Like Tree38Likes
Old 03-25-2015, 06:27 PM   #7726
rcgod's Avatar
Trader Rating: 27 (100%+)
I just reposted my 1 star review on amain. Will be interesting to see how long it lasts before being deleted.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 03-25-2015, 06:31 PM   #7727
Trader Rating: 30 (100%+)
I agree with you! as once you get your part then you can change your review if you like.
Norse is online now   Reply With Quote
Old 03-25-2015, 06:35 PM   #7728
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
pretty shady on amain's part
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 03-25-2015, 06:41 PM   #7729
Trader Rating: 32 (100%+)
I agree that i will posted 1 star review till not get my replacement parts. I call RCamerica and they said didn't get any replacement.
raved007 is offline   Reply With Quote
Old 03-25-2015, 08:39 PM   #7730
likea45's Avatar
Recently upgraded my xb4 '14 to the steel pinion and bevel gears and am having some issues with the front dif. It's making a grinding sort of noise only noticeable when under load on the ground. I've checked that everything is tightend and appears to be correct but the noise persists. Any help or advice would be appreciated.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 03-26-2015, 12:39 AM   #7731
Daniel Kies's Avatar
You broke the axle or the bone?
Thanks very much Norse, this car has done nearly 5 seasons on carpet....about 3 weeks ago I snapped both rear bones....put the proper Xray ones in and now just snapped one front bone and the other side isn't far behind. Ill give those Spec R double jointed as I use them in my touring car and there are heaps of benefits.
*** KL Racing Team Driver ***
Team Associated * Jconcepts * Ko Propo * Hobbywing
Supercheap hobbies * Ace Hobbies
https://m.facebook.com/KL-Racing-110-Offroad-Electric-Team-573132579553215/
Daniel Kies is offline   Reply With Quote
Old 03-26-2015, 02:53 AM   #7732
Originally Posted by advpball View Post
does any one who is running the center diff after like 4min of 5min race it starts to feel soft? running 8-100-8 in diffs in 13.5 class.haven't refilled diffs since i put together about 8 race nights.
Thank you. I thought it was me. I'm guessing it's heating up and thinning out a little. I went to 200k and same thing. I read bentkas post and he said the lowest they run is 500k. The lower oils don't allow you to push it As hard as we want. I just put the 500 In last night so after this weekend I'll get back atcha with results . I don't think it has anything to do with rebuilding the diff . There designed to be good for along time.
* HobbyWing of N.A. * Nitrohouse *M.I.P.*Proline * Carl D. *
Losi57 is offline   Reply With Quote
Old 03-26-2015, 05:56 AM   #7733
EricW's Avatar
You might want to replace the bulkhead and the diff case as well, perhaps the diff isn't seated firmly enough and it moves around. When I switched to the steel gears in my 14 I had a problem with the rear diff leaking, tried lots of stuff but eventually just replaced the diff case itself and the problem went away.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 03-26-2015, 08:26 AM   #7734
jmackani's Avatar
Trader Rating: 14 (100%+)
Grinding under load is a good indication that the front pinion gear is chipped or has broken teeth.
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 03-26-2015, 08:58 AM   #7735
Im running a 2015 Xb4. I currently have a 8.5t in it and want to go to a 6.5t is there a chart anywhere for what size pinion I should use. I have been racing associated stuff since the summer and am used to having the sheets in the book that show the size you should start with and go from.
Eboyles is offline   Reply With Quote
Old 03-26-2015, 09:09 AM   #7736
I would drop 2-3 teeth
Old 03-26-2015, 09:20 AM   #7737
No problem Daniel
Old 03-26-2015, 09:31 AM   #7738
Mizchief's Avatar
Stock spur is the same on xb4 and b44.3 81t i'm running 19t pinion on the b44 with a 6.5 so going start out with the same on the xb4.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 03-26-2015, 09:36 AM   #7739
Trader Rating: 15 (100%+)
It's always tricky to recommend gearing because no one knows your track but you. Start with the stock 81T spur and run either an 18 or 19 tooth with your 6.5 and keep an eye on your temps. If you run a really small, tight track, you could try the 84T spur and maybe a 20 or at max a 21 tooth pinion. Watch your temps.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 03-26-2015, 09:43 AM   #7740
likea45's Avatar
Gears are all good.
This is what I'm thinking. I've tried shimming and everything else short of replacing the dog bone and it still does it so this is my next course of action. Thanks.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
