Like Tree45Likes
Old 03-14-2015, 02:10 PM   #7561
suby723's Avatar
Trader Rating: 21 (100%+)
Originally Posted by spu83 View Post
I think for the center diff Xray suggest 500k cst for low traction and 1000k or 1 mil cst for high traction.??
Correct but that is mostly on astro tracks. For clay tracks I would go 500k tops. The average medium bite track works best with 100k IMO.
suby723 is offline   Reply With Quote
Old 03-14-2015, 03:06 PM   #7562
BentKa's Avatar
Yes……for med to high traction tracks like carpet and astro we use 1.000.000cst diff grease for the center diff.
For low to medium traction tracks like dirt, clay and wet astro we use 500.000cst.
Have tested close to every thinkable combination since we started running the center diff last summer and these are our go to setups
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 03-14-2015, 03:24 PM   #7563
Trader Rating: 30 (100%+)
Bent
Bentka,
I was wondering if I should lightly lube the diffs internal graphite gears before installing in the diff. I know to lightly grease the aluminum diff pins with graphite grease.
Thanks as always your advice is greatly appreciated.
Norse is online now   Reply With Quote
Old 03-14-2015, 08:44 PM   #7564
Bent
Good to know, thanks
Rico54 is offline   Reply With Quote
Old 03-14-2015, 09:06 PM   #7565
Trader Rating: 32 (100%+)
If you are looking to update your 2014 to new specs, when comparing the full partsheets for 2015 vs 2014, these are the parts missing from the 2014 buggy. Some do not seem needed to convert like shocktowers.
Part# Description COST
303125 ALUSHIM3x6x3.0MM-10 9.99
306301 ANTENNAMOUNT-THIN 4.79
361102 ALUCHASSIS-SWISS7075T6(2MM) 64.99
361163 GRAPHITEFRONTUPPERDECK2.0MM 35.49
361164 GRAPHITEREARUPPERDECK2.0MM 35.49
361165 GRAPHITECENTERUPPERDECK2.0MM 20.99
361166 GRAPHITEFRONTUPPERDECK2.0MM-SHORT 35.49
361167 GRAPHITEREARUPPERDECK2.0MM-LONG 35.49
361172 GRAPHITECENTERUPPERDECKSHIM2.0MM 5.29
361182 COMPOSITEREARLOWERBRACE 4.29
361184 GRAPHITEREARUPPERBRACE2.0MM 7.79
361263 COMPOSITECHASSISSIDEGUARDSL+R 15.75
361291 COMPOSITECHASSISBRACEFRONT 9.49
361292 COMPOSITECHASSISBRACEREAR 9.49
361293 COMPOSITECHASSISWIRECOVER 4.29
362081 GRAPHITESHOCKTOWERFRONT3.5MM 36.99
364011 ALUMOTORBULKHEAD 46.99
364022 COMPOSITECENTRALBULKHEAD 11.25
364111 SLIPPERCLUTCHSHAFT-HUDYSPRINGSTEEL™ 25.99
364171 SLIPPERCLUTCHOUTDRIVEADAPTER-HUDYSPRINGSTEEL™ 17.99
364955 STEELDIFFERENTIALBEVELGEAR35T 20.49
364990 COMPOSITEBEVELGEARBUSHING-2 5.49
365134 STEELBEVELDRIVEGEAR14T 11.99
365422 CENTRALDRIVESHAFT116MM-HUDYSPRINGSTEEL™ 25.49
365423 CENTRALDRIVESHAFT64MM-HUDYSPRINGSTEEL™ 25.49
365424 CENTRALDRIVESHAFT85MM-HUDYSPRINGSTEEL™ 25.49
365425 CENTRALDRIVESHAFT95MM-HUDYSPRINGSTEEL™ 25.49
366050 COMPOSITERADIOPLATE 7.79
366114 COMPOSITEBATTERYSTRAP-LONG 5.79
366142 COMPOSITEBATTERYHOLDERSTAND-2 5.79
366202 COMPOSITESERVOMOUNT-HIGHER 4.79
369702 XRAYXB4BODY-WIDE 32.49
Retired - 9.5Pro -> Jammin X1 -> Jammin X2 -> AE RC8B -> Serpent S811 Cobra -> Hotbodies D8 -> 2010 XB808 -> 2011 XB808 -> 2012 XB9 // 2012 XB9-E, Current Vehicles -> 2013 XB9 // Converted 2013 XB9E
mcion is offline   Reply With Quote
Old 03-15-2015, 01:23 AM   #7566
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Racer Tick View Post
What are you guys using?
For 3.5 degrees toe use 0 insert on the right and 1 out on the left. To get 3 deg toe use .5 in on right and .5 out on left.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 03-15-2015, 07:33 AM   #7567
MaricopaAgent's Avatar
https://www.facebook.com/2015XB4 Follow the link for big discounts on the parts.
You dont need the front shaft. Your 88 mm front will work in place of the 85.
only one set of carbon top plates needed, depending on battery setup..
MaricopaAgent is offline   Reply With Quote
Old 03-15-2015, 11:26 AM   #7568
Quick question,
I am going to install graphite gears in the F C and R diffs, in doing so I was wondering if I should very lightly coat the 4 satellite gears and 2 bevel gears with graphite grease?
Basically wondering if doing this is beneficial or not.
Any input would be greatly appreciated.
Old 03-15-2015, 11:38 AM   #7569
Trader Rating: 29 (100%+)
Originally Posted by Norse View Post
Quick question,
No, not needed the diff fluid will act as a lubricant.
DustinEich is offline   Reply With Quote
Old 03-15-2015, 12:56 PM   #7570
Thanks Dustin, I pretty much figured diff oil was more than adequate. but being new to graphite gears I was uncertain if they needed to be pre-lubed.
Thanks again brother
Old 03-15-2015, 01:53 PM   #7571
Also, after your first couple of runs open up the diffs; you may need to add more fluid. After that they don't need much maintenance.
Old 03-15-2015, 02:05 PM   #7572
Thanks Dustin much appreciated.
Regarding diffs, would lightly coating the diff gaskets with green slime promote a better seal? I know soaking the diffs orings in a little oil for a half day and thus after soaking applying a little green slime to them really works well in sealing the diff at the out drives.
Thanks again
Old 03-15-2015, 02:23 PM   #7573
No Green slime needed, soak the rings in diff fluid and build. The gasket doesn't need anything either.
Old 03-15-2015, 02:24 PM   #7574
Trader Rating: 15 (100%+)
Thanks again
The whole point of green slime is to prevent the o-rings from the swelling caused by the silicone oil...I just pull the o-rings out and put green slime of them and install them into the diffs or shocks. No soaking in oil. No leaks. As for the diff gaskets I add a drop of oil to them just to get them to lay flat and hold them in place while I assemble everything together.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 03-15-2015, 02:59 PM   #7575
Thanks Fellas!
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
