Like Tree38Likes
Old 03-29-2015, 03:04 PM   #7786
advpball's Avatar
Trader Rating: 27 (100%+)
got mine yesterday too.also put back in slipper and ran the best times so far finally made 22 laps would have been 23 but had bad lap and cost me almost flu lap..oh well shouldn't have crashed..lol running basic clay setup.
tekno sct-410.3,xray xb2 de and xsc2?
eb 48.3 for sale artr 600
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 03-29-2015, 04:11 PM   #7787
Trader Rating: 114 (100%+)
XB4 @ my local track: LRH Raceway!
Practicing with a fellow XB4 and D413
https://www.youtube.com/watch?v=DQTtyuAM1Yc
winstonite is offline   Reply With Quote
Old 03-29-2015, 08:03 PM   #7788
theclutch's Avatar
Originally Posted by kevinpratt823 View Post
I just got my new corrected rear hanger in the mail from rcamerica!
Originally Posted by Norse View Post
Sweet!!! Craziness as mine was in today's mail as well.
Have a great weekend fellow XB4 owners the hangers are showing up.
Originally Posted by rcgod View Post
My friend just got his today for his 2014 car so they made some for both the 14 and 15 models. Still waiting on mine.
Originally Posted by timannnn6 View Post
Just got mine from amain today and it had the revised part on outside of box (inside outer cover though). So looks like amains kits are good to go.
Originally Posted by rraden View Post
For those who are waiting for the updated RR toe block, got mine in the mail yesterday!
Originally Posted by suby723 View Post
Got mine yesterday also.
Originally Posted by raved007 View Post
I didn't get mine also i call RCamerica last week and spoke to Brian said they don't have received any replacement but I hope I get this week.
Ok guys... Did yours look like this? It's a "RR +2". But mine is a regular "RR".
Any thoughts?
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 03-29-2015, 08:05 PM   #7789
timannnn6's Avatar
Trader Rating: 124 (100%+)
Any thoughts?
Mine was the same RR+2
timannnn6 is offline   Reply With Quote
Old 03-29-2015, 08:13 PM   #7790
Trader Rating: 32 (100%+)
Anyone can confirm if this wheels fit in front xray xb4 '15 before i place an order.
http://www.amain.com/rc-cars/de-raci...91076?v=296193
raved007 is offline   Reply With Quote
Old 03-29-2015, 08:13 PM   #7791
Mizchief's Avatar
Got mine out on the track today and man what a difference over the b44.3! I weighed the two and the XB4 was about 100g lighter overall but felt 10lbs lighter on it's feet. Was immediately able to double-double a 4 pack of what are normally all singles. Steering was much more reactive even at the conservative box settings. Would rotate on a dime but still throttle out of the turn without getting loose.
Ran the center diff first with 100k on med-high bite. Really hard packed indoor but was fairly dusty on top being a practice day. Also swapped out to the slipper and think I liked it better than the center diff. More forward bite and could get on the gas harder without spinning tires and didn't notice much difference in turning.
I figured they would have some 500k or 1000k at the hobby shop but no luck, so going to order some and try out the center diff again with thicker oils.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 03-29-2015, 08:21 PM   #7792
MaricopaAgent's Avatar
His says " +2 " But looks standard to me.
MaricopaAgent is offline   Reply With Quote
Old 03-29-2015, 08:29 PM   #7793
Mizchief's Avatar
are there any good aftermarket battery strap systems out there for shorty packs? It's kind of a pain getting to the body clip in the rear and would rather just have two thumb screws holding it down. I also use some packs that are a little swollen during practice so nice to be easy to have a bit more room adjusted for.
Tekno Team Driver
AKA Racing
Old 03-29-2015, 08:56 PM   #7794
Yes..
Old 03-29-2015, 08:56 PM   #7795
timannnn6's Avatar
I took a long screw (around 32mm if I remember correctly) and cut the standoff about 5mm shorter. Screwed the screw all the way through and use a standard thumb nut. Works like my b5m now.
Old 03-30-2015, 03:51 AM   #7796
Originally Posted by MaricopaAgent View Post
Yes..
MaricopaAgent thanks for quick reply
Old 03-30-2015, 06:45 AM   #7797
theclutch's Avatar
If I install the RR+2 upside down, then it's a match with the original "RR" that came with the car. If I install it correct side up, then it would result in a DECREASE in rear caster - maybe negative caster even.
Can others check if this is the case with theirs please?
Old 03-30-2015, 07:30 AM   #7798
I take that back.. The standard rear mount is notched on the bottom to lower it. Your mount looks correct.
Old 03-30-2015, 07:50 AM   #7799
Originally Posted by BentKa View Post
What pistons are you running ?
For loose dusty conditions we usually run F: 2x1.6 or 2x1.5 + 2x1.1 R: 2x1.7 or 2x1.6 + 2x1.1
Stock pistons are not ideal on a loose bumpy track.
Front: 500-550 cst Rear: 400-450 cst
Springs: Front 2 or 3 dot and Rear 1 or 2 dot
No limiters in shocks and if really loose we add droop as well by unscrewing the shock rod ends.
Swaybars 1.2mm or thinner.
If really loose we run no swaybars.
Shorter links, inside and down on the hinge pin inserts and ride height of around 22mm on a bumpy track.
For diffs in low grip conditions we run 3 / 500.000 / 2
Metal gears inside and hardened alu. pins in all diffs.
Shorty pack is awesome in low grip conditions
Other buggys looking better with saddles is down to a better setup
Bent
Bent its great to have you back on the thread!
Where do you run the shocks with this low grip setup?
thanks
Associated, Tekin, AKA
2011 & 2012 Carine Bombshell
willo76 is offline   Reply With Quote
Old 03-30-2015, 09:04 AM   #7800
jmcelroy42's Avatar
Any thoughts?
That is the RR hanger for the '15 models, or for the '14 with both +2 rear hangers.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
05PSD
