Like Tree36Likes
Old 05-21-2015, 02:13 PM   #8296
rc_dude's Avatar
Trader Rating: 130 (100%+)
Hey guys, I need to replace the rear axle carrier on my 2013 XB4, are they the same as the 2015?
Is there a way to find the 2013 manual online? I cant find it...
rc_dude is offline   Reply With Quote
Old 05-21-2015, 03:49 PM   #8297
jmkalt's Avatar
http://www.petitrc.com/setup/xray/se...XB4_Manual.pdf
jmkalt is offline   Reply With Quote
Old 05-21-2015, 04:24 PM   #8298
Trader Rating: 22 (100%+)
They should be. The part numbers are the same on both manuals. The 2015 one is slightly beefier.
littleZEN is offline   Reply With Quote
Old 05-21-2015, 07:12 PM   #8299
rc_dude's Avatar
Awesome! Thanks guys!
Engineering is my passion.
Team Durango DEX408T & DEX408v2
One of a kind vehicle in progress
-Needing a machinist to make a couple parts.
Old 05-21-2015, 08:22 PM   #8300
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Rear Hubs? New ones are updated some.
https://www.facebook.com/RcKleinKram...type=1&theater
MaricopaAgent is offline   Reply With Quote
Old 05-21-2015, 08:47 PM   #8301
rc_dude's Avatar
Wow, that's a small difference though
Old 05-21-2015, 09:35 PM   #8302
rc_dude's Avatar
Does anyone know if the 2015 slipper set fits a 2013?
The screw holding that whole assembly together is stripped and have to rebuild the whole thing
Old 05-22-2015, 08:06 AM   #8303
no..
https://www.facebook.com/2015XB4/pho...type=3&theater
Old 05-22-2015, 03:08 PM   #8304
HulkNT1's Avatar
I need help here please. I just finish my XB4 2015 car and I am using Team Orion ESC and Motor sensor and the motor is running reverse.. I was thinking can I just flip the rear and front diff and leave the motor how it is and the car will run forward by doing that?
HulkNT1 is offline   Reply With Quote
Old 05-22-2015, 03:15 PM   #8305
Simpelt answer, yes.
If you look in the manual , they are switch if you run motor front compaired to rear
Xray T4 2014 / Orca VXX / Orca 5t
Team Xray-shop.dk
johnsen-dk is offline   Reply With Quote
Old 05-22-2015, 03:37 PM   #8306
HulkNT1's Avatar
Thank you
Old 05-22-2015, 03:43 PM   #8307
HulkNT1's Avatar
ok another question when I try doing the the motor mesh with the spur gear on the motor mount the motor will need to rotate and then tighten the screw down but when I do that the mesh is too tight. can anyone put up a pic focusing on the gear mesh like that I can see how you did it. It in the book it looks simple. I rotated ontil it lock and then I screw down the screw but it is too tight..
Old 05-22-2015, 04:59 PM   #8308
GrandeGixxer's Avatar
Does anyone run the "progressive" springs? I bought all of the springs and was wondering what advantage the progressive springs have over the regular ones or when they would be better?
GrandeGixxer is online now   Reply With Quote
Old 05-22-2015, 06:35 PM   #8309
suzukipro's Avatar
Trader Rating: 21 (100%+)
I keep the mesh a bit looser than I want it and it closes up when you tighten the screw. It wil probably take a few attempts at it to get it right / to your liking.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 05-22-2015, 07:15 PM   #8310
advpball's Avatar
I like the progressive springs,I feel the car stays planted better..i went to stock springs on same setup and was a little squirrely off some of the bigger jumps landings.
tekno sct-410.3,xray xb2 de and xsc2?
eb 48.3 for sale artr 600
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
aspiringracer
