Like Tree52Likes
Old 05-03-2015, 10:26 PM   #8146
likea45's Avatar
I'm running a 5.5t on our medium size track. I enjoy the power but I'm not full bore on the throttle. To each their own, if the driver can handle it the motor is fine.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 05-04-2015, 05:56 AM   #8147
Originally Posted by DIRT DIGGER View Post
Did a quick search? U need to get a life!
Just trying to help you out dude.
3DRCRACER is offline   Reply With Quote
Old 05-04-2015, 02:42 PM   #8148
Trader Rating: 38 (100%+)
Default less motor.
Originally Posted by tony montana View Post
Yeah if he is running the 5.5 that is the issue like you said. I run a 6.5 and have my epa set at 85 percent. Unless you run a whole qualifier with zero mistakes then that motor isn't gonna help you. Guys have to realize they would be faster with less motor.
I am the perfect example of less motor I am faster. I had a 5.5. Way too fast. Put an 8.5 in it. Much smoother. One thing I also learned. Tires are 95% of the whole setup.
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 05-04-2015, 06:48 PM   #8149
Mizchief's Avatar
So much snippyness lately starting to look like an AE thread.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 05-04-2015, 07:37 PM   #8150
coming from tc 17.5 i was used to mashing the throttle often with little consequences,now on my buggy even with a 7.5 i have had to learn self control with index finger.Now that I am getting better with throttle control I am finding my lap times have dropped considerably and consistency has gone up. All with very few changes to my setup.
When seeking advice,people should be willing to accept constructive criticism,even if it isn't what you wanted to hear...no room for snippy
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 05-04-2015, 08:21 PM   #8151
rc_dude's Avatar
Trader Rating: 130 (100%+)
Hey guys, what are you guys running as far as motor and ESC? I ran a speed passion reventon pro 1.1 and 8.5R at a larger track this weekend and didn't make it a single heat without thermal shutdown. I have holes in the body, fans on the ESC and motor, and now ordered a heat sink for the motor but it seems a bit ridiculous. I was geared so the motor topped out right before the end of the front stretch with 5 degrees timing. Nothing is binding or anything and all the bearings/shafts are good.
I'm debating putting an 550 motor in it if this continues.
Engineering is my passion.
Team Durango ET48.3, EB48SL, & DEX408v2
One of a kind vehicle in progress
rc_dude is offline   Reply With Quote
Old 05-04-2015, 08:34 PM   #8152
TPR 1's Avatar
Trader Rating: 26 (100%+)
What pinion/spur r u running? sounds like you might have to go down with your pinion size other than that your 8.5
could need replacing!
Im using a hw 120 amp esc with a novak 6.5 motor 19 tooth pinion with kit spur gear never ever had a problem.
-Adelaide RC -
-Game On
TPR 1 is online now   Reply With Quote
Old 05-04-2015, 08:38 PM   #8153
bd581's Avatar
I would double check that your thermal cut off isn't set too low by accident (done it myself)
Brad
Xray T4 '16, Xray X1, Tamiya M05 Ver.II Pro.
X-ray XB4 '16, TLR 22 3.0, TLR/Exotek 22T 2.0, Mugen MBX7R Eco.
bd581 is offline   Reply With Quote
Old 05-04-2015, 09:29 PM   #8154
rc_dude's Avatar
I'm not sure what spur gear but it's the largest I have and then pinion is a 25T. It was a fairly tall gear but it had to get keep it up to speed around the large track.
it's set at 95 C. That's the only setting my ESC allows other than off.
Old 05-04-2015, 09:54 PM   #8155
Trader Rating: 15 (100%+)
The stock 81T spur should be fine for most tracks, even large ones with 20+ second lap times. This goes against everything said above, but maybe you need more motor. It also sounds like your thermal setting may be a bit off, check that as well. I run a 6.5T geared at 81/19 in blinky mode on a large track as well and I am not hurting for speed. Depending on how many times you've thermal'd, your motor may be toast.
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 05-04-2015, 10:03 PM   #8156
can someone post a link to the front support for the shock tower that reinforces the top of diff case,cant find one in the states.
ResultsRC is offline   Reply With Quote
Old 05-04-2015, 10:21 PM   #8157
Trader Rating: 31 (100%+)
I agree with TPR as your pinion gear may need to drop a tad or your motor could be laid out. Hope it's just your pinion needing a down size.
I run a Novak 6.5 with the Novak Pulse V2 and am running the 81t spur with a 20t pinion with no issues. I also run a 19t pinion with the 81t spur and have no issues.
Have an excellent week my friend.
Norse is online now   Reply With Quote
Old 05-04-2015, 10:31 PM   #8158
suby723's Avatar
Trader Rating: 21 (100%+)
That's exactly what I'm doing and same gearing. 6.5 with an Orion r10pro set in blinky mode. I never get out throttled and my temps stay very low.
suby723 is offline   Reply With Quote
Old 05-04-2015, 10:47 PM   #8159
rc_dude's Avatar
Ok guys. Yea i've got a 7.5R motor on the way and I ran a 7.0T Reedy motor in my DEX410 last summer no problem. The 8.5 is out of my 2WD buggy and the motor never got above 158 from what I saw but could have gotten up around 170 but from monitoring cool down temps the ESC was always hotten and cooled down faster so the motor should be good and it still runs perfect, but I guess we'll see.
I'm hoping having the fan blow on a heat sink on the motor will help a bit as well as shims between the fan and ESC as well as lower gearing.
Mainly seems odd because the night before (10 degrees cooler weather) the motor ran fine with a 23T pinion and 18 degrees timing.
Old 05-05-2015, 06:48 AM   #8160
Rc dude, you'd know if the motor was melted, it would stink like nothing you've ever smelled before, but heat hurts and it would feel soft. It's much more obvious in a 4wd vs. a 2wd, due to the weight and drag. Anyhow, drop the 7.5 in it with a 23 tooth pinion and see how it goes.
Daragh Slowey
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
