Like Tree39Likes
Old 12-29-2012, 08:39 PM   #811
Autocratic's Avatar
Trader Rating: 26 (100%+)
Originally Posted by ps71 View Post
The front has a got 2 or 3 dots
Front: 2 dot 0,65.........3 dot 0,72
Progresive 0,65-0,85 2 stripes
Rear: 1dot 0,35.....2dot 0,40.......3dot 0,45
Progresive 0,35-0,45 2 stripes
So what exact number in lb/in are the kit springs?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 12-29-2012, 11:27 PM   #812
3.66 front
2.25 rear
This is according to arno buggy spring chart
Sponsers: Schumacher, Santiam Hobbies, Fantom Racing, Racing-cars.com, Flawless RC, Discountrcstore.com
Theroc is offline   Reply With Quote
Old 12-29-2012, 11:34 PM   #813
I think the stock shocks leak. I would bleed them with 0 rebound and wait hour or so and check again and they had rebound. So I ended up just putting my spare Rb6 shocks on the xb4.
Old 12-30-2012, 12:46 AM   #814
RShockley's Avatar
Default Shimming the diff?
Has anyone tried shimming the diff before you ever ran the car. I was think about doing it before running mine for the first time Friday. I was planning on putting the nt1 gears in anyways. The only thing that could happens is I still damage the gears. Just putting a 0.1mm shim behind the gears right?
Richard Shockley
Kyosho RB6 / Kyosho RT5
Mike's Hobby Shop......Carrollton, TX
Kalgard / Epic Cameras / SMX Optics / Heavenly Hobbies
RShockley is offline   Reply With Quote
Old 12-30-2012, 01:31 AM   #815
DZM
DZM's Avatar
Default shocks
After 1.30h run No problem for shocks leak.I use Granville Black Silicon Sealant.
Xray XB4 thread-cam_0695.jpg   Xray XB4 thread-cam_0696.jpg   Xray XB4 thread-cam_0703.jpg
DZM is offline   Reply With Quote
Old 12-30-2012, 01:44 AM   #816
silvalis's Avatar
Trader Rating: 29 (100%+)
is anyone making metal shock towers?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 12-30-2012, 03:25 AM   #817
cyba888's Avatar
setup sheet says -2 downstop... how you measure this? Thanks!
cyba888 is offline   Reply With Quote
Old 12-30-2012, 04:59 AM   #818
rraden's Avatar
Trader Rating: 231 (100%+)
That means there are two black washers on the shock shaft inside of the shock body. This shortens the total shock travel thus limiting the down travel of the arms.
rraden is offline   Reply With Quote
Old 12-30-2012, 05:00 AM   #819
rraden's Avatar
I shimmed mine that exact way. Without the shim there was a lot of side to side play in the diff case. Too much for me to ignore.
Old 12-30-2012, 06:28 AM   #820
Oli
Just to clear something up - have people had issues with the diff gears themselves breaking (the sun and satellite gears) or the ring and pinion gear?
From my understanding, it's the diff gears themselves, but XRAY included a spare set of pinion and ring gears in the kit...
Oli is offline   Reply With Quote
Old 12-30-2012, 07:05 AM   #821
cyba888's Avatar
Thank you
Old 12-30-2012, 09:23 AM   #822
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
I seen 2 of these cars in action last night at my local track and they look amazingly good, they look more composed than any other car on the market....cant wait to see Josh run his!
Let Xray sift through these problems and address them, this car looks crazy good on indoor medium bite/partial clay track!
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 12-30-2012, 10:44 AM   #823
jamiekerr14's Avatar
Anyone tried some JB weld or metal Epoxy on the front bulkhead yet. Had a 2nd crack today.. Mind you it did have a few heavy hits! so not too surprised, Just wondering how to try and add some strength to the case. Any engineer chaps have a good idea how/where to put the putty inside corner/outside ect?
Xray XB4
Supported By:
RC Disco
jamiekerr14 is offline   Reply With Quote
Old 12-30-2012, 11:53 AM   #824
RShockley's Avatar
0.1 shim behind each of the satellite gears correct?
Richard Shockley
Old 12-30-2012, 12:38 PM   #825
sickpuppy1's Avatar
Trader Rating: 25 (100%+)
Your gears on the ends,(sun gears) to push them in and take out slack between them and the planetary gears, If I remember correctly.
If you cant fix it with a hammer, you have an electrical problem...
TeknoSCT410,Losi 22 2.0 & Eight-B 2.0,Losi LST2 , losi LXT circa 1990, it's a runner!
sickpuppy1 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
