Like Tree37Likes
Old 08-26-2015, 06:00 PM   #8671
TV
Originally Posted by nismortrd View Post
So I'm trying to setup my xb4 4wd for my local clay track and I am trying to see what oils I should start with for the shocks and what oils for the dif. I'm running a 2014 xb4 I bought used mad trine to go threw it and get it set to hook at my track. Any suggestions would be great.
Thank you
Justin
10k front and 5k fear for the diffs, and 42/27 for the shocks with 1.3x3 pistons should be a good start.
XRay | RCAmerica | AKA | FX Engines | MotivRC | P1Hobbies.com | Sidewinder | Airtronics | UpGrade RC
TV is offline   Reply With Quote
Old 08-30-2015, 06:42 PM   #8672
tony montana's Avatar
Trader Rating: 65 (100%+)
Ok fellas, getting the 15 edition ready for the approaching indoor season. Ran into a problem. The screw that secures the steel pinion gear inside the front gear box stripped out on me. Now I use quality tools. I use strictly MIP. I have tried just about everything to get it out. Even tried a speed out with no success. The opening is to small to get a dremel in the without doing major damage to the front gear box and pinion gear. Any other suggestions I can try?
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 08-30-2015, 07:09 PM   #8673
timannnn6's Avatar
Trader Rating: 124 (100%+)
I've used these many times all successful.
http://www.amazon.com/Alden-4507P-Gr.../dp/B000Q60UOO
timannnn6 is offline   Reply With Quote
Old 08-30-2015, 09:35 PM   #8674
you need a smaller cutting wheel.
It can be done..... I know. :-)
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 08-31-2015, 09:47 AM   #8675
Slapjack's Avatar
Trader Rating: 19 (100%+)
I am new to 10th scale and I am looking at getting into indoor racing. I am debating between the XB4 and the D413 (leaning towards the xb4). I would be going with either Tekin RSX or Orion R10 or Viper ESC. The tracks I would be running on are med size (nothing large). What motor would you all recommend... 6.5, 7.5, 8.5?
And are there any upgrades on the XB4 I would want to do off the bat? I may buy the 2015 but maybe the 2014. with 2014 I would want to do the steel diff gears right? And I also like the idea of a CD. Do the 2015 come with the CD? or do you need to buy that separately? I hear everyone say that xray parts are more expensive compared to others like the D413. Is that a big deal? I also hear that the xb4 is tough and won't really need replacement parts very often.
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 08-31-2015, 09:56 AM   #8676
rcgod's Avatar
Trader Rating: 27 (100%+)
If you want to run a center diff and/or shorty pack get the 2015. The center diff doesn't come with the car and costs $60.
Yes xray parts are more expensive than almost any other car. The car is tough but commonly broken parts are arms, front shock tower and front diff case. If you keep the car long enough to wear out the outdrives and bones you'll be shocked at how expensive they are. Just fyi.
The only upgrades I would recommend are shock pistons (schelle or avid) and 1 dot rear springs. Maybe a couple different size sway bars. And the rear wing mount gets hammered so a lot of guys go with the exotek one.
rcgod is offline   Reply With Quote
Old 08-31-2015, 10:02 AM   #8677
Trader Rating: 15 (100%+)
I'll take a stab at this: @slapjack
Any of those ESC's can do the job. I like Orion myself.
Depending on your skills, will dictate your motor choice. I'd say a 7.5, you could always add some boost thru the ESC if you needed more.
If you buy a 2014, steel gears are nice, but not a must have. Many have run indoors on clay and carpet with the plastic gears. Set your slipper right and you'll be good.
The CD only fits the 2015, and is available separately.
The only must have hop up I can think of are aluminum CVD cups. Search this thread otherwise for good advice.
Parts are expensive, but I have broken only a few items in the past three years. The buggy is tough.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 08-31-2015, 10:23 AM   #8678
Slapjack's Avatar
Thanks guys. I appreciate it.
Old 09-01-2015, 06:06 PM   #8679
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Hey, You GUYS!!!!!!!
Are spec R cvds worth it at 30 cents to the dollar??????
Broke another front bone at the weak point . Its getting old. Xray better beef up that part where the barrel goes in. Im at the point im waiting forca 16' before i wait for a back ordered front bone.
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 09-01-2015, 06:33 PM   #8680
rcgod's Avatar
My spec r driveshafts lasted about 4 races and broke the axle. My spec r shock mounts broke when I installed them and dropped the car from 6 inches. Imo they're cheaper but you get what you pay for in this case.
Old 09-02-2015, 04:54 AM   #8681
Before I tear down the slipper assembly, do you guys think a Schumacher spur/slipper pads will fit? (I have a ton of Schumacher spurs and only a single Xray spur is why I ask)
Zak
PRS1 V3 (FM), Mugen MBX7 Eco
Team Absima UK
PR Racing UK
fivepointnine is offline   Reply With Quote
Old 09-02-2015, 07:26 AM   #8682
timannnn6's Avatar
I broke all but 1 of my Spec-R front driveshafts (I bought two sets). They are just not made to handle the stress. I did not hit anything with the car, they would just snap upon landing a jump.
Spec-R did refund my money for both sets though. So kudos to their customer service dept. Would not purchase again though.
I did break two stock shafts (that's why I tried the Spec-R) but currently have a set with 50 packs through them without issue. I turned my EPA way down so there is no stress on front end when turning. Seems to help.
Old 09-02-2015, 09:44 AM   #8683
I bought a set of Spec R driveshafts last summer, I broke one of the tiny CV d pins near the end of the season because I was told not to bother lubricating them, big mistake, but that's all I've broken. I make mistakes, crash and have cartwheeled off the track with them. Never sheared anything off.
Daragh Slowey
Old 09-02-2015, 04:54 PM   #8684
BDRMBULLY's Avatar
Hmm well losi has a pair for 22$ for the 22_4 im considering buying to see if they'll work . They are also 81mm.
Hand D Flooring
Old 09-02-2015, 06:52 PM   #8685
HSV427's Avatar
Trader Rating: 21 (96%+)
Don't waist your money the TLR ones won't fit i made the same mistake as X-ray measure there drive shafts from end to end and TLR measure from centre to centre. The TLR shaft is actually 88mm not 81.
XRAY XB4 15, XRAY XB4 16, XRAY XB2, YOKOMO B-MAX4 III FACTORY KIT, YOKOMO YZ4, YOKOMO YZ2,KYOSHO RB6, TAMIYA TRF503, TAMIYA TRF201XMW, TAMIYA TRF 211XM
HSV427 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
