Like Tree52Likes
Old 03-24-2015, 08:33 AM   #7696
theclutch's Avatar
Originally Posted by Mizchief View Post
Just got my kit today from amain. No external holder attached, but got a nice letter in the box explaining the issue and that I can measure the toe then call them for a replacement.
Is there a way to measure the holder prior to installing to see if it needs replacing? It will probably be a couple of days before I can get it built and would like to get on the list as soon as possible.
Oh that SUCKS.... Search a bit on previous pages on how to measure.
XRAY XB2 2018, XRAY XB4 2017, Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 03-24-2015, 08:33 AM   #7697
Mizchief's Avatar
Originally Posted by BentKa View Post
Internal diff gears are composite on all models of the XB4 ('13, '14 & '15).
The external 14T pinion gear and 35T bevel gear however are metal on the '15 model
Bent
Ahh ok, I suppose i'll give them a shot and see how it goes. I'm usually not to rough on drive trains.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 03-24-2015, 08:48 AM   #7698
fredmotokx's Avatar
This is a serious turn off, I was thinking about buying this kit for outdoor season...
TLR SCTE 2.0
Team associated B5
fredmotokx is offline   Reply With Quote
Old 03-24-2015, 09:34 AM   #7699
Mizchief's Avatar
Pretty sure mine is off. I'm using calipers to measure from the screw hole to the outer edge of the holder and from the screw hole to the inner edge and consistently getting about .5mm more on the right side. Is that what others have seen?
Tekno Team Driver
AKA Racing
Old 03-24-2015, 09:36 AM   #7700
jmcelroy42's Avatar
Pretty sure mine is off. I'm using calipers to measure from the screw hole to the outer edge and consistently getting about .5mm more on the right side. Is that what others have seen?
Yes
EB48.4 - TEKIN RX8 & SMC 2100
EB410 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 03-24-2015, 09:44 AM   #7701
Trader Rating: 29 (100%+)
Originally Posted by Norse View Post
Ronzo,
Are the brass hangers off as well?
yes mine is off like the the one from the kit.
ronzo is offline   Reply With Quote
Old 03-24-2015, 09:44 AM   #7702
My kit shipped out today from amain, curious to see what holder comes with it. Either way pretty sure it's going to be better than the 44.3
I just noticed the center diff comes with polymer gears vs. steel like the 15 kit front and rear. Anyone have issues with them stripping?
Even with the toe off the car is better than the b44.3 mine is off and i still run my 15 and the car is still the best 4wd out of the box!
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
bigdog is offline   Reply With Quote
Old 03-24-2015, 10:07 AM   #7703
Mizchief's Avatar
Yea i'm still excited about it and can offset via the insert in the meantime.
My b44.3 did ok when we had a smoother and faster layout, but drives like a brick with wheels now that we added some whoops and more technical features. I think one of the main issues is that the 44.3 has no kick-up so the shocks can't dampen much of the force when the front end meets steep or sharp bumps. (probably also causes much of it's arm breakage) Bought it more as a toy to go along with my B5M which I do really like and liked being able to share shocks and a few other things. but now that the 4wd class has taken off I want the best equipment
Tekno Team Driver
AKA Racing
Old 03-24-2015, 11:28 AM   #7704
Mizchief's Avatar
Seems like good news on the holder front. Just got this email from rcamerica:
Thank you for your purchase of the XRAY XB4 2015. We just received the replacement plates from XRAY, so we will get one on the way to you.
Tekno Team Driver
AKA Racing
Old 03-24-2015, 07:13 PM   #7705
ATLiens's Avatar
Trader Rating: 51 (100%+)
Just got my XB4 in last week from Amain and its all built up and ready to run. I had the same note in box about issue with rear holder and I received a call from Amain yesterday saying they see I recently purchased an XB4 and just received the replacement holder in would I like them to send me one? Of course...
Customer service at its best.
ATLiens is offline   Reply With Quote
Old 03-24-2015, 07:48 PM   #7706
MikeXray's Avatar
Trader Rating: 73 (100%+)
Yup brass is one is off too, you can see it if you look down at the gap from the arm to the gear casing.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-24-2015, 09:13 PM   #7707
I wrote to RCAmerica and received the same email. Should be getting the replacement soon.
Rico54 is offline   Reply With Quote
Old 03-24-2015, 11:58 PM   #7708
Daniel Kies's Avatar
Default Front drive shafts
Hey guys, I have just broken one front axle on my XB4 and the other side isn't far behind. As I am on a tight budget I cant afford to order genuine Xray ones at around $25 each, I know the fronts are 81mm. The 22-4 has the same length, I'm wondering if they could be an option?
Thanks Daniel Kies
*** KL Racing Team Driver ***
Team Associated * Jconcepts * Ko Propo * Hobbywing
Supercheap hobbies * Ace Hobbies
https://m.facebook.com/KL-Racing-110-Offroad-Electric-Team-573132579553215/
Daniel Kies is offline   Reply With Quote
Old 03-25-2015, 12:04 AM   #7709
Mizchief's Avatar
Ok I have to ask, what are those little pieces of brown paper for that come with a lot of their parts?
Tekno Team Driver
AKA Racing
Old 03-25-2015, 12:52 AM   #7710
According to a Slovakian guy at work, they're there to baffle and confuse you!
Actually, he had no idea why they might be in there
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
