Like Tree45Likes
Old 10-12-2015, 06:36 PM   #8881
tlyons68's Avatar
Trader Rating: 75 (100%+)
Do you have a link to the driveshafts
tlyons68 is offline   Reply With Quote
Old 10-12-2015, 06:40 PM   #8882
tlyons68's Avatar
Found them thank you what the shipping time to usa
Old 10-12-2015, 06:42 PM   #8883
suby723's Avatar
Trader Rating: 21 (100%+)
Takes about a week or so. Spec r shafts are the way to go forsure.
suby723 is offline   Reply With Quote
Old 10-12-2015, 06:43 PM   #8884
suby723's Avatar
Originally Posted by teeforb View Post
Are parts out of stock something common with the xb4?
Amain or discountrc always seem to be stocked. Also eBay is a great resource for parts.
Old 10-12-2015, 09:41 PM   #8885
HSV427's Avatar
Trader Rating: 22 (96%+)
Its very rare to find XRAY parts out off stock, however there are a few parts that seem to fail on some cars but not all, for example the front drive shafts and the 14t bevel diff gear seem to always be out of stock around the world and i don't no if its because XRAY is addressing the issue or because people are going threw them quicker than they can be produces, in either case there are options, I've been running SPEC-R for a year now with out a problem and as for the bevel gear, well the minute you start stripping them thats usually a sign your rear bulk head needs replacing well for me anyway but other than that my xb4 is the best most durable car i have ever owned besides the drive shaft and bevel gear my car is bullet proof and trust i punish my car 5 days a week and close to 5 packs a day.
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 10-12-2015, 11:33 PM   #8886
BigInJapan's Avatar
Trader Rating: 15 (100%+)
The '16 will have re-inforced bulkheads so if they can be retro fitted then that may be a solution HSV
⚡ TEKNO ⚡ OS ENGINE ⚡ KO Propo ⚡
BigInJapan is offline   Reply With Quote
Old 10-12-2015, 11:36 PM   #8887
BentKa's Avatar
Originally Posted by HulkNT1 View Post
Need some help with this issue. I setup my cars with Hudy setup system but this is the thing when I set it with the board an then put the tires an use the camber gauge it like 1 degree off now why is that. Should I go by the camber gauge or setup board system????
This is not an "issue"
Your Hudy setup system when used correctly and with the 20mm chassis support blocks (#107701) will give you the correct measurements each and every time
As the name indicates the Hudy quick camber gauge should only be used for quick setup changes and to give you a quick reference when making adjustments.
The results obtained using a camber gauge will vary when turning the wheel and will not be a consistent measuring method like the setup system
It normally only takes a couple of minutes extra to use the setup system instead of the quick camber gage and is always our preferred method of measuring if time allows
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 10-12-2015, 11:55 PM   #8888
BentKa's Avatar
The front '16 bulkhead is a direct replacement, but for the rear you will have to slightly clearance the shock tower to make room for some of the reinforcements on the bulkhead when running the shock tower in front of the bulkhead (standard position).
Bent
Old 10-13-2015, 12:03 AM   #8889
BentKa's Avatar
By next January they will have the 2017 out.. Xray is kinda becoming like Apple release kit too fast. What's everyone take of this.
Xray normally releases updated or new models with 1 year intervals.
This should be no surprise to anyone that has followed Xray for a couple of years
Updated parts and setup changes the Factory Team work on during the season will be incorporated into the updated kits to ensure the different platforms are as close to the top of their class as possible.
New parts are always tested to search for improvements and is a continuous work in progress
Some parts never even make it to production as they offer little to no improvement and in some cases might be too fragile or complicated for the normal end user.
The release times of new or updated Xray kits normally follow the European racing calendar to make sure new models are in place for the start of a new season
But some times this will vary slightly due to production capacities.
Bent
Old 10-13-2015, 07:01 AM   #8890
RokleM's Avatar
Trader Rating: 33 (100%+)
Originally Posted by RokleM View Post
Trying to figure out of the XB4 wheels are that different from the 2014, or if they're just re-enforced. To have to replace tires/wheels will be most costly than the vehicle itself.
Anyone figure this out?
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 10-13-2015, 07:11 AM   #8891
jmcelroy42's Avatar
I think the wheels have been the same since the '14 model.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 10-13-2015, 08:26 AM   #8892
BentKa's Avatar
'14 and newer wheels labeled V2 have a +1mm wider offset in the front.
Other than that they are interchangeable.
New 12mm wheels also have the same offset but are significantly softer to increase traction.
Bent
Old 10-13-2015, 03:26 PM   #8893
I wish i knew when the release of the new car is.
I stopped at my sponser to get to a new car/brand for coming winter and summer season.
At this point testing a car but i would love to race Xray as i have done in the past.
Pls i need a car soon as racing starts, dont let us wait any longer!
Supported by: Absima.com - TeamCracing.net - jdrracingparts.nl
Cars TeamC: T8EV3 - TM2V2 - T2EVO - TS2TE
Electronics: Airtronics/Sanwa - Absima
Cale79 is offline   Reply With Quote
Old 10-13-2015, 04:27 PM   #8894
suby723's Avatar
The cars are shipping now. Xray Austria has them available for purchase.
Old 10-13-2015, 04:45 PM   #8895
any ideas when amain will be shipping? any ideas at all?
DIRT DIGGER is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
