Like Tree44Likes
Old 08-03-2015, 03:09 PM   #8611
Originally Posted by rcgod View Post
Take a look at Leon's setup he posted a couple posts before yours. I think if you keep your current shock setup maybe going down to 37.5/27.5 in oils and using his arm mount positions you should have plenty of steering. Also take off the front sway bar. Having really heavy center diff fluid doesn't help off power steering either. Maybe try 100k to 200k.
Freeski, I'd start with no sway-bar. It'll give you more steering, and make the steering feel more linear. If you still feel like you need more steering, move the front shocks in on the tower and the arm, and add another downstop shim. I'd always leave the rear toe at 3 degrees.
Thanks guys, appreciate the advice. I will definitely try it and report back.
Freeski is offline   Reply With Quote
Old 08-04-2015, 12:15 AM   #8612
Hey guys,
I'm guessing the xb 15 toe is correct now in the new kits.
Going into the store to get one on order, what spares to have on hand and is there any optional upgrades must have with besides centre gear dift to order in.
Racing on carpet. Thanks in advance.
Vinno is offline   Reply With Quote
Old 08-04-2015, 05:13 AM   #8613
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Buy 2 kits lol
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 08-04-2015, 05:43 AM   #8614
HSV427's Avatar
Trader Rating: 22 (96%+)
Originally Posted by Vinno View Post
Hey guys,
I have been running X-ray for nearly one complete season and the only spare parts i have needed are the f/r 14t bevel gears in the diff, get the composite ones and your good to go stay away from the metal ones they chip teeth very quick and are just real poor quality in general, I'm really shocked how X-ray hasn't fixed this problem, other than that the buggy is the best buggy out there both in quality performance and durability, also if you run composite you will need the composite 35t bevel diff gear as well. the part numbers are X-ray 364935 and 365114, other than that just enjoy it truly is an amazing buggy.
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 08-04-2015, 05:46 AM   #8615
HSV427's Avatar
Originally Posted by TPR 1 View Post
Does anyone know of a company that sells carbon fibre chassis for the 15 ?
I have looked every were with no luck, i even emailed dhawk racing to see if they would make one as they make them for the 14 and 2wd 14 but still haven't received a response.
Old 08-04-2015, 11:03 AM   #8616
skeasor's Avatar
I was going through my car last night making sure everything is ready for indoor season and the one bearing on my rear out drive is stuck on the outdrive. Has this happened to anyone before? I'm hoping I don't need to get a new outdrive. I tried everything I could think of to remove the bearing but had no luck.
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 08-04-2015, 11:37 AM   #8617
Originally Posted by Freeski View Post
- Would using the front hole on the steering rack give me more in corner steering? (I am currently using the rear hole)
- For those of you that have used the optional 4 hole steering rack (#362573), How did the different hole options affect in corner steering?
Any help is welcome. Thanks.
The forward hole would reduce the amount of ackerman in the steering. Meaning the inner front wheel would turn at a similar radius as the outside front wheel. For tight turns, more ackerman, the inner wheel turns sharper than the outside wheel, would have more overall steering and better turn in.
LAGuy is offline   Reply With Quote
Old 08-04-2015, 09:29 PM   #8618
TPR 1's Avatar
Trader Rating: 26 (100%+)
Ok cheers for that.
I bought the chassis stiffeners after reading your post and yes I agree without
The top decks the buggy felt like it drove better and had more traction on my local low bite track , but I noticed my chassis had a slight banana bend in it that's the reason I'm looking into a carbon fibre chassis .
I'm surprised no one else has had the same problem cause like I said I didn't crash the buggy once!
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Old 08-05-2015, 12:25 PM   #8619
jmackani's Avatar
Trader Rating: 14 (100%+)
Your outdrive probably is notched and has a high spot that can be simply ground down with a dremel.
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 08-05-2015, 07:55 PM   #8620
BigInJapan's Avatar
Trader Rating: 15 (100%+)
yes. if your drive pins are worn they create a ridge on the outdrives. dremel or file them down and replace pins to stop premature wear of outdrives
⚡ TEKNO ⚡ OS ENGINE ⚡ KO Propo ⚡
BigInJapan is offline   Reply With Quote
Old 08-06-2015, 05:44 AM   #8621
skeasor's Avatar
I'll take a picture sometime today. It's not from the pins or because there is a notch on the out drive...It's almost like a piece of rubber or something seized to the outdrive right where the bearing sits. The bearing wont budge from where it's supposed to be...if that makes any sense.
Old 08-06-2015, 02:09 PM   #8622
skeasor's Avatar
Ok here the pic...The parts that's keeping the bearing from coming off is circled in red. The diff case looks fine though so I'm not sure what caused it. Any help would be appreciated.
Thanks!
Old 08-06-2015, 10:52 PM   #8623
Thanks!
it looks like dirt...... but im sure that helps alot
so the McGyver in me says to place the diff on a table, bad bearing side down, place a pair of scissors on the backside of the stuck bearing between the bearing and the case and then whack it with a pair of pliers.
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 08-07-2015, 05:14 AM   #8624
BDRMBULLY's Avatar
Just grab the bearing with vise grips. And tap on the out drive. But use a piece of wood on the out drive when you hit it. So as not to snap the outdrive . It will come out.
Hand D Flooring
Old 08-09-2015, 03:52 PM   #8625
BigInJapan's Avatar
can anyone tell me if they are running a center diff in their 2014? and if so what parts other than the diff did you need? TIA
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
