Like Tree52Likes
Old 06-17-2015, 04:54 AM   #8446
Originally Posted by HeavyD99 View Post
I was checking out the custom paint threads and noticed a lot of guys who run XB4's seem to run B5M's as their 2WD. I run one as well.
What is everyone else running for a 2WD?
I run a X-Factory UK X-6s on high grip astro turf & for the most part, it laps faster then the XB4
X-Factory X-6 Cubed when it rains or when racing on grass.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 06-17-2015, 07:56 AM   #8447
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Originally Posted by BigBrute_347 View Post
New to this class. What is a good starting point for gearing a 13.5? Seems like the cam adjuster might not allow pinions much larger than 23 tooth with the 81 tooth spur.
One car has a 75/30 with 17.5, fan and heatsink of course.
MaricopaAgent is offline   Reply With Quote
Old 06-17-2015, 10:24 AM   #8448
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Working on getting the buggy wired up. What size wire should I be using? Will be running 6.5T motor. I have started wiring with 12g, but it is tight, would 14g be OK in this application?
_____________________________________
Earl Towson
Team RC America - Xray USA - Hudy USA - Motiv RC - Max Power - Gravity RC - Prolevel RC - GRIPWORKS RC
WCICS.ca club rep. www.krcracing.ca
SLOWINSLOWOUT is offline   Reply With Quote
Old 06-17-2015, 10:38 AM   #8449
BentKa's Avatar
We run ORCA 13ga wires on the 4WD's using 5.5T with quite a bit of timing and boost with no issues.
Use 12g a for the 1/8 scale only.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 06-17-2015, 01:19 PM   #8450
BigBrute_347's Avatar
That's encouraging to know, should have no issue gearing for a 13.5 then. Thanks for the reply!
BigBrute_347 is offline   Reply With Quote
Old 06-18-2015, 01:39 AM   #8451
HSV427's Avatar
Trader Rating: 22 (96%+)
What pinion gear are people running when running a 13.5t motor on a medium size outdoor track.
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 06-18-2015, 06:56 AM   #8452
Took mine out with a 13.5 for the first time yesterday on a medium sized indoor track. The biggest pinion I could fit with the 81t spur center diff was a 27t. Felt like it needed more gear (motor temp 135) so the 78t spur is on the way.
Old 06-18-2015, 09:27 AM   #8453
Trader Rating: 15 (100%+)
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 06-18-2015, 09:52 AM   #8454
RC America's Avatar
The smallest XRAY spur for the slipper is a 75T. If using the center diff, the smallest available is a 78T.
- Bryan
RC America is offline   Reply With Quote
Old 06-18-2015, 04:30 PM   #8455
Trader Rating: 31 (100%+)
Originally Posted by shuless View Post
I run a Kyosho RB6 with the Zack Rogers setup. I have had every 2wd buggy except the Xray and I have never had one handle and drive better than this! I would however be interested in trying an Xray 2wd
I would assume the RB6 is incredible as I run my SC6 in mid motor on every type of track condition and the car is just perfa. Although many believe mid motor setups won't be kind on loose low bite conditions the Kyosho SC6 thrives.
Sorry I know this is the XB4 thread but I had to throw in my experience with my SC6.
However I will be purchasing the XB2 when released.
Norse is online now   Reply With Quote
Old 06-18-2015, 11:58 PM   #8456
HSV427's Avatar
Thanks for the replies, I'll try the 75t spur, what would be a good starting pinion for the 13.5. Thanks
Old 06-19-2015, 09:46 AM   #8457
pickle311's Avatar
For 2wd I'm running the Team C TC02 Evo and doing really well with the car, only running it indoors. Just waiting on the XB2.
Anyone running VRP Pistons in the XB4? If so, which ones? I'm thinking about trying them. I'm fighting the rear socks on my XB4 right now.
Indoor high bite track and the rear end just isn't stable at all. Running 2 dot springs front and rear, 1.3x3 pistons, 40f and 35r oils. Rear has as much droop and I can put in it. No internal limiters and shock ends and unscrewed 3mm.
Landing off of a jump on the downside and the rear end gets upset and wants to spin out. Any kind of bump and it's rebounding up hard and dancing. It seems more like a chassis kicker than just suspension rebound. What are you guys doing to settle down the rear end? It's a 14 spec BTW.
Thanks to my sponsors and friends
RC America l Xray l Hudy | Pro-Line |KO Propo | Avid | VP Powermaster
pickle311 is offline   Reply With Quote
Old 06-19-2015, 10:05 AM   #8458
rcgod's Avatar
I don't see xb4 specific pistons on the vision website. They pistons need to be thinner for the xb4 so using kyosho or Losi pistons won't work.
I've had good luck using Schelle or Avid pistons. Both fit the shock body much better than stock pistons and control the shocks better.
rcgod is offline   Reply With Quote
Old 06-19-2015, 09:27 PM   #8459
try 1 dot rear.. 3 dot front.
Old 06-20-2015, 07:23 AM   #8460
suby723's Avatar
Trader Rating: 21 (100%+)
Or ae red/yellow front springs and black rear.
suby723 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
chrisw
