Like Tree52Likes
Old 04-13-2015, 08:51 PM   #7906
Trader Rating: 31 (100%+)
Originally Posted by DustinEich View Post
Diff:
Front 5
Slipper
Rear 3
Shocks:
Front 3 dot 32.5
Rear 1 Dot 27.5
Thanks Dustin! Your springs and shock weight are spot on being the same I recieved from another experienced XB4 driver. Thus nice seeing another repeating this set up.
I am running a c-diff, thus what would u recommend for diff oil weight.
Your Front 5 and Rear 3 recommendation is spot on with this other fella as well.
Thanks my friend
Norse is offline   Reply With Quote
Old 04-13-2015, 09:01 PM   #7907
Trader Rating: 32 (100%+)
Diff:
Front 5
Slipper
Rear 3
Shocks:
Front 3 dot 32.5
Rear 1 Dot 27.5
We almost same except the spring. I'm running progressive spring F/R also i change from center differential to slipper
raved007 is offline   Reply With Quote
Old 04-14-2015, 12:20 AM   #7908
Enyone have a good basic astro turf setup?
walste is offline   Reply With Quote
Old 04-14-2015, 01:13 AM   #7909
Hi All,
I own XB4 14'. I drive on a astro turf track, and my slipper is on its tightest and still slips a lot around all of the track. i cleaned my slipper pads with brake cleaner without any result. the thickness of the pads are 1mm (0.039"). can anybody help out.
SamP2 is offline   Reply With Quote
Old 04-14-2015, 03:17 AM   #7910
Boz
Trader Rating: 23 (100%+)
Originally Posted by SamP2 View Post
Hi All,
What slipper pads are you using?
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 04-14-2015, 03:26 AM   #7911
Boz
I'm lost.
I see you quoting what oils and springs you are using, but no mention of piston. That's like ordering a burger, minus the bun.
Chris Bozich
Xray XB8 XB4 XB2
Old 04-14-2015, 03:30 AM   #7912
I use these #364131 Slipper Clutch Pad SLS
Old 04-14-2015, 03:41 AM   #7913
Boz
mmm
I tried using the AE yellow pads on the XB4'13 and they slipped like yours. Then Xray brought out there SLS pads and the stronger spring. Mine is fully undone and I cant get enough slip. Weird.
Did you squash you spring before installing it?
Chris Bozich
Xray XB8 XB4 XB2
Old 04-14-2015, 04:26 AM   #7914
I bought the car second hand, so i don't know for sure, but i didn't.
I might have done it the last time when i tried to compress the spring to the max and broke a piece out of my bearing shell.
Old 04-14-2015, 04:07 PM   #7915
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
I'm lost.
Or battery style..
MaricopaAgent is offline   Reply With Quote
Old 04-14-2015, 04:48 PM   #7916
Trader Rating: 29 (100%+)
Thanks my friend
I haven't tried the center diff, but i would guess thick 500,000 to mimic the slipper.
Piston 3x1.3
Saddle Pack
DustinEich is offline   Reply With Quote
Old 04-14-2015, 04:49 PM   #7917
Get the stiffer spring i believe it is the 45c
Old 04-14-2015, 05:10 PM   #7918
tony montana's Avatar
Trader Rating: 65 (100%+)
Just bought a new xb4 15. On building the diffs do I use the plastic bevel gear bushing?
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 04-14-2015, 05:38 PM   #7919
Yes, there to be used with only metal gears. Good luck with your build and have fun driving her when your done.
Old 04-14-2015, 05:42 PM   #7920
Ok thanks. The manual is a little confusing there lol. Says do not use for alumium or graphite gears
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
