Like Tree39Likes
Old 03-20-2015, 08:26 AM   #7621
Originally Posted by John Myall View Post
I don't think they changed the arms for the '15 car, so yes they will fit.
Ok thanks for the info guys. Any other suggestions? Also is it worth switching the diff gears to the steel bevel 35t and 14t gears? I was reading in some earlier posts that a lot of people were doing that.
St21reaper is offline   Reply With Quote
Old 03-20-2015, 08:32 AM   #7622
rcgod's Avatar
Trader Rating: 27 (100%+)
In addition to arms and hinge pins, get some hinge pin inserts, front diff case, and diff gears if you're staying with the plastic gears. A good upgrade is the metal diff gears.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 03-20-2015, 08:53 AM   #7623
Where could I get the hinge pin inserts from? Also I know that the diff cases from 14' to 15' are different and that the 15' are much more solid but does anyone know the part number for the 15' diff case?
Old 03-20-2015, 10:21 AM   #7624
jmackani's Avatar
Trader Rating: 14 (100%+)
So, I have a friend that has a 15 and has broken two of the front diff cases. I would not be so quick to jump on those.
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 03-20-2015, 10:58 AM   #7625
jmackani's Avatar
Eccentric bushings are out of stock at most places. There is one set here http://www.stormerhobbies.com/cgi-bi...l?pn=XRA362315
Old 03-20-2015, 01:44 PM   #7626
suby723's Avatar
Trader Rating: 21 (100%+)
eBay has killer deals on new Xray parts.
suby723 is offline   Reply With Quote
Old 03-20-2015, 02:39 PM   #7627
kevinpratt823's Avatar
Originally Posted by ezlight View Post
Hey Kevin,
I'll be down there tomorrow for the race with my xb4 for the weekend. You going to be doing the tekin race? Where's your outdoor track at? I like having options to race.
I won't be there for the Tekin race, that's a long, crowded weekend, and I have some heavy family situations going on right now. My track is at my house, in Canton, MA, where are you?
Good luck at the race, lmk what you think about the layout. Lots of good people down there at RC Excitement! I already saw a few FB videos of Dakota Phend warming up.
May you always hold your line, and keep the rubber side down.
My private track- https://www.youtube.com/watch?v=XC3HpcDO4Ig
kevinpratt823 is offline   Reply With Quote
Old 03-20-2015, 02:43 PM   #7628
I have only run 300,000 in the center, but I'm thinking I need to drop it to 200,000, maybe even 100K. Running 8K front 5K rear, but may try dropping those too. I want to try saddle, but I don't have the packs and it's hard to convince myself to spring for them when shorty is working, but people are saying it's better for low/medium. This track is considered medium by our standards, but I'm pretty sure it's low bite compared to most areas of the country.
Old 03-20-2015, 03:53 PM   #7629
GregerL's Avatar
Part number for '14 and '15 diff case is the same. Whatever changes were made was a running change of the part.
Alexander Landén RC on facebook:
https://www.facebook.com/alexanderlandenRC
GregerL is offline   Reply With Quote
Old 03-20-2015, 04:20 PM   #7630
Ok thanks for all the help guys I appreciate it
Old 03-20-2015, 04:40 PM   #7631
blwaz23's Avatar
I went to do my ride height the other day and I wanted to run 21mm in the rear of my XB4. I went to do this and my rear shocks screwed all the way up and I still wasn't even close. I took my rear shocks apart completely, measured everything and put them back together by the book. I went to measure my ride height and I still had the same problem. Help anyone? thanks.
blwaz23 is offline   Reply With Quote
Old 03-20-2015, 06:00 PM   #7632
jmackani's Avatar
What dot springs are you running? Can you post a picture?
Old 03-20-2015, 06:38 PM   #7633
Trader Rating: 15 (100%+)
You need to run 2mm shock limiters and run the spring collars as high on the shock body as they go - then, I think you should be able to get closer to 21mm. I'm not sure how Xray Team guys get down to 18-20mm without cutting their springs otherwise.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 03-20-2015, 06:59 PM   #7634
suby723's Avatar
That's strange. I have no issues getting to 18mm. I use associated springs but I think the lengths are the same.
Old 03-20-2015, 07:18 PM   #7635
Spring length makes all the difference!
Daragh Slowey
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
