Like Tree36Likes
Old 10-20-2015, 11:19 PM   #8941
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
Originally Posted by BentKa View Post
We run only the steering brace and no front top deck for added steering.
For the front and rear chassis braces we use the carbon stiffeners.
Bent
Carbon brace on Bruno's buggy from worlds. Are these a factory option part yet?
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is online now   Reply With Quote
Old 10-21-2015, 04:03 AM   #8942
dMITIj's Avatar
The Carbon brace part number is #361178 and info is in the manual it is an option part but is not out yet (ore i can't find it anywhere)
TLR 22-4.
ORION VORTEX R10.1 Pro ESC.
ORION VORTEX VST2 PRO 7.5T.
ORION CARBON PRO 4500 100C 7.4V SHORTY PACK x3.
Sanwa MT4S Radio/RX-481 receiver & Xpert RC PI-3402 Brushless Servo.
dMITIj is offline   Reply With Quote
Old 10-21-2015, 04:06 AM   #8943
hacker's Avatar
Trader Rating: 140 (100%+)
Ha-ha so much for Bruno running a kit car, as mentioned in an interview
hacker is offline   Reply With Quote
Old 10-21-2015, 04:08 AM   #8944
BentKa's Avatar
Yes…..the carbon brace is a factory option part.
For the front you have 2 different steering braces…..with or without an option for the body mount.
Parts are included in the latest parts list sent to distributors on Monday and will soon be available to order
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 10-21-2015, 04:16 AM   #8945
BentKa's Avatar
We all ran the optional carbon brace which will be out as soon as production and packaging is ready.
And some of the other option parts that have been out for the '15 as well such as:
4 dot / 3 dot springs
1.8mm swaybars
12* alu. c-hubs
Alu. rear uprights
Alu. ackermann bar.
Steel gears in the diffs.
All parts that we have been running on the XB4 for the last year on high traction carpet and astro tracks.
Kit car as in no prototype parts………everything is available to everyone…….except the rear brace that they are finishing up now.
Bent
Old 10-21-2015, 04:19 AM   #8946
BentKa's Avatar
Originally Posted by ResultsRC View Post
Thanks. So tightening the 2 screws in the diff cover causes play and striped gears ? The diff seems to fit in there really tight. I have a 14 and 15 and both started stripping gears after I broke a couple bulkheads and replaced them with new ones. I'll try replacing all 4 bulkheads and gears at same time. Pretty expensive but oh well. Are composite gears or metal going to last about the same time. Or metal pinion and composite ring gear best. Rc America is back ordered on both for weeks now. Must be happening to a lot of guys not talking about it here.
No…..over-tightening the screws for the bulkhead cover causes it to be able to expand and affect gear mesh.
Bad bearings will also affect gear mesh.
And if you've had problems with gears stripping change both 14T pinion and 35T bevel gear at the same time or you will continue to have problems with just 1 new gear.
Bent
Old 10-21-2015, 05:13 AM   #8947
COP4's Avatar
Will there be any variations to the body designs and colors for the XB4 16? I'm only seeing the one color on Amain website. I haven't got into painting or drawing designs on clear bodies as of yet. I have one clear body with a pigment design already printed on the body. I just have to add color to the clear areas. That's easy since it already has graphics to paint over though.
3908 Emaxx (All RPM Suspension, Custom setup shocks by me, Tacon 4074, Xerun 150a, SPC Racing 2s & 3s 70C 7200 Lipos, Proline Desperado's, T-Bone front & rear bumpers, steel skids w/ custom cut oem skids on top, and a destroyed drive train under construction...) & lots of Nitro and Electric Airplanes.
COP4 is offline   Reply With Quote
Old 10-21-2015, 05:56 AM   #8948
BentKa's Avatar
XB4 comes with a clear unpainted body.
Bent
Old 10-21-2015, 12:26 PM   #8949
Bent
Over tightening is what I meant to say. My bearings are nice. Diff case is new and both gears replaced at same time. This fix gets me about 6 to 10 packs and grinding starts to be audible. 2 to 3 more packs and they strip. I tried shimming right in back of the pinion and that gave me about double the run time before strip. 6.5 motor on decent c shorty packs on med bite indoor clay track The car is tough other wise. We had some big triple jumps on last layout that broke some bulkheads but other than that rock solid. Gears never stripped before I started breaking bulkheads. Didn't really tighten them much either.
ResultsRC is offline   Reply With Quote
Old 10-21-2015, 12:27 PM   #8950
BentKa:
Do you know if the new 2016 body is compatible with the 2015 chassis ?
Bonanza73 is offline   Reply With Quote
Old 10-21-2015, 12:47 PM   #8951
BentKa's Avatar
Originally Posted by Bonanza73 View Post
BentKa:
Yes......'16 body fits '15 chassis.
Bent
Old 10-21-2015, 02:41 PM   #8952
Originally Posted by JJG690 View Post
Just acquired a used XB4 '14 and the car needs a shock rebuild pretty bad.
Does anyone have a part number for a rebuild kit? I cant seem to find one anywhere. Needs guides and o-rings.
Also found a couple of bent shock shafts...are B5M ones compatible? Shock body lengths are indentical...
Nobody has got any help for me?
JJG690 is offline   Reply With Quote
Old 10-21-2015, 03:02 PM   #8953
BentKa's Avatar
All the part numbers you need for rebuilding the shocks are listed in the manual.
There's no dedicated "rebuild kit".
Bent
Old 10-21-2015, 03:22 PM   #8954
seth556's Avatar
Trader Rating: 42 (100%+)
If you're having to replace the bushings as well as the o-rings you probably need to polish the shock shafts. I did that to my 2015 after about 6 months of running and it made a big difference in how smooth the shocks were.
seth556 is offline   Reply With Quote
Old 10-21-2015, 03:54 PM   #8955
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Xb4 shocks are the worst ive ever used. There is 0 quality in their shocks. I have to change shock oils every single race day. The oils get filthy almost sludgy. The pistons suck in atock form . Almost make the shafts wobble in them. Pathetic!!!!.
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
