Like Tree39Likes
Old 09-17-2015, 03:16 PM   #8731
advpball's Avatar
Trader Rating: 27 (100%+)
looking for xb4 81mm shaft front ,none in stock a main or stormer.
xray xb2 de and xsc2,eb410
eb 48.3 for sale artr 500
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 09-17-2015, 03:37 PM   #8732
rcgod's Avatar
Google the part number or check on ebay.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 09-17-2015, 09:11 PM   #8733
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Ah the mighty front shaft everyone says is fine yet they have been on back order for over a year. Did yours snap at the barrel end?
BDRMBULLY is offline   Reply With Quote
Old 09-17-2015, 09:22 PM   #8734
rcgod's Avatar
http://www.discountrcstore.com/mobil..._p/365220.htm=
Looks like they're in stock there.
Dialed RC Hobbies
Old 09-18-2015, 08:46 AM   #8735
BigBrute_347's Avatar
Default Offset Hexes
Anybody using positive offset wheel hexes up front? I have +1.5 mm front hexes and that results in not enough wheel nut thread engagement. Are there longer stub axles to enable these offset hexes?
BigBrute_347 is offline   Reply With Quote
Old 09-18-2015, 06:50 PM   #8736
Trader Rating: 75 (100%+)
Absolute Hobbyz has them in stock. I just ordered one myself and their site still shows more in stock:
http://www.absolutehobbyz.com/XRAY-F..._p_499327.html
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 09-19-2015, 08:24 AM   #8737
seth556's Avatar
Trader Rating: 42 (100%+)
I run the low profile JConcepts M4 nuts. The serrations on them are really good but over time you'll have to replace them to keep them fresh. I find the front goes through a lot more stress than the rear so it's important to have good wheel nuts.
I have a couple questions...
1. Is the servo linkage supposed to be angled like this. When I turn left the linkage almost touches the top deck plate. It doesn't but there is probably only about .001" between the linkage and the bottom of the top deck. I am using an alum horn not one of the plastic ones. so maybe that is why. If I drop the linkage down one hole on the arm the linkage hits the top of the servo at full turn left.
Is the slipper assembly supposed to be able to move back and forth in the mount? Or should it be shimmed so there is no back and forth movement? I am used to 8th scale buggies with a CD. I have never had a slipper before. I am also wondering is this slipper just as good as a CD? With a CD power is transferred front to back as needed. I don't see how the slipper would do that. So it seems like on the xb4 power can only be transferred side to side through the front and rear diffs? Or am I looking at this wrong?
If you want to stick to an aluminum servo horn, the Hudy one is the same height as is the Racers Edge clamping horn. It's important that they're the same height or you'll end up with the same problem you're experiencing now, or if it's too low then the steering link will hit the servo case.
The slipper assembly should have some play back and forth, about 1mm, to deal with chassis flex. If you put shims in there, as the chassis flexes there will be considerable load on the 10x15 bearings holding the slipper.
Some guys like the center diff, other guys like the center diff. I feel as though the center diff is easier to drive and has more traction, especially in sweepers, but the slipper has a much more direct feeling and gives better rotation. My rule of thumb is if it's a loose track, run the diff, if it's high bite, run the slipper.
seth556 is offline   Reply With Quote
Old 09-19-2015, 08:24 AM   #8738
You can try a TLR front wheel nut as they are a bit thinner than stock.
Why are you running the front so wide?
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 09-19-2015, 09:23 AM   #8739
I'm actually just trying to match the original front width while using AKA front 12 mm hex wheels.
Old 09-19-2015, 01:53 PM   #8740
HulkNT1's Avatar
I having issue that my turn buckles are pop off is anyone having this issue?? Are you using diff steering link that use screw and a self locking nut to avoid this issue??
HulkNT1 is offline   Reply With Quote
Old 09-19-2015, 07:04 PM   #8741
Trader Rating: 32 (100%+)
I have same problem every time hit the pipe pop off. I upgrade lunsford super duty turnbuckle
raved007 is offline   Reply With Quote
Old 09-19-2015, 07:27 PM   #8742
Mizchief's Avatar
Don't hit the pipe so hard If the ball cups are susposed to pop off if you hit something hard enough to prevent something else breaking. However if the cup starts to get loose it will pop easier. I typically replace them after poping off 2-3 times of If I feel i didn't hit hard enough for it to pop
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 09-19-2015, 09:06 PM   #8743
carrotcake's Avatar
Hi guys, xb4 2015 newbie here. I just bought the kit, but I saw somewhere there were issues with rear toe ? like people were saying Xray was sending replacement parts to customers to fix the issue for free? ... any other "Problems" in this kit that I should know?
carrotcake is offline   Reply With Quote
Old 09-20-2015, 04:10 AM   #8744
rraden's Avatar
Trader Rating: 231 (100%+)
There was a problem with the rear toe block being machined incorrectly. If your kit hasn't been sitting on the shelf for the past 8 months you will be OK. Xray fixed it earlier this year. If interested there is ample reading on page 444 of this thread. If by chance you have an "old" kit contact RC America and they will replace the rear toe block for free. Enjoy your car, it's awesome!
Xray XB8E 2016 | MBX7TR Eco | Xray XB4 2017 | Xray XB2 DE | Xray XB8 2017
Dirt Burners - Livonia, Mi
The Track - Carleton, MI
rraden is offline   Reply With Quote
Old 09-20-2015, 04:12 AM   #8745
rraden's Avatar
Anybody know what bodies they are running on these cars at the EOS race?
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
