Like Tree36Likes
Old 04-22-2015, 07:06 PM   #8041
Trader Rating: 30 (100%+)
Quick Question in using the new 4 hole aluminum steering plate.
What is a good starting point regarding suggested mm b. steer under the ball studs. The kit plate looks to have lower hanging base point for the ball studs. I was thinking possibly adding an additional 2mm shim with the 2mm c. washer thus topping out at 4mm.
As always any suggestions is greatly appreciated
Norse is offline   Reply With Quote
Old 04-22-2015, 07:30 PM   #8042
Boz
Trader Rating: 23 (100%+)
I used a 4mm spacers on the weekend. I think factory driver are using either 4-5mm of spacing.
I'm surprised how different the holes are on the new plate. Not one hole lines up to the standard kit one.
ps I have sent Xray an email questing an updated XB4 setup sheet(v5) so we can record the new ancherman position and include the a spot to record spacers used on the new alum rear hub.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 04-22-2015, 07:32 PM   #8043
Originally Posted by GregerL View Post
The back side is not flush, so it is adapted for stock geometry without the roll center brace. I find that with the new towers there is very little or no need for the roll center brace, so it will do its job without it.
For the rear it won't work, unless maybe if you run the shock tower in the rear position.
/Greger
looking at where the rear diff case breaks,it is the plastic that is very thin where the screw comes through the ears of the tower shock tower mount,if I make a support that goes up and over the 4 screws that hold the mount and came down to a 90 degree bend tab and was screwed over top of the rear chassis support with the those 2 screws,it would secure it to a much thicker piece of case.
Using the shock tower mount in the rear still leaves nothing but the shock tower bolts to screw to,this whole area is very weak.
Asfar as the front just noticed the brace i have doesnt connect to the last row of bolts,but does connect to the inside camber link screws,not sure what good that does,can someone post a link to a site in the usa that sells this type brace and the shelle or avid pistons that work well for handliing larger jumps.this triple is eating the xb4 alive
ResultsRC is offline   Reply With Quote
Old 04-22-2015, 08:38 PM   #8044
both mine broke on 2 diffrent cars in almost same spot,this type of mini brace in alum would work ok..
Old 04-22-2015, 08:39 PM   #8045
another
Old 04-22-2015, 08:40 PM   #8046
worthless front brace
Old 04-22-2015, 09:03 PM   #8047
Boz,
Thanks my friend for the help. Yes I agree the new 4 hole plate is much different with the Ackerman positions and although thinner the ball stud base mounts sit higher than the stock plate.
I will definitely try 4mm first by adding a 2mm shim. When using just the 2mm c. washer as directed with the stock steering plate the angle is just to much.
Thanks again brother and have an excellent rest of the week.
Old 04-22-2015, 09:08 PM   #8048
Originally Posted by ResultsRC View Post
another
Ouch!!!!! I better get something figured out before I even think about running my XB4 on our local 8th scale track.
Thanks for sharing the pics although I hate seeing people gear getting laid out.
Have a excellent rest of your week my friend
Old 04-22-2015, 09:13 PM   #8049
Your probably correct. What about CF in a that format but a full triangle. Thus one could recess counter sunk screw holes.
Old 04-22-2015, 09:21 PM   #8050
havnt seen may carbon parts with a tight right angle in them. usually flat parts that can be cad cut from a sheet.
Old 04-22-2015, 10:12 PM   #8051
Boz
Originally Posted by Norse View Post
Boz,
303127-K
You can use this spacer from the XB4 2wd
Chris Bozich
Xray XB8 XB4 XB2
Old 04-22-2015, 11:26 PM   #8052
I think that camber link brace was to stop the inner ball stud ripping though the shock tower, nothing to do with the bulkhead breaking.
First thing I noticed when I built mine was that there wasn't a lot of the flat part of the ball stud sitting on the shock tower, meant it could twist in a crash, I just used washers and flanged nuts and haven't had a problem there.
Like I said before, the Rall Racing bulkhead saver is a god send, going by how the kit one broke, I'm sure the saver has stopped me having a breakage since.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 04-23-2015, 12:21 AM   #8053
suzukipro's Avatar
Trader Rating: 21 (100%+)
Just got doing some maintenance on my 14 XB4 and noticed that the top deck is broke in half by the body mount post. Since there is no chance of getting a replacement here in time for the last indoor race of the season on Sat, I'm going to try epoxying it together and keep my fingers crossed to see if it holds up. Anyone have any tips for gluing or welding carbon fiber?
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 04-23-2015, 06:55 AM   #8054
Hey Eric,
Can you use CA glue in conjunction with some accelerator(Bob Smith Industries) CA on one edge and accelerator on the other edge.
I could be totally wrong as I am not positive on how this combo works on CF but I do know it works like magic in securing broken plastic/composite parts..
have a great rest of your week
Old 04-23-2015, 06:58 AM   #8055
I was thinking one could use a thick piece of CF, to then mod into the brace.
Wish I had I nice 3D printer as that would be a great way to create your brace.
Have a great rest of your weekend
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
