Like Tree39Likes
Old 05-22-2015, 09:33 PM   #8311
rc_dude's Avatar
Trader Rating: 130 (100%+)
Originally Posted by MaricopaAgent View Post
Thanks, that'd be a no for 2015-2013
rc_dude is offline   Reply With Quote
Old 05-23-2015, 04:38 PM   #8312
GrandeGixxer's Avatar
Originally Posted by advpball View Post
I like the progressive springs,I feel the car stays planted better..i went to stock springs on same setup and was a little squirrely off some of the bigger jumps landings.
Thank you, anyone else?
GrandeGixxer is offline   Reply With Quote
Old 05-23-2015, 04:40 PM   #8313
rcgod's Avatar
Trader Rating: 27 (100%+)
There are plenty of guys that have used the progressive springs and posted their results. Try using the search function for this thread.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 05-23-2015, 08:33 PM   #8314
rc_dude's Avatar
What wheels are we suppose to use with 12mm hex's? Mainly need the fronts.
I've been using AE and JC wheels but the AE wheels don't have the outer bead and the JC wheels are a crazy tight fit on the hex's
TLR wheels work fine on the rear.
Old 05-24-2015, 05:53 AM   #8315
FrEaKiShTuNER's Avatar
Trader Rating: 200 (100%+)
I like to use the DE Borrego wheels for the DEX410. The fronts fit perfect. But the xrays rear axle is thicker than the 410. So I drill the hole out with a 13/64(.203) drill bit. One pass with the drill and everything works great.
~AdamQ~
**Lower feedback ships first**
FrEaKiShTuNER is offline   Reply With Quote
Old 05-24-2015, 07:08 AM   #8316
rc_dude's Avatar
I'm running 12mm hex's though
Old 05-24-2015, 07:15 AM   #8317
rcgod's Avatar
I use these with the 12mm hexes.
http://www.amain.com/rc-cars/kyosho-...391102?v=22396
Dialed RC Hobbies
Old 05-24-2015, 07:17 AM   #8318
Originally Posted by rcgod View Post
+1. I use the exact same wheels and they work great.
Freeski is offline   Reply With Quote
Old 05-24-2015, 07:41 AM   #8319
Yup, my bad..
I'll chalk that up to still being asleep when I responded..
~AdamQ~
Old 05-24-2015, 07:44 AM   #8320
MaricopaAgent's Avatar
Losi 22-4 Fronts are fine.. AE/Losi rears.
MaricopaAgent is offline   Reply With Quote
Old 05-24-2015, 07:51 AM   #8321
BigBrute_347's Avatar
Is there a disadvantage to using the Xray wheels? Do most change to 12 mm hex due to availability?
BigBrute_347 is offline   Reply With Quote
Old 05-24-2015, 08:34 AM   #8322
The only possible disadvantage to using the std wheels would if you find it hard to buy them, I swapped to 12mm hexes purely because I has lots of good tyres on 22-4 wheels & didn't want to bin them along with the TLR car.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 05-24-2015, 08:36 AM   #8323
Does anyone run the "progressive" springs? I bought all of the springs and was wondering what advantage the progressive springs have over the regular ones or when they would be better?
I tried the progressive springs when I first got the '13 car, I didn't like very much, I found they let the car roll a little too much before they stiffened up & on the high grip Astro tracks we have, that meant too much grip roll.
In the end I swapped to AE springs as there is more choice.
Old 05-24-2015, 09:33 AM   #8324
rcgod's Avatar
If anyone is thinking about buying a 2015 car this is a great deal. Discountrcstore.com has then for 339 shipped with discount code. The code is on their website. Only good through tomorrow. Discount code is memday15.
Dialed RC Hobbies
Old 05-24-2015, 10:15 AM   #8325
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Great deal, just picked one up. Thank you, have been eyeing the XB4 for a while.
Dan is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
