Like Tree52Likes
Old 03-21-2015, 10:34 PM   #7651
Mizchief's Avatar
Originally Posted by suby723 View Post
Exotek makes 12mm hexes and the rear will use a rb6/b5 wheel and the fronts are zx5 wheels. Both have a ton of options.
Ok cool thanks. I see that if I went with the b4 stuff it would be 243mm front and rear, but the xray spec sheet says it's adjustable from 245mm - 250mm so i'm guessing that would put it 2mm shorter than box stock?
I'm thinking I may just acetone off the good rubber, buy new foams and stock up on xb4 wheels incase I need to buy something at the track....
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 03-22-2015, 02:48 AM   #7652
Working out the hex widths and back depths of all the wheels definitely a challenge, I have the exotek hex's now and have worked out that my 22 rears work with the 7mm and 22-4 fronts work with the 5mm. I have been running the de racing 14mm wheels and the back depths are the same as the TLR wheels
goldy is offline   Reply With Quote
Old 03-22-2015, 10:29 AM   #7653
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Mizchief View Post
I'm looking switch over from the b44.3 to buy the 2015 and trying to figure out what 12mm offsets to buy so I can use b4/b5/b44 rear wheels. Then I was thinking of just running the 14mm xray fronts since I have to ditch the 10mm b44.3 fronts anyway, but want to shoot for something that is highly available like losi or AE.
I suppose any 12mm wheel will "fit" but want to maintain kit width starting out.
http://www.exotekracing.com/xb4-9-5m...-front-wheels/
http://www.exotekracing.com/xb4-12mm...ar-2-7mm-wide/
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 03-22-2015, 12:12 PM   #7654
rcgod's Avatar
Fwiw I have several friends that have broken driveshafts recently on both 2014 and 2015 cars. The 2014 manual says to run 3 oring limiters on the shock shaft but my 2015 manual shows no limiters. I recommend running at least 2 orings because depending on roll center and camber the bone can bind on up travel in the outdrive and break the bone or outdrive with no orings. A friend broke another bone at the track yesterday and I looked at his car and he has no limiters and you could see the marks on the bone where it was hitting the outdrive. And he was running middle width, so it doesn't only happen when running narrow.
Dialed RC Hobbies
Old 03-22-2015, 01:13 PM   #7655
Trader Rating: 31 (100%+)
RCGOD thanks for the heads up on the limiters needed even when running middle.
Norse is offline   Reply With Quote
Old 03-22-2015, 01:19 PM   #7656
I'm running a loose small indoor track this next weekend. Suggestions on F/C/R diff oil weight?
Much appreciation for suggestions.
Old 03-22-2015, 06:24 PM   #7657
MaricopaAgent's Avatar
Broken them where? I have twisted a '15 shaft on the wheel side off, but that would not be outdrive/limiter issues.
MaricopaAgent is offline   Reply With Quote
Old 03-22-2015, 06:36 PM   #7658
TPR 1's Avatar
Trader Rating: 26 (100%+)
5-20-3 with 20,000 in the centre you will get wicked turn in off power.
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Old 03-22-2015, 06:38 PM   #7659
hello just curious if its worth getting the center gear diff? im wondering how it makes the car better? im ruuning on a med bite loose indoor clay track
DIRT DIGGER is offline   Reply With Quote
Old 03-22-2015, 06:42 PM   #7660
suby723's Avatar
Trader Rating: 21 (100%+)
Yes the center diff give the car a whole different feeling. It's worth every penny IMO.
suby723 is offline   Reply With Quote
Old 03-22-2015, 06:55 PM   #7661
Trader Rating: 32 (100%+)
Go back to slipper pads more power and down my laps from 18's to 17's
raved007 is offline   Reply With Quote
Old 03-22-2015, 06:56 PM   #7662
Thanks TPR1, much appreciated.
Old 03-22-2015, 07:04 PM   #7663
the slipper is better than the gear diff?
Old 03-22-2015, 07:28 PM   #7664
I feel better for slipper pads because been running 2months for center differential but my laps still the same then i replaced slipper pads can't believe my laps dropped with same tire, motor & set up
Old 03-22-2015, 10:32 PM   #7665
likea45's Avatar
I've noticed associated spurs seem a close fit to the xb4 ones. Has anyone tried them and will they work?
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
