Like Tree39Likes
Old 06-29-2015, 04:37 PM   #8521
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Originally Posted by BentKa View Post
Yes they will be different heights due to the '15 not having the plastic "tub chassis" on top of the aluminum chassis.
Just clearance the plastic chassis and it should fit
Bent
Not only does it need the tub chassis removed .but it will need propper shimming . I used 3 on the backside of the diff and one towards the front. And you will need to cut the portion of the battery posts off n re install it .other than that it works grrrrrreat!!!!!
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 06-30-2015, 07:57 AM   #8522
hacker's Avatar
Trader Rating: 140 (100%+)
Default weight
for the 2015, what are peoples running weight?
trying to figure out if it's worth running in 17.5 stock class down here.
hacker is offline   Reply With Quote
Old 06-30-2015, 08:50 AM   #8523
suby723's Avatar
Trader Rating: 21 (100%+)
That depends on many variables. With a shorty it's 1700g ball park. Basically my 15spec was 80g lighter with same electrics compared to my 44.3.
suby723 is offline   Reply With Quote
Old 06-30-2015, 03:55 PM   #8524
HSV427's Avatar
Trader Rating: 21 (96%+)
Does any one now were this X-ray part is in stock Xray 361173, Rc-mushroom and discount-rc are both out off stock.
Serpent 977 35th anniversary. Serpent 977 evo2, Shepherd Velox, Motonica p81rs2, OS speed shimo edition.
HSV427 is offline   Reply With Quote
Old 06-30-2015, 05:10 PM   #8525
rcgod's Avatar
Trader Rating: 27 (100%+)
http://www.absolutehobbyz.com/XRAY-G..._p_505909.html
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 06-30-2015, 06:29 PM   #8526
MaricopaAgent's Avatar
17.5 is fun.. Mine was 1640ish with gear diffs and center slipper.
I run an aluminum heatsink and or a fan. 75/30-31 pinion with D4 SS..
I think you could drill some holes thru the slipper shafts, and the ball diffs if there was a serious race class.
MaricopaAgent is offline   Reply With Quote
Old 07-01-2015, 12:35 AM   #8527
TPR 1's Avatar
Trader Rating: 26 (100%+)
Does anyone know if you have to run part # 361173 if you want to remove the top decks and use part # 361169 ?
cheers
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Old 07-01-2015, 05:14 AM   #8528
HSV427's Avatar
cheers
I'm running #361169 without running #361173 the only problem is there is no were to mount body post on the front, so i just use the rear clip for the rear and velcro on the body in the front and theres no problem at all, i did how ever order the part just to see if it makes a difference just out of curiosity.
Old 07-01-2015, 05:29 AM   #8529
When using 361168 does it come with a spacer for the center diff plate that mounts over the center diff. Currently it uses the top deck as a spacer.
eddie10 is offline   Reply With Quote
Old 07-01-2015, 10:24 AM   #8530
361168 does not come with the spacer. That piece comes with the 361173 x-brace OR you could order that spacer separately as part #361172.
Freeski is offline   Reply With Quote
Old 07-01-2015, 04:36 PM   #8531
I'm going to try the good old link Friday.
discodom is offline   Reply With Quote
Old 07-02-2015, 05:06 AM   #8532
Trader Rating: 39 (98%+)
The chassis braces that you guys are talking about are they just for the '15 model?
Team associated sc5m
Team associated t5m
Hobby wing
Trinity
Futaba 4px
wheres_yogi is offline   Reply With Quote
Old 07-04-2015, 09:37 AM   #8533
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Looking for a bit of gearing advice. I am running a 6.5T motor, on a fairly large track, 30-32sec lap times. I had it geared 18/81 and my motor was getting hot, 175-180f, with speedo temps of about 130f. (it was a hot day as well, 90-94f)
The speedo would go into reduced power due to the motor temp, had the limit set to 80C (176F). No boost or turbo set. (I have increased the temp limit for the motor to 120c (248f) so it will not shut down, but may fry the motor!)
Tomorrow is going to be even hotter, may hit 100f, not sure what way to go with the gearing, up or down? Thinking I should put a fan on it as well.
Any advice is welcomed! And by the way, the buggy is fantastic, I was only 1sec. off the fast guys pace, and this was the first time running off road in 20+years.
_____________________________________
Earl Towson
Team RC America - Xray USA - Hudy USA - Motiv RC - Max Power - Gravity RC - Prolevel RC - GRIPWORKS RC
WCICS.ca club rep. www.krcracing.ca
SLOWINSLOWOUT is offline   Reply With Quote
Old 07-04-2015, 09:49 AM   #8534
rcgod's Avatar
I run a 5.5 with 18 pinion and motor runs about 150. Could go either way in gearing. I've seen temps drop going up in pinion but not always. You could be under geared and spinning the motor too fast. What is the timing set at on the end bell? I would definitely run a fan on both esc and motor in hot temps. Also I know you've probably checked but make sure nothing is binding in the drive train.
Dialed RC Hobbies
Old 07-04-2015, 10:12 AM   #8535
Trader Rating: 114 (100%+)
Default Practice laps on a fresh layout...
LRH Raceway
1412 N Hundley St
Anaheim, CA 92806
(714) 319-6720
XB4 & D413 trying out the new layout!
https://www.youtube.com/watch?v=pxm1t_iWhbo
winstonite is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Mikeyme84
