Like Tree39Likes
Old 10-18-2015, 08:11 PM   #8926
Originally Posted by COP4 View Post
So how does this chassis and brand compare to chassis like the Losi and the like? As in value vs quality and reliability comparison?
I have a D413, B44.2, ZX-6 and XB4'14.
XB4'14 is by far my favourite to drive but I have upgraded the diff crown and pinions to the steel variants. It's a tank! B44.2 would strip diff gears (TC3 versions basically) and D413 slop is excessive and scared about parts availability and my ZX-6 ... well I can't comment more on that as I'm holding out on running that until I get the gear diffs.
Liking the Xray stuff so much, XB4'16 and XB2 are on the wish list at the moment
Can't comment on the 22-4. I don't like the look of it and aesthetics matter if I'm going to spend money on it
Edit - need to comment that parts support in Hong Kong for Xray is quality and having Bent back on RCTech is awesome!
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 10-18-2015, 08:55 PM   #8927
BentKa's Avatar
Originally Posted by EricW View Post
What about the bulkheads and the 2014 model?
Same for the '14 model
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 10-18-2015, 10:12 PM   #8928
likea45's Avatar
Another awesome factor of this car is how easy it is to work on. You can literally change an arm, rebuild your difs, change the front and rear toe in a quarter of the time it takes to do it on another car. It's just well designed all the way around.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 10-19-2015, 04:02 AM   #8929
Boz
Trader Rating: 23 (100%+)
Default Layout
As requested for HomicidalBunny.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 10-19-2015, 04:28 AM   #8930
HomicidalBunny's Avatar
Thanks mate, this helps
TLR 8ight 4.0 / TLR 8ight-T 2.0
HomicidalBunny is offline   Reply With Quote
Old 10-19-2015, 08:30 AM   #8931
EricW's Avatar
Bent
Thank you!
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 10-19-2015, 08:36 AM   #8932
suby723's Avatar
Trader Rating: 21 (100%+)
I'm getting so impatient for the 16! I feel like any minute Amain is going to be receiving it.
suby723 is offline   Reply With Quote
Old 10-19-2015, 04:56 PM   #8933
Talked to rc America and they said 7 to 10 days before they start to ship here in the usa. So I would guess amain would get it in that time frame since they get them from rc America aswell. Then you gotta factor in the time it takes for amain to ship it to you. Either way I ordered mine right from rc America as I have a account with them.. last year I got my center diff before any other websites here in he USA and from what I have been told rc America is the only distributor in America so I figured ordering from them would be the fastest way to get my hands on one.
randy0025 is offline   Reply With Quote
Old 10-20-2015, 03:07 AM   #8934
Trader Rating: 55 (100%+)
What center diff oil is recommended for medium bite indoor clay track? Somewhat bumpy
Jamison R is offline   Reply With Quote
Old 10-20-2015, 04:32 AM   #8935
GrandeGixxer's Avatar
100,000k
GrandeGixxer is offline   Reply With Quote
Old 10-20-2015, 01:57 PM   #8936
freakshow__'s Avatar
Has anyone looked on petit rc setup sheets at the Bruno Coelho setup from the worlds? All it really shows is detailed pictures of his XB4 but I noticed one thing...
He doesn't have a front upper deck at all...it looks like he even trimmed the front bulkhead area of the front upper deck so that it did not connect to the steering linkage.
My question is:
Why? I thought on turf you wanted the chassis as stiff as possible...wouldn't this make it flex a lot more? Can someone smart explain why he did what he did?
freakshow__ is offline   Reply With Quote
Old 10-20-2015, 02:28 PM   #8937
BentKa's Avatar
My question is:
We run only the steering brace and no front top deck for added steering.
For the front and rear chassis braces we use the carbon stiffeners.
Bent
Old 10-20-2015, 09:46 PM   #8938
The '16 front bulkhead is a direct replacement for the '15 spec part.
For the rear bulkhead you need to clearance the shock tower so it fits over the added bracing when running the shock tower in front of the bulkhead (standard position).
If you're experiencing problems with the pinion and ring gear stripping I would replace them and the bulkhead at the same time.
We constantly trash on these gears both running the center diff with 1.000.000cst grease and tight slipper on both carpet and astro with no issues at all……most recently at the Worlds at Yatabe Arena.
Helping people with stripped gears almost always ends up in changing bulkheads as owners over time have over-tightened the screws for the diff cover allowing the housing to expand and affecting gear mesh
+ YouTube Video
Bent
Thanks. So tightening the 2 screws in the diff cover causes play and striped gears ? The diff seems to fit in there really tight. I have a 14 and 15 and both started stripping gears after I broke a couple bulkheads and replaced them with new ones. I'll try replacing all 4 bulkheads and gears at same time. Pretty expensive but oh well. Are composite gears or metal going to last about the same time. Or metal pinion and composite ring gear best. Rc America is back ordered on both for weeks now. Must be happening to a lot of guys not talking about it here.
ResultsRC is offline   Reply With Quote
Old 10-20-2015, 10:57 PM   #8939
HSV427's Avatar
Trader Rating: 21 (96%+)
Composite is the way to go and you can't use metal with composite it will destroy the comp gear in 5 minutes trust me i tried, l to am at a loss changed my rear bulkhead after stripping gears and it lasted about 5 packs and back to stripping and i really am at a loss oh well at least the composite gear isn't expensive.
Serpent 977 35th anniversary. Serpent 977 evo2, Shepherd Velox, Motonica p81rs2, OS speed shimo edition.
HSV427 is offline   Reply With Quote
Old 10-20-2015, 11:04 PM   #8940
Just acquired a used XB4 '14 and the car needs a shock rebuild pretty bad.
Does anyone have a part number for a rebuild kit? I cant seem to find one anywhere. Needs guides and o-rings.
Also found a couple of bent shock shafts...are B5M ones compatible? Shock body lengths are indentical...
Tekno RC, AKA Products, LFR
JJG690 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
