Like Tree52Likes
Old 12-29-2012, 09:12 AM   #796
ps71's Avatar
People are used to the durango ones that pop if you look to hard at them...
IMO the ball cup should not pop off...
We have 4 xray at our track and the this is the list of broken parts.
2 front bulkheads
1 rear tower (not glued)
1 rear arm
1 set internal diffgears (rear)
1 ballcup
Not a lot of stuff when you look at how mutch they have been used.
So i think the car holds up quite well
Losi 22 2.0 xerun 120a v3.1 6.5t
Xray xb9e w/tekin rx8 gen2 1900kv t8
Spectrum dx3s
ps71 is offline   Reply With Quote
Old 12-29-2012, 09:36 AM   #797
t8rtot's Avatar
Trader Rating: 14 (94%+)
Face palm, gluing shock towers won't stop them from breaking. It stops them from fraying
Sfida
t8rtot is offline   Reply With Quote
Old 12-29-2012, 10:09 AM   #798
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by dennisV View Post
Indeed CNC. I won't make it from delrin, Delrin is quite a hard material.
You can also take your original tower, draw it on lexan and cut it with a dremel. Should work too.
Yeah delrin is a bit harder but I thought I could buy the material in a thickness similar to the original 3mm shock towers so thats why.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-29-2012, 10:29 AM   #799
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by ps71 View Post
Front: 1dot 0,65.........2 dot 0,72
Progresive 0,65-0,85 2 stripes
Rear: 1dot 0,35.....2dot 0,40.......3dot 0,45
Progresive 0,35-0,45 2 stripes
The manual doesn't show a one dot front but it does show a three dot front. Please advise. I found it slightly disturbing when the shock shaft wobbles like a drunken sailor. Anyone else notice that ? Durangos wobble, Kyoshos and Losis don't (quick check of vehicles within reach). I won't run mine till tomorrow, I sure hope they don't leak like sieves. Good thing I'll be running the Kyosho as well and have a spare set of big bores I can try on the xb4.
One thing that concerned me when looking at the manual before I got the car was the slipper adjuster but after building I like it. As someone just said a bench test even at the looser of the recommended setting seems a bit tight and it may be fine after break in but with the gear issue in mind I 'll start with a very loose slipper.
With a new car I'll just make some casual laps checking trims etc and just driving around and NOT worry about how "fast" it is or whatever. Spend a whole pack never going full blast, stopping every 5-10 laps to check and set things, 10-15 minutes.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 12-29-2012, 12:56 PM   #800
OleC's Avatar
Make sure you adjust the slipper to the updated setting", 5.8-6.3mm I belive?
I have had no problem with shocks leaking on mine.
I did make quite a fuzz regarding shimming of the diffs (crown and pinion) a while back. Even got the attention of Xray employees
I choose to leave the shims in there, and my gears are still in great shape. I do not buy the argument of plastic gears expanding as much as they would have to in order to get perfect mesh, in my car at least. And after replacing the front bulkehad, the same shiming was needed there as well...
Not saying you all should run an shim your gears, but I just want to share my experience so far
I also broke a rear tower at the top. This tower was not sanded and glued. As someone stated here, you dont sand and glue for strength. And I agree.
However, with edges rounded I belive there is less chance of snagging, which I belive broke my rear tower.
JQ The Car Black Edition - O.S. - BUKU - AKA - Byron - Sanwa - Sav÷x
No sponsors. I drive what I like, and so should you
OleC is offline   Reply With Quote
Old 12-29-2012, 01:07 PM   #801
ps71's Avatar
The front has a got 2 or 3 dots
Front: 2 dot 0,65.........3 dot 0,72
Spectrum dx3s
Old 12-29-2012, 01:29 PM   #802
Default Shock diameter
Can anyone tell me what diameter shocks this car has?
Stevenkoiter is offline   Reply With Quote
Old 12-29-2012, 03:12 PM   #803
asc6000's Avatar
the threaded portion of the bodies has an exterior diameter of 14.50mm , spring inner diameter 15.75mm
Ayrton Senna
Old 12-29-2012, 04:34 PM   #804
Just finished my build. Kit went together good. Ive built quite a bit of kits and put this kit almost as good as my Kyoshos.
The shocks are def NOT on the same level as the velvets. I did have few screws that where bent or not hexed correctly (also had a ball end with no hex).
Fit and finish on the plastic was A+. Ill get to test a little tomorrow. I owned both a zx5 and a 44.2 so Ill give a little insite.
Rocky
Sponsers: Schumacher, Santiam Hobbies, Fantom Racing, Racing-cars.com, Flawless RC, Discountrcstore.com
Theroc is offline   Reply With Quote
Old 12-29-2012, 05:31 PM   #805
ChrisP's Avatar
I know that XRAY has been working hard on addressing some of the issues that have popped up since the kits went into full release.
For those complaining about the lack of response, please consider that it is the Holiday season and many if not all of them are off spending time with their families (as most of us also have time off from our jobs to do the same)...
Even so, I know that there has been correspondence and that they have been looking into the issues.
ChrisP is online now   Reply With Quote
Old 12-29-2012, 06:07 PM   #806
Rampokker's Avatar
Just about ready to go! Electronics done, and old 78t AE spur fitted.
Just need wing and body now.
XRAY XB8 - Keep Off 21-4
XRAY XT9 - Elite 8 Off
XRAY XB4 - Tekin RS Pro / Fantom 6.5
Rampokker is offline   Reply With Quote
Old 12-29-2012, 06:14 PM   #807
Oli
Wink
Thanks for the update Chris.
I believe this will give everyone a little confidence that xray are looking into some of the minor issues the car has. I think the main things are;
The thickness of the shock tower material/ amount of material around where the ball stud joins.
The strength of the bulkheads around the stock tower mounting area (these two need to be considered hand in hand as thickening up the towers will put more stress on the diff casing in a crash).
The shimming/ size/ material of the diffs gears.
I haven't even built my kit yet, let alone run it, but I'd say the issues seem to be fairly minor, but something xray should try and address with some running parts updates. All in all, all owners seem to be over the moon with their cars.
Oli is offline   Reply With Quote
Old 12-29-2012, 06:26 PM   #808
ChrisP's Avatar
I'm sorry I didn't see this thread and post anything sooner....been traveling the countryside with my wife and 2 small children, battling colds and flu to fulfill family obligations over the Holidays...frankly...if I was feeling better I'd be at the track today even, but so far I'm doing good just to make it to the PC.
Old 12-29-2012, 08:00 PM   #809
Has anyone got a starting point for a pinon on the XB4 when I run a 7.5 in it?
Thanks for your help.
XRAY T14
www.wingsoverthedowns.com.au
PHI2 is offline   Reply With Quote
Old 12-29-2012, 08:16 PM   #810
Autocratic's Avatar
Trader Rating: 26 (100%+)
I'm happy with a 20 on mine.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
miranmotorports
