Like Tree52Likes
Old 03-30-2015, 10:23 AM   #7801
theclutch's Avatar
Originally Posted by theclutch View Post
If I install the RR+2 upside down, then it's a match with the original "RR" that came with the car. If I install it correct side up, then it would result in a DECREASE in rear caster - maybe negative caster even.
Can others check if this is the case with theirs please?
So I just found out... in order for you to make use of the "RR+2", you also have to have the corresponding "RF+2" on the front side of the rear diff. So if you have a 2014 and you have a "RF" at the front, you will seemingly need to install the "RR+2" upside down in order to have the same geometry. I say seemingly since if flip the RF+2, it looks like the holes match with the RR.
XRAY XB2 2018, XRAY XB4 2017, Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 03-30-2015, 10:30 AM   #7802
rcgod's Avatar
Trader Rating: 27 (100%+)
Sounds like they sent some 2014 owners the 2015 +2mm rear mount. If that's the case then 2014 owners will have to buy the +2mm front mount to match, or run offset bushings in the mounts to make the anti squat where it should be, around 2.5 degrees. If you have a 0mm front mount run 1up bushings, and 1 down bushings in the +2 rear mount. Or contact rc america and have them send you the correct mount.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 03-30-2015, 10:43 AM   #7803
kevinpratt823's Avatar
Originally Posted by Mizchief View Post
are there any good aftermarket battery strap systems out there for shorty packs? It's kind of a pain getting to the body clip in the rear and would rather just have two thumb screws holding it down. I also use some packs that are a little swollen during practice so nice to be easy to have a bit more room adjusted for.
I drilled a new hole for the clip, it now goes in at an angle, kind of from the direction of the front right tire, not too bad. I also used a dubro body clip retainer(the rubber string type) to keep from having to worry about where I place it.
May you always hold your line, and keep the rubber side down.
My private track- https://www.youtube.com/watch?v=XC3HpcDO4Ig
kevinpratt823 is offline   Reply With Quote
Old 03-30-2015, 10:52 AM   #7804
Trader Rating: 32 (100%+)
Originally Posted by raved007 View Post
I didn't get mine also i call RCamerica last week and spoke to Brian said they don't have received any replacement but I hope I get this week.
Just got my replacement today and took my caliper same measurement.
raved007 is offline   Reply With Quote
Old 03-30-2015, 12:15 PM   #7805
rcgod's Avatar
Same as the bad ones or same side to side?
Dialed RC Hobbies
Old 03-30-2015, 12:48 PM   #7806
skeasor's Avatar
Originally Posted by timannnn6 View Post
I took a long screw (around 32mm if I remember correctly) and cut the standoff about 5mm shorter. Screwed the screw all the way through and use a standard thumb nut. Works like my b5m now.
That's a good idea. I absolutely hate trying to put a clip in there with my fat fingers!
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 03-30-2015, 12:55 PM   #7807
BentKa's Avatar
Originally Posted by willo76 View Post
Bent its great to have you back on the thread!
Where do you run the shocks with this low grip setup?
thanks
We usually start with middle on the towers and outside on the arms and go from there
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 03-30-2015, 01:30 PM   #7808
Trader Rating: 15 (100%+)
I am still waiting on my rear hanger. Mine was a 2013, but I also bought the newer RR+2 separately and sent in a photo to RC America with my replacement form and SN, so I am not sure which hanger I will get now.
For anyone who has a 2014 and received a RR+2 but wants an RR, let me know if you plan to keep it or sell it before you send it back to RC America.
HeavyD99 is offline   Reply With Quote
Old 03-30-2015, 03:24 PM   #7809
rcgod's Avatar
Got my new rear hanger today and revised my review on Amain.
Also I find that putting the nut in front on the battery mount makes removing and adjusting for different thickness packs easier. Pic attached.
https://www.dropbox.com/s/a4ijlwx9w3...34541.jpg?dl=0
Dialed RC Hobbies
Old 03-30-2015, 03:59 PM   #7810
Just received my free replacement part for the rear today :
Rico54 is offline   Reply With Quote
Old 03-30-2015, 04:09 PM   #7811
Trader Rating: 31 (100%+)
Sweet!!!!! I received mine Sat. nice idea, in putting the nut in front per adjusting for battery packs quicker.
Norse is offline   Reply With Quote
Old 03-30-2015, 04:09 PM   #7812
Sweet!!!!
Old 03-30-2015, 04:19 PM   #7813
I was thinking maybe I would leave my up for an extra two week duration, as that's how long it took for them to finish blowing smoke up our a$$es and acknowledge it
Old 03-30-2015, 04:24 PM   #7814
Bent,
You bring up a good point. Most of the Spec R aluminum XB4 parts are replicas of XB4 composite parts. The 9 degree caster blocks (honest aluminum finish), rear uprights (honest aluminum finish), aluminum cvd collars (red & black finish offered), aluminum steering plate (honest aluminum finish)
The after market XRAY produced parts are available at the XAY-shop Austria for those looking for 12 degree caster blocks, 4 hole steering plate, 3mm chassis, x-brace, etc etc.
Best,
N
Old 03-30-2015, 04:47 PM   #7815
skeasor's Avatar
I got mine today too. Just in case if anyone is looking for theirs, mine came in a small envelope. Don't throw it out accidentally
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Phillip F
