaced I'd think on carpet that would be more issue. Replacing one gear isn't a real culprit because they were both new at some point and still stripped for some reason To be more specific on over tightening. Diff or case. Wouldn't the plastic hole strip before either distorted? What are you looking for in this case to know that was the issue. So if you loosen a bit does that fix issue. If the tolerance of slight over tighten is that close with these bulk heads?Are the reinforced 16 bulkheads solving this issue ? When are those avail ? I replaced rear bulkhead and both composite gears and used one small shim in back of pinion to push closer to bevel in one car and just getting past dozen packs run. I'll let ya know how far it makes it.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
