Like Tree45Likes
Old 10-21-2015, 04:06 PM   #8956
jmkalt's Avatar
Originally Posted by JJG690 View Post
Nobody has got any help for me?
Can't speak to the shock shafts, but I can tell you that B5 shocks are a direct bolt-on.
jmkalt is offline   Reply With Quote
Old 10-21-2015, 04:28 PM   #8957
Trader Rating: 32 (100%+)
Originally Posted by BDRMBULLY View Post
Xb4 shocks are the worst ive ever used. There is 0 quality in their shocks. I have to change shock oils every single race day. The oils get filthy almost sludgy. The pistons suck in atock form . Almost make the shafts wobble in them. Pathetic!!!!.
I agree run only 5 packs shock oil got easily dirty.Now thinking to upgrade from proline pro-specs 1/10 buggy shocks.
raved007 is offline   Reply With Quote
Old 10-21-2015, 04:38 PM   #8958
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
I just pulled the trigger on some b5m shocks on ebay for 65 buck . Otherwise i was gna get the pom cartridge set and several pom pistons and they still would of been black after a few packs so bad that they oval the pistons and render them useless. My avid pistons lasted 6 months on a back yard hard packed clay track. I waste more $ on shock oils changing them constantly. Ill change the oils then run like 4 packs and they feel dead causing my car to donkey ass over head. . Its exausting.
Rant over.
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 10-21-2015, 04:49 PM   #8959
jmkalt's Avatar
Rant over.
IIRC, the only thing you will need besides the B5 shocks are the B5 upper bushings and some longer screws going through the shock tower.
Old 10-21-2015, 04:55 PM   #8960
HulkNT1's Avatar
[QUOTE=jmkalt;14233031]IIRC, the only thing you will need besides the B5 shocks are the B5 upper bushings and some longer screws going through the shock tower.[/QUOT
I use the same screws the lock nut locks perfectly
HulkNT1 is offline   Reply With Quote
Old 10-21-2015, 05:09 PM   #8961
jmkalt's Avatar
[QUOTE=HulkNT1;14233035]
Well, the hole in the B5 shock cap is larger than the XB4, so I used the B5 bushings, and I thought I had to use longer screws, but maybe my recollection is wrong.
Old 10-21-2015, 08:20 PM   #8962
i cant find the 2 ring and pinion gears i need with the 1 rear axle in stock anywhere,both my xb4 cars are broke for this weekend,rc america,discount hobbies,absolute hobbies and local hs all on back order for at least one of these parts, does anyone here have these parts as extras they could sell,im in Va.
ResultsRC is offline   Reply With Quote
Old 10-21-2015, 10:52 PM   #8963
likea45's Avatar
Interesting. Kyosho xrings and avid Pistons installed and my xray shocks are perfect. I do tend to run heavier oil for high bite and those shocks like thicker weight.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 10-22-2015, 12:35 AM   #8964
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
So the Kyosho X rings fit good?
I run the Avid pistons and they work great. I do get dirt in the oil pretty quick when running on a dusty out door track. Inside on the turf or carpet no problems.
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is offline   Reply With Quote
Old 10-22-2015, 01:13 AM   #8965
MiG77's Avatar
Yokomo X-rings (Z2-S3X) fits very well also. These will keep dirt out of the shock way better than xrays own.
MiG77 is offline   Reply With Quote
Old 10-22-2015, 01:55 AM   #8966
dMITIj's Avatar
Do ppl youse "green slime" for there shocks?
TLR 22-4.
ORION VORTEX R10.1 Pro ESC.
ORION VORTEX VST2 PRO 7.5T.
ORION CARBON PRO 4500 100C 7.4V SHORTY PACK x3.
Sanwa MT4S Radio/RX-481 receiver & Xpert RC PI-3402 Brushless Servo.
dMITIj is offline   Reply With Quote
Old 10-22-2015, 05:14 AM   #8967
suby723's Avatar
Trader Rating: 21 (100%+)
Green slime is absolutely key to building a proper set of shocks.
suby723 is offline   Reply With Quote
Old 10-22-2015, 06:57 AM   #8968
or the Cookies Crap Grease is really good as well.
http://shop.leadfingerrc.com/Cookies...-grease_c6.htm
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 10-22-2015, 08:39 AM   #8969
COP4's Avatar
For such an expensive kit, I am basically reading that their shocks are basically junk? Green Slime or not, the shocks should not wear out that fast. Coming from someone that has run mostly monster trucks, Green Slime is not an absolute must, but it is definitely recommended. I'm building a set of Supermaxx SuperShocks and I am using Green Slime on these. These are too expensive not to.
Either way, for the cost of these kits that come with no electronics, and unpainted body and no foam inserts/ tires, you would think they would have the resources to offer the remainder of the kit in top notch form. Hearing this will probably keep me from purchasing their new XB4 16. Too much coin to spend on a kit that I will constantly have to maintenance or rebuild parts. If I want that, I'd just buy another Traxxas vehicle.
3908 Emaxx (All RPM Suspension, Custom setup shocks by me, Tacon 4074, Xerun 150a, SPC Racing 2s & 3s 70C 7200 Lipos, Proline Desperado's, T-Bone front & rear bumpers, steel skids w/ custom cut oem skids on top, and a destroyed drive train under construction...) & lots of Nitro and Electric Airplanes.
COP4 is offline   Reply With Quote
Old 10-22-2015, 09:07 AM   #8970
suby723's Avatar
Better stick to traxxass then! NO race level kit is going to come with all/any of that.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
MrLean
