Xray XB4 thread
#7818
Big time PROPS to XRAY!!!
They surpassed my expectations by far....
I bought a used XB4 2015 a couple of weeks ago, found out about the suspension holder issue via this thread, sent XRAY an email, they advised me to contact RCAmerica, so I did and just got my replacement today in that little envelope (skeasor) made mention of. I've tried the D413, S10B, B44.2, DEX410 and now the XRAY XB4. Hands down, this has been the best wheeler for me! It's also good know that I have EXCELLENT customer service support to back it up!
winstonite= Driver
winstonite= Driver
#7819
winstonite= Driver
winstonite= Driver
#7820
winstonite= Driver
winstonite= Driver
#7821
Quick question. I got the steel internal gear sets for both of my Diffs however I neglected to get the metal diff cross pins. Can I get away with running the steel gears on the composite diff cross pin for a race day or two?
Thank you
Ducky
Thank you
Ducky
#7822
Bent
#7824
#7825
Looking for a little trouble shooting or advice. Recently had front transmission pinion gear come loose on my 14 xb4 which caused the composite gears to roach. Replaced them with another set of composites and replaced the dif case as well.
The rear has steel pinion and bevel gears and hasn't had an issue, however the front roached the pinion tonight after about two batts through it. Initially I was thinking the pinion had come loose again but upon opening the case it was still tightend down.
I have steel gears on order for the front but I'm at a loss as to why the front transmission keeps eating pinions. It isnt loose and its sitting in new dif cases that were properly tightened down. Could running steel in the rear and composite up front have somehow put more strain on the composite gears? Any help is appreciated.
#7827
#7828
I had the exact opposite issue, I was going through front and rear composite gears and went to the steel gears and roached the rear steel pinion and have no idea why? My slipper is way looser than recommended in the manual and I run on loose dirt and everything seems to fit perfectly together. I replaced the rear with composite gears until a replacement steel pinion could be sourced, and they went bad too. Now that I have the steel gears back in it, it hasn't given me an issue knock on wood .
#7829
Steel bevel and pinions should be your first upgrade, however, bad driving habits can roast a set of composite gears fairly easily; landing off jumps on throttle, trying to jump over track barriers or tile drainage that outline the track and yes, an overly tightened slipper.
#7830
Any recommendation for tires for an outdoor dirt track? (RC Madness in CT) Never seen the track before.
