Like Tree39Likes
Old 04-25-2015, 04:31 PM   #8086
Trader Rating: 30 (100%+)
Originally Posted by HeavyD99 View Post
What are you guys using for chassis protection? Does anyone make '15 specific protective chassis sheet?
Heavy,
JConcepts makes a 2 pack of clear chassis protectors. Thus you have to trim to fit but there nice. Playmore's chassis protector I ordered for the 15 XB4 ended up being for the 14 as it to narrow. Hoping the get their protectors made for the 15 soon as the are really nice.
Have a great rest of your weekend my friend
Last edited by Norse; 04-25-2015 at 04:43 PM. Reason: I believe they are under $9 for a pack of two.
Norse is offline   Reply With Quote
Old 04-25-2015, 04:43 PM   #8087
How many mm back from the rear shock tower are XB4 owners setting the wing, or has any one run thier rear wing snug against the back of the shock tower. Track I running tom. is loose dirt but very packed when running the inner lines.
Have an excellent rest of your weekend
41BB66E5-5BFD-4982-A5D9-61EB3E9CAE42
, t
Old 04-25-2015, 04:48 PM   #8088
Originally Posted by JEFF.777 View Post
Whats the front x brace???
sAlso how many bevels would i need?
And im wanting to do saddle so please someone help because that doesnt help at all..
It stiffens up the front of the chassis decreasing chassis flex and is installed above the steering rack. I think it is intended for super high bite conditions.
Old 04-25-2015, 07:04 PM   #8089
theclutch's Avatar
@jmackani,
If I were to build my 2013 into a 2015 today, my parts list would have been simpler than what I ended up doing.
I'd build it in shorty configuration as follows:
3mm aluminum chassis
Carbon fiber front X brace
Side guards
95mm center rear dog bone (use your 2014 88mm bone for the front)
Steel 35T bevels and 14T pinion gears
Center diff
Carbon fiber center top plate
Shorty battery brace
2015 ESC mount
2015 motor mount
2015 composite motor mount
2015 center chassis stiffeners
There are some spacers and small bits etc that I'm probably missing to complete the full conversion, but knowing what I know now, this is how I'd do it. I actually bought all the top decks and the standard 2mm chassis and all the bits through that online auction site, so I did not spend top dollar. I've built it up this weekend finally, but still have not raced it. Still might get the 3mm chassis, but since I race on clay during the summer I will wait to see if it is the way to go or not.
D.
You wouldn't happen to know the exact part numbers do you? Some of them are easy enough to figure out. But some have multiple versions that it gets confusing...
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 04-25-2015, 08:11 PM   #8090
jmackani's Avatar
Trader Rating: 14 (100%+)
Xray XB4 thread
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 04-25-2015, 08:11 PM   #8091
bd581's Avatar
Download the '15 spec manual. Cross check with that.
It's all anyone else would do to answer your question.
Brad
Xray T4 '16, Xray X1, Tamiya M05 Ver.II Pro.
X-ray XB4 '16, TLR 22 3.0, TLR/Exotek 22T 2.0, Mugen MBX7R Eco.
bd581 is offline   Reply With Quote
Old 04-25-2015, 08:37 PM   #8092
Trader Rating: 15 (100%+)
Thank you bd581.
(Sigh)...If you go to the Xray site and look in the downloads for the XB4'15, in the exploded diagram view, you can see right there what you need, like I did. You guys gotta stop asking for part numbers, stop being so lazy, go figure it out.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 04-25-2015, 09:43 PM   #8093
JEFF.777's Avatar
Meant the part number.. Couldn't find anything called the x brace on amain..
JEFF.777 is offline   Reply With Quote
Old 04-25-2015, 09:44 PM   #8094
JEFF.777's Avatar
Originally Posted by jmackani View Post
No one needed the 2014 to 2015
Old 04-26-2015, 06:49 AM   #8095
suzukipro's Avatar
Trader Rating: 22 (100%+)
Good luck tomorrow. I think your fix will get you through the day. Have a great night my friend.
Good news! The top deck repair job held up and is still intact after a day of racing. I'm tempted to leave it on until it fails and then install the new replacement, but I'll likely swap it out and hang on to it as a spare.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 04-26-2015, 10:28 AM   #8096
Default traction roll misery
I just reconfigured my '15 car from dirt to carpet.
I used this setup http://www.petitrc.com/setup/xray/se...els2015032729/ and added all of the option parts except the rear aluminum hubs.
The problem I am having now though is horrible traction roll.
I have clipped the outer pins on both the front and rear tires and the inner ones on the front like the setup page shows in the pics at the bottom.
However the car still tries to roll on almost any turn. The rear outside tire comes off the ground and if I don't hit the brakes, over she goes.
If I knew that this was just a driver issue and that everyone was having the issue I'd just deal with it but one guy at the track running a ZX can fly through the corner never appearing to lift.
I have turned down steering rate, steering servo speed, tried with, and without drag brake, and everything else I can think of.
Is there anything you guys can suggest that I try?
Slippery Dan is offline   Reply With Quote
Old 04-26-2015, 10:34 AM   #8097
rcgod's Avatar
Trader Rating: 27 (100%+)
Run a front sway bar and widen the car. I would start with a 1.6 front bar and go from there. No front bar and low roll center will be a lot of roll in the front and inside rear will come off the ground. You can raise the front roll center to get the car flatter in the front but it might be too twitchy.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 04-26-2015, 10:53 AM   #8098
Originally Posted by advpball View Post
What besides the stock body fit the 2015? What's everyone running?
Small indoor track 50 ft straight and tight.
has anyone ran the dmx body? curious how it is
DIRT DIGGER is offline   Reply With Quote
Old 04-26-2015, 11:14 AM   #8099
rcgod's Avatar
I ran the DMX body on my 2014 with saddles. I don't think it will work with shorty configuration though.
Dialed RC Hobbies
Old 04-26-2015, 12:23 PM   #8100
tony montana's Avatar
Trader Rating: 65 (100%+)
Someone have a link to the adapters that will make the car use 44.3 wheels front and rear. Thanks
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
