Like Tree37Likes
Old 07-28-2015, 01:18 PM   #8596
hugin_q3's Avatar
Originally Posted by punkracer24 View Post
The guys at RCAmerica and the Hudy's take that stuff very serious. Glad to hear its headed in the right direction for you.
Yep they do, this however will be dealt directly with the Xray in EU as I am an European. And I believe this is a issue outside Xray department so to say.
Originally Posted by HeavyD99 View Post
@hugin, that is surprising that a kit in such suspect condition made it into your hands, it might have been destined for return to Xray I hope, and you got it by mistake! Glad to hear they are correcting it for you.
I had a chance to run my '15 this past weekend on a hard packed clay track, kept damp, only minimal dust, with the new 2mm chassis stiffeners, the steering x brace and the floating servo mount. I run in shorty config. I noticed the buggy felt really good, planted and yes, it had traction. I was running mine way too low for no other reason than I was completely misreading my ride height gauge (long story). Anyhow, once at the proper ride height I had loads of traction (but I drove like a donkey). The chassis certainly has flex to it. You can bend it yourself without too much force. As said many times, it's a tuning thing and may not be right for everyone, but I like it. Oh, and no, even after many crashes, flips and a few cartwheels and casing a few jumps, the bottom of the chassis is still flat as glass. The new stiffeners are for traction, the shocks are for handling. I like them.
This kit has either passed inspection that it should not have passed. Or the kit has been tampered with in some way. The Xray kits comes with Xray tape as the seal right? But this one had the sealed tape all on skew and looked to be tampered with. This makes me think that this kit has been put together after it left Xray factories, I.E. it has been opened and the seal has been broken. At least that it what I think has happened here. They also said that this kit did not comes from my national trader for Xray in Norway but from a dealer in Sweden. It should come directly from Xray and not trought a 3rd dealer in Sweden, as I understand the Xray convo trough email. Meaning, yeah, what does that means really? Most likely the Norwegian dealer has bought cheap kits from the Sweden dealer, or just bought them from them because they did have other reason we don't know the reason for.
In the end, this kit has been tampered with after it left Xray factories I am sure, and the bags inside are missing the numbering labels and such, This is not like Xray at all.
What I think? This is a kit is been open to help out some poor guy missing parts and then they have added some bags/ parts later to make it a full kit again. That part can indeed be the chassis plate, that is bent in several axis..
This is making me as an customer to suffer for it. This is not like the Norwegian Xray dealer at all, sending out a kit like this. Unfortunately they are still on summer vacation all this week, so I need to wait to next week to get the new chassis in house..
Anyway, it is dealt with by Xray and the kit will come together and I will indeed enjoy my XB4 soon, after all, that is all that matter
When it comes to chassis flex that is all ok, only problem is if you start out to adjust chassis flex on a bent chassis plate it will never get a car that will drive straight, but we both know that anyway. If I did understand your input correctly?
With the chassis braces etc mounted the chassis will not bend that easy, but as a part in your hand it will fore sure hehe. My biggest concern is the axial issue that is out of line with 2-3mm (0.12''), that is not so easy to correct.
<< 5ive-T | Tekno SCT410.1 | Carisma GTB | MBX6e | MP9e ~ TF-5 | XB4'15 ~ T4'13 ~ T4'14 >>
<< Futuba 4PK Super-R | Futuba T4PX >>
hugin_q3 is offline   Reply With Quote
Old 07-29-2015, 06:42 AM   #8597
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
Can you Xray guys answer a question for me? What is the diameter of the shock pistons? I understand they are bigger than AE pistons, but how much. Thank you.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 07-29-2015, 01:56 PM   #8598
GrandeGixxer's Avatar
.473"
GrandeGixxer is offline   Reply With Quote
Old 07-31-2015, 07:06 AM   #8599
BentKa's Avatar
New release from Xray for the XB4 and upcoming XB2.
Softer for improved traction and more universal 12mm hex mounting.
New 1/10 Off-Road Wheels Aerodisk with 12mm Hex
Specially-designed 1/10 off-road wheels with 12mm internal hex. Perfect fit, and perfect for high-competition racing. The wheels are made from flexible material while still being durable against impacts. The side of the wheel is aerodynamic for maximum performance.
Special features of the wheel are visible from the inside: reinforcement ribs to make the wheels as stable as possible and eliminate deformation.
12mm internal hex
Excellent for high-competition racing
Flexible yet durable material
Perfect fit
#329910 2WD Front Wheel Aerodisk with 12mm Hex - White (2)
#369912 4WD Front Wheel Aerodisk with 12mm Hex - White (2)
#369913 4WD/2WD Rear Wheel Aerodisk with 12mm Hex - White (2)
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 07-31-2015, 07:23 AM   #8600
Trader Rating: 15 (100%+)
what width/size 12mm hexes are to be used?
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 07-31-2015, 07:29 AM   #8601
BentKa's Avatar
Will find out at the EFRA European Championship next week
http://www.uk2015.com
Bent
Old 07-31-2015, 07:33 AM   #8602
Suspended
Bent
Is Malin going to the Euros?
Mantis Toboggan is offline   Reply With Quote
Old 07-31-2015, 07:35 AM   #8603
BentKa's Avatar
Yes
Bent
Old 08-02-2015, 02:41 AM   #8604
TPR 1's Avatar
Trader Rating: 26 (100%+)
Does anyone know of a company that sells carbon fibre chassis for the 15 ?
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Old 08-02-2015, 04:01 AM   #8605
skeasor's Avatar
I was thinking about trying to run the xb4 as a 2wd buggy for fun. Does anyone know if the xb4 2wd buggy wheels mount directly to the xb4? I'm assuming so since they're both 14mm wheels but wanted to see if there was something else I needed to do.
Thanks!
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 08-02-2015, 09:13 PM   #8606
Had a pretty good first "big" race with my XB4. Car was incredibly easy to drive and would more than recommend my setup to anyone racing in high traction.
Here is my setup as well:
http://forum.teamxray.com/xform/inde...setup=xb4_2015
The car was awesome. Not sure I could do anything to make it better. I lead the entire race except for the last half a lap when some traffic caused a ruckus. Eager to get out and race it some more.
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 08-03-2015, 08:55 AM   #8607
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
If anyone is looking for a good deal on a lightly used XB4 2015, I have one for sale look here.
_____________________________________
Earl Towson
Team RC America - Xray USA - Hudy USA - Motiv RC - Max Power - Gravity RC - Prolevel RC - GRIPWORKS RC
WCICS.ca club rep. www.krcracing.ca
SLOWINSLOWOUT is offline   Reply With Quote
Old 08-03-2015, 11:08 AM   #8608
Default Looking for more in-corner steering / 4 hole steering rack
As the title says, I am in search of more in corner steering. My situation is that the initial turn in is good, but once the car is in the middle of the turn, it feels like I have to get off the throttle, wait for the car to rotate and then I can get back on the throttle for exiting the corner.
Basically, the car has a bit of hesitation or "stalling" in the middle of the corner. I have experimented with freeing up the rear end, but after trying different toe settings/track width options, I settled with what I started with prior to experimenting because the car felt the most natural for my driving style.
I am attaching a copy of my setup sheet and I run on medium to medium-high grip indoor clay.http://www.rctech.net/forum/attachme...2015110154.pdf**I made a mistake on the setup sheet,I am using the stock hubs of 9 degrees. Also run no top decks, but do run the optional graphite stiffeners, x brace, and floating servo mount.
The only change I have made since the setup sheet is to adjust the rear toe to 3 degrees. That helped the car rotate better.
- Would using the front hole on the steering rack give me more in corner steering? (I am currently using the rear hole)
- For those of you that have used the optional 4 hole steering rack (#362573), How did the different hole options affect in corner steering?
Any help is welcome. Thanks.
Freeski is offline   Reply With Quote
Old 08-03-2015, 01:05 PM   #8609
rcgod's Avatar
Trader Rating: 27 (100%+)
Take a look at Leon's setup he posted a couple posts before yours. I think if you keep your current shock setup maybe going down to 37.5/27.5 in oils and using his arm mount positions you should have plenty of steering. Also take off the front sway bar. Having really heavy center diff fluid doesn't help off power steering either. Maybe try 100k to 200k.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 08-03-2015, 02:37 PM   #8610
TV
Freeski, I'd start with no sway-bar. It'll give you more steering, and make the steering feel more linear. If you still feel like you need more steering, move the front shocks in on the tower and the arm, and add another downstop shim. I'd always leave the rear toe at 3 degrees.
XRay | RCAmerica | AKA | FX Engines | MotivRC | P1Hobbies.com | Sidewinder | Airtronics | UpGrade RC
TV is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
