Like Tree39Likes
Old 05-24-2015, 10:41 AM   #8326
GrandeGixxer's Avatar
That is a great deal! Over $100 less than I paid for mine less than a month ago. I don't regret it though.
GrandeGixxer is offline   Reply With Quote
Old 05-24-2015, 11:02 AM   #8327
Motorman007's Avatar
Trader Rating: 78 (100%+)
Originally Posted by rcgod View Post
If anyone is thinking about buying a 2015 car this is a great deal. Discountrcstore.com has then for 339 shipped with discount code. The code is on their website. Only good through tomorrow. Discount code is memday15.
They sold out fast
YOU WILL (ALWAYSWIN).....
Motorman007 is online now   Reply With Quote
Old 05-24-2015, 01:10 PM   #8328
BigBrute_347's Avatar
Amain puts the kit on sale for $20 off but then you can't use any of the promotions and the sale ends up more expensive. Wish I knew about Discount RC yesterday!
BigBrute_347 is offline   Reply With Quote
Old 05-24-2015, 10:35 PM   #8329
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I would have bought one just because, but discountrc sold out
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-24-2015, 11:45 PM   #8330
likea45's Avatar
Originally Posted by Motorman007 View Post
They sold out fast
They will be back in stock there in about a week. Same price.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 05-25-2015, 01:53 AM   #8331
Would the Kyosho rear wheels work with Xray's 12mm hexes?
Qrio is offline   Reply With Quote
Old 05-25-2015, 07:15 AM   #8332
Not with the 15% off
Old 05-25-2015, 07:39 PM   #8333
Trader Rating: 15 (100%+)
Just curious, what is everyone running for shock caps nowadays? Stock plastic, aluminum caps from Exoteck or Xray? I know Spec R have some as well as DHawk. My shocks squeak and it's either from air getting in the bottom, or a bad seal on top. I got rid of the Traxxas ones I tried and put my old stock ones back in, I have new ones ordered to replace the stock orings soon. I noticed the same squeak with my B5m and actually switching back to plastic caps was a better seal....does anyone know what Factory drivers run? I see some photos with stock plastic, but not sure....do they replace them a lot, the bleeder screw hole rounds out fairly easily if I remember.
...and for those helping me and my rear traction issue, thanks for the tips. I am going to try and run with my set up as is, but 100k in the center diff, 3 dot springs up front and hubs forward Wednesday night. Will report back on my findings, I hope for more traction. Major jump in temperature as well so the experiment will be under better conditions.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 05-25-2015, 08:35 PM   #8334
Mizchief's Avatar
Originally Posted by BigBrute_347 View Post
Is there a disadvantage to using the Xray wheels? Do most change to 12 mm hex due to availability?
I've had both my fronts crack and have heard others with the same problems. I prefer JC wheels as they seem to be the brightest whites but haven't ran them on the xray yet as I stocked up on xray sets when I bought it
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 05-26-2015, 04:51 AM   #8335
I'm still using the plastic ones that came in my 2013 kit, haven't changed one part on the shocks other then Pistons since I built them & don't have any problems with leaking or air getting in.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 05-26-2015, 07:23 AM   #8336
Trader Rating: 29 (100%+)
Original '13 plastics as well. I do run a bead of black grease on the threads though.
DustinEich is offline   Reply With Quote
Old 05-26-2015, 07:56 AM   #8337
rc_dude's Avatar
Trader Rating: 130 (100%+)
The JC wheels I have are a blueish white, the TRL wheels i have are greenish white. and AE and DE wheels are they only ones I've tried yet that are truly white.
My JC wheels also fit very tight to the JC hex's I have on my buggy, to wear i feel like in going to crack them or strip them due to having to use the wheel nut to get them all the way on.
Engineering is my passion.
Team Durango ET48.3, EB48SL, & DEX408v2
One of a kind vehicle in progress
rc_dude is offline   Reply With Quote
Old 05-26-2015, 09:30 AM   #8338
Trader Rating: 30 (100%+)
Hello Heavy,
I use Xray Aluminum shock caps. Thus I put a little Green Slime over the shock cap bushing as well around the shock barrel threads. In conjunction with RDRP orings I have no issues.
I am running 200K in my center diff and it is very very sweet, thus I am running on a hard packed but loose track. I find the 200k center perfect as you can drive aggressive and still control of the buggy. I would try 200K before dropping all the way down to 100K. Thats just my thoughts as I have found 200k to work primo compared to higher than and lower than 200K. I run my hubs forward as well and am running 3 dots up front.
Last edited by Norse; 05-26-2015 at 09:33 AM. Reason: Oh! I have seen some fellas running aluminum shock caps in conjunction with a little teflon tape around the top shock threads
Norse is offline   Reply With Quote
Old 05-26-2015, 05:06 PM   #8339
I only have 1M, 500k and 100k, but I have 200k and 300k coming in the mail. I'll only make a few changes at a time. To complicate matters, for the better, the temperature has gone from 55F to nearly 90F since last week!
Daragh Slowey
Old 05-27-2015, 03:40 AM   #8340
I run stock plastics on all 3 of my xb4's and only ever replaced one. My fault of course.
sirianni317 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
