Like Tree38Likes
Old 05-12-2015, 11:07 AM   #8236
spu83's Avatar
$10/ arm only matters when it break.
Pak Lee
XB8E, XB4'15, 410.3, T4'16, XB2de, X1'16, XT2de
spu83 is offline   Reply With Quote
Old 05-12-2015, 11:17 AM   #8237
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I have seen a few broken front arms on the xb4. It is not immune.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-12-2015, 11:18 AM   #8238
Originally Posted by jmcelroy42 View Post
Have you actually had an issue with the composite gears? Or just not like that they are composite?
Yup, 2 race days, shredded the composite pinion, replaced it. Next race day, had to do it all over again. Found out if you replace one, replace them both. There was an issue with one tooth on the ring gear of rear diff, so replaced them both again.
Originally Posted by Motorman007 View Post
The plastic gears are for the birds why even put them in the kit then make you buy the metal gears.
Thanx again for your input
the 15' comes with the metal gears
The nice thing I liked about the xb4, was 4 screws, and your diff is out. real easy access.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 05-12-2015, 08:20 PM   #8239
Driven XB4 '14, D413 and B44.1
XB4 is by far my favourite. I've yet to put my ZX6 on the track so can't comment on that but the XB4 is well thought out. I have the steel diff crown + pinion in mine now so I'm a little less fussed about the slipper settings. With the steel gears, I drive my XB4 as hard as my D413, but the 413 still has a different driving style from the XB4 '14 because of the centre diff. XB4 has awesome parts availability in Hong Kong too!
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 05-12-2015, 09:34 PM   #8240
likea45's Avatar
I will spare everyone. Sir no more talking about the Pro and cons here.
Thank you for your time
It's true that a fast guy with most any car can still be fast. But I will say that a nicely built and thought out kit can make a decent driver, faster. Period.
Ive owned quite a few wheelers but the xb4 works best with my driving style. Parts can be expensive but the Kyosho cars are even more to start out and parts are almost just as much. I'm not sure how expensive HB parts are but the DEX410 was a nightmare to work on and I've heard it compared to that car in terms of maintenance. I'll never own the d413 as a result.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 05-12-2015, 09:47 PM   #8241
bd581's Avatar
Sure parts can be expensive, sure parts will still break. But if something is twice the price and you break half as many, it's not really more expensive is it?
Brad
Xray T4 '16, Xray X1, Tamiya M05 Ver.II Pro.
X-ray XB4 '16, TLR 22 3.0, TLR/Exotek 22T 2.0, Mugen MBX7R Eco.
bd581 is offline   Reply With Quote
Old 05-13-2015, 06:20 AM   #8242
Has anyone used the RB Products ADS in their XB4? if so, how did you like it, what were the results?
Old 05-13-2015, 07:32 AM   #8243
rcgod's Avatar
Trader Rating: 27 (100%+)
Parts are expensive if you buy from a hobby shop. I buy most from eBay. Just picked up new front and rear shock towers for $25 shipped out of a 2015 kit.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 05-13-2015, 07:46 AM   #8244
I try to do the same
Old 05-13-2015, 10:36 AM   #8245
Trader Rating: 29 (100%+)
Plus you finish races... I am sitting on a boat load of parts that I rarely ever need. Picked the habit of hoarding parts from my b44 days.
DustinEich is offline   Reply With Quote
Old 05-13-2015, 10:58 PM   #8246
I don't own a xb4 but what size are the pins for the driveshaft? I would like to get one later this summer
Rckid19 is offline   Reply With Quote
Old 05-14-2015, 05:17 AM   #8247
Trader Rating: 15 (100%+)
+1
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 05-14-2015, 05:26 AM   #8248
GrandeGixxer's Avatar
First race night with the XB4 last night and it was the most fun I've had racing in a while. The car worked good but was a little loose in the rear on power. I had the motor turned down quite a bit, 50% at the beginning of the night and 70% at the end. The car and I both improved throughout the night and I got to within about a second per lap from the fast guys. A couple more weeks and I should be dialed in and competitive. How does everyone go about setting their slipper? I was thinking about when the slipper pads wear out to just get the gear diff since the replacement slipper pads are so expensive. But for now I'd like to get the slipper dialed in.
GrandeGixxer is offline   Reply With Quote
Old 05-14-2015, 02:41 PM   #8249
TV
Set it the same way you would with a 2wd. Hold both rear tires on the pit table, and punch it. The front tires should only lift off the ground a little bit, and you should hear the slipper whine plenty.
XRay | RCAmerica | AKA | FX Engines | MotivRC | P1Hobbies.com | Sidewinder | Airtronics | UpGrade RC
TV is offline   Reply With Quote
Old 05-14-2015, 02:54 PM   #8250
Cool, thanks!
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
