Like Tree52Likes
Old 07-16-2015, 09:55 AM   #8566
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by likea45 View Post
Can you elaborate? Are you changing the inserts to achieve this or just moving spacers?
Just move spacers.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 07-16-2015, 03:01 PM   #8567
Trader Rating: 32 (100%+)
Last weekend first run without rear brace and front brace but had a top deck brace with 3mm chassis very easy to drive a consistent lot of traction. My local track hard pack with blue grove running sweep slick tires.
raved007 is offline   Reply With Quote
Old 07-16-2015, 04:29 PM   #8568
jmkalt's Avatar
Is there any way to still use the body mounts with the new graphite chassis braces?
jmkalt is offline   Reply With Quote
Old 07-16-2015, 04:43 PM   #8569
HulkNT1's Avatar
Originally Posted by Peakki View Post
I've noticed that if you enable reverse on the R10 Pro (not tried it with R10.1), it feels on neutral that there is drag brake on. don't know really the reason for it! So check that and disable reverse
Ok I do have reverse on will take it off
HulkNT1 is offline   Reply With Quote
Old 07-16-2015, 08:33 PM   #8570
What part number for the o ring up stop shock limiters? Or does something else work? Thanks!
LAGuy is offline   Reply With Quote
Old 07-16-2015, 11:41 PM   #8571
You can use any type of o ring you like, it doesn't t have to be the XRAY ones.
Fuel tubing works well, but I use some of Durango's moulded rubber stoppers on mine, find them more sturdy then normal o rings.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 07-17-2015, 12:58 AM   #8572
HSV427's Avatar
Trader Rating: 22 (96%+)
You already have the part to mount the rear body mount and you will need 361173 to mount the front one or you can do as i do and use velcro to hold the body at the front.
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 07-17-2015, 05:43 AM   #8573
jmkalt's Avatar
Originally Posted by HSV427 View Post
You already have the part to mount the rear body mount.
Old 07-17-2015, 07:45 AM   #8574
timannnn6's Avatar
Trader Rating: 124 (100%+)
It comes in the kit.
timannnn6 is offline   Reply With Quote
Old 07-17-2015, 10:29 AM   #8575
jmkalt's Avatar
Does that part come with a spacer to raise part #361165 in the front where the upper deck used to be?
Old 07-17-2015, 11:47 AM   #8576
http://www.t2shop.de/WebRoot/Store19...Deck_2.2mm.PNG
The link I posted above shows what comes with the #368173 x brace.
To answer your questions, yes the spacer you need to raise the #361165 does come with the x brace. it also includes the silver spacers that make the x brace align properly with the front bulkhead.
Like others have mentioned, Xray really should have at least noted to anyone buying the 361168/9 that you need to also buy the 368173 to have all the necessary parts to use the chassis braces.
Freeski is offline   Reply With Quote
Old 07-17-2015, 11:56 AM   #8577
It comes in bag 9 where the misc parts are located. It is part #361184. It's the part that allows you to run to rear top deck and still have a hole for the body mount.
Old 07-19-2015, 08:22 AM   #8578
timannnn6's Avatar
Anyone thinking of getting the Spec-R swing axles, I highly DON'T recommend it. They snap at the inside thread easily. They seem to be too brittle. I'm a clean driver and downside every jump. Had TWO yesterday break. Landed our triple perfect, snap! The only reason I tried them was I had two stock ones break at the ball. And since they are completely out of stock everywhere, needed something as replacement.
The swing axle concept is awesome for this buggy and I do wish Hudy would look into making some quality items for this car as that's what it needs. It gets rid of all chatter when steering lock to lock and just takes the stress out of this area.
Just my .02
Old 07-19-2015, 10:56 AM   #8579
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Just my .02
Good to know they were going to be my nxt purchase. Ive also been considering the alloy hubs n spindles as ive broken a few and the two always go at the same time. Id rather change an arm then the hub n spindle. Anyone else run the alloy front hubs n spindles? Spec R spindles have been on back order for some time. I did run out of 9 d front hubs and went to the 6d and i kinda like it. . Had to turn dwn the dual rate for steering to control it better as it can be twitchy.
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 07-19-2015, 12:36 PM   #8580
tony montana's Avatar
Trader Rating: 65 (100%+)
What seems to be the popular setup for indoor as a good starting point. I did some practicing last weekend in stock form with the center diff and the car was decent. My diffs are 8k front 100k center and 8k rear. Was running saddles and it was planted. Thinking about trying the shorty . I was running a 44.3 and that car was just to aggressive. And this car is much more stable but need it to be a little more aggressive
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
