Like Tree45Likes
Old 03-07-2015, 08:31 PM   #7471
Originally Posted by DIRT DIGGER View Post
wondering how this car does on med bite clay track? im running a d413 but selling for a xb4
It does very well with the right setup. Have a friend that ran the fastest time at our track with the xb4'15 in meadium bite clay.
Rico54 is offline   Reply With Quote
Old 03-08-2015, 06:31 AM   #7472
Trader Rating: 30 (100%+)
Anyone have any suggestions on what works best for lubricatiing graphite crown(bevel) and pinion gears?
I know graphite grease is recommended for use on steel crown(bevel) and pinion gears but I am not certain on what product best suites graphite crown and graphite pinion gears.
Any recommendations on what working best for hinge pin lubrication would be appreciated as well.
Thank you XB4 owners as always your suggestions are greatly appreciated.
Norse is offline   Reply With Quote
Old 03-08-2015, 01:23 PM   #7473
GregerL's Avatar
Graphite grease works for the graphite gears as well. We have had good results with lithium based grease as well.
I generally try and stay away from hinge pin lubrication since it attracts dirt, thus counteracting its purpose. Just make sure to use an arm reamer so that the hinge pin moves freely and you should be all set.
Alexander Landén RC on facebook:
https://www.facebook.com/alexanderlandenRC
GregerL is offline   Reply With Quote
Old 03-08-2015, 03:37 PM   #7474
Trader Rating: 32 (100%+)
http://www.amain.com/tko-eureka-pro-gear-lube/p16859
I've been using this for my tekno and xray xb4 it's quiet my truck since using these grease.
raved007 is offline   Reply With Quote
Old 03-08-2015, 04:19 PM   #7475
Thanks Brother I will definetly order some
Old 03-08-2015, 04:25 PM   #7476
Thanks Gregor! That makes sense on the hinge pins. How much is enough regarding the crown(bevel) and pinion?
Old 03-08-2015, 10:38 PM   #7477
Originally Posted by rcgod View Post
I ran the exotek hubs middle hole with 1mm spacer and plenty of clearance.
thanks thats about what i put in there for mon clearance,it seems to work well
what mm shock limiters are you guys running for a pretty smooth mid bite clay track?
ResultsRC is offline   Reply With Quote
Old 03-09-2015, 01:15 PM   #7478
GregerL's Avatar
Hard to give an exact measurement, I usually coat the pinion by applying 2-3 "dabs" of grease to it. However, I tend to check and re-lube quite frequently, so if you have a longer maintenance interval than 1-2 race days you might want to apply more.....
Old 03-09-2015, 02:58 PM   #7479
Anyone received there replacement yet?
Old 03-09-2015, 03:29 PM   #7480
Trader Rating: 15 (100%+)
Xray announced the replacement program back on February 2nd, so it's been 4 weeks already. I imagine we still won't see them for another 4-6 weeks from Slovakia. Total guess on my part to keep my expectations low....if mine show up sooner, I'll be twice as happy!
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 03-09-2015, 04:07 PM   #7481
Thanks Greger, So graphite grease or lithium. Another fella mentioned Eureka pro lube was really good which makes sense as I believe it has a lithium polymer. Sounds like all of the above are great. I guess I am somewhat OCD in always wanting to make sure I am applying the best solution per the situation I am trying to address.
Thank you again brother for help.
Old 03-09-2015, 08:41 PM   #7482
Default RC 101.....PLEASE
I'm new to this and stumped.
Just built my kit.....brand new, drove it down driveway 3 feet and it barely moved. Pull trigger...motor spins....that spins center diff very fast......front and rear dog bones spin up......vehicle barely moves. Lift car up in air and pull trigger and the wheels pretty much balloon up.
I noticed if I lift either the front or the rear end up....hand turn a wheel, the opposite wheel doesn't move at all.
Center diff has been out and reassembled, it's full of oil.
Any ideas please? Thank you!
dblhelx is offline   Reply With Quote
Old 03-09-2015, 09:00 PM   #7483
rcgod's Avatar
Trader Rating: 27 (100%+)
You forgot to put the satellite gears in the front and rear diffs?
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 03-09-2015, 09:01 PM   #7484
TPR 1's Avatar
Trader Rating: 26 (100%+)
check the pins are in the wheel hexes.
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Old 03-09-2015, 09:02 PM   #7485
I wish....that would be easy. All 4 and the big one are in there.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
