Like Tree52Likes
Old 07-04-2015, 02:03 PM   #8536
Originally Posted by SLOWINSLOWOUT View Post
Looking for a bit of gearing advice. I am running a 6.5T motor, on a fairly large track, 30-32sec lap times. I had it geared 18/81 and my motor was getting hot, 175-180f, with speedo temps of about 130f. (it was a hot day as well, 90-94f)
The speedo would go into reduced power due to the motor temp, had the limit set to 80C (176F). No boost or turbo set. (I have increased the temp limit for the motor to 120c (248f) so it will not shut down, but may fry the motor!)
Tomorrow is going to be even hotter, may hit 100f, not sure what way to go with the gearing, up or down? Thinking I should put a fan on it as well.
Any advice is welcomed! And by the way, the buggy is fantastic, I was only 1sec. off the fast guys pace, and this was the first time running off road in 20+years.
I run a 21t pinion on a 6.5 pretty much everywhere in mine, but that's on Astro tracks.
Never checked temps, but it'll happily run 10+ mins.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 07-04-2015, 03:25 PM   #8537
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Originally Posted by rcgod View Post
I run a 5.5 with 18 pinion and motor runs about 150. Could go either way in gearing. I've seen temps drop going up in pinion but not always. You could be under geared and spinning the motor too fast. What is the timing set at on the end bell? I would definitely run a fan on both esc and motor in hot temps. Also I know you've probably checked but make sure nothing is binding in the drive train.
Thanks for the input guys.
I just checked the motor on my motor checker, it is a new Tekin redline gen 2, I installed it out of the box. The timing was set to 10 on the can, which was 38 actual deg.s. One thing of note, this is the worst sensor board I have ever tested. With 9 deg phase variation. I set it to 0 on the can, 30 deg. actual timing, my Kv dropped 50, but amp draw went down almost 1 amp. This motor does not respond to timing very well.
The poor sensor board will account for some of the heat, and backing the timing down should help as well. I will put a fan on it just to be safe.
_____________________________________
Earl Towson
Team RC America - Xray USA - Hudy USA - Motiv RC - Max Power - Gravity RC - Prolevel RC - GRIPWORKS RC
WCICS.ca club rep. www.krcracing.ca
SLOWINSLOWOUT is online now   Reply With Quote
Old 07-04-2015, 09:24 PM   #8538
seth556's Avatar
Trader Rating: 42 (100%+)
I run an Orca 6.5t and it gets about 160f with 18/84 after a good bit of running. I'm sure if I turned down the timing a bit it'd cool down. Also with the '15 car and a shorty there's plenty of room for a fan when you run in super hot conditions. Your temps sound like Florida!
seth556 is offline   Reply With Quote
Old 07-06-2015, 07:37 PM   #8539
TPR 1's Avatar
Trader Rating: 26 (100%+)
Has anyone else tried the chassis braces instead of the top decks?
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Old 07-07-2015, 08:02 AM   #8540
RokleM's Avatar
Trader Rating: 33 (100%+)
All, I am looking for a large outdoor track, loose setup for my '14. Anyone have a suggestion?
- Eric G. -
Tekno EB48.4, NB48.4, ET48.3, NT48.3, EB410
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 07-07-2015, 08:35 AM   #8541
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
There is a good write up a few pages back..
MaricopaAgent is offline   Reply With Quote
Old 07-07-2015, 12:38 PM   #8542
Trader Rating: 22 (100%+)
just an fyi, discountrcstore now carries xb4 parts!
littleZEN is offline   Reply With Quote
Old 07-08-2015, 01:41 AM   #8543
HSV427's Avatar
Trader Rating: 22 (96%+)
Is anyone running the shelle 1.5/1.1 and the 1.6/1.1 shock pistons in there xb4, are they a worth while upgrade, and has anyone using them seen performance gains. Currently running on a medium size outdoor track with medium to high grip
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 07-08-2015, 01:54 AM   #8544
rcgod's Avatar
Originally Posted by HSV427 View Post
Is anyone running the shelle 1.5/1.1 and the 1.6/1.1 shock pistons in there xb4, are they a worth while upgrade, and has anyone using them seen performance gains. Currently running on a medium size outdoor track with medium to high grip.
I've tried the stock 3 hole for and rear, 3 hole rear and 2 hole front, and machined delrin 3 hole and I keep going back to the Schelle pistons. I usually run 35/27.5 to 40/32.5 depending on temp and traction.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 07-08-2015, 01:57 AM   #8545
HSV427's Avatar
Thanks for that ill give them a try.
Old 07-08-2015, 08:01 AM   #8546
pickle311's Avatar
Trader Rating: 31 (100%+)
Avids are better. They were actually tested where this guy just ripped off the specs after he left Avid.
Thanks to my sponsors and friends
RC America l Xray l Hudy | Pro-Line |KO Propo | Avid | VP Powermaster
pickle311 is offline   Reply With Quote
Old 07-08-2015, 10:57 AM   #8547
Trader Rating: 15 (100%+)
I was looking around at some older set ups and noticed Tyler Vik used the 6 degree front camber blocks at OCRC and other places, yet Martin Bayer is running 12 degree hubs, mostly for carpet, but also for testing at OCRC....anyone else running the 6 degree? What do you like about them vs. the stock 9 degree? Are the 12 degree really more for the added initial turn in on carpet?
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 07-08-2015, 07:03 PM   #8548
TV
The 12 degree blocks will be a little lazy off center but have smoother steering, and a little extra at the end of the turn. The 6 degree blocks will be twitchier and harder to drive, but will react better off center. That's the kind of feel I like personally, but I'd say it's up to you and one isn't really "better" than the other, it comes down to the driver. On something ridiculous like carpet though, where you have so much steering and grip already, the 12s will really smooth the car out and carry more corner speed.
XRay | RCAmerica | AKA | FX Engines | MotivRC | P1Hobbies.com | Sidewinder | Airtronics | UpGrade RC
TV is offline   Reply With Quote
Old 07-09-2015, 08:12 AM   #8549
RokleM's Avatar
Nobody?
- Eric G. -
Old 07-09-2015, 11:00 AM   #8550
HulkNT1's Avatar
Is anyone running toe out higher than stock which is 0 in the front and if u are which insert??
HulkNT1 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
