Like Tree54Likes
Old 03-05-2015, 09:04 AM   #7441
Canadianrage's Avatar
Originally Posted by rcgod View Post
What holes does the 14 have that the 15 doesnt?
Just a quick google search, 2015 chassis
http://www.teamxray.com/xb4/images_2...e/anim01_1.png
From this thread...2014
http://9rc.com/gallery3/var/resizes/...g?m=1356107865
- Xray XB4 2015 VTXR10BE / Trinity D4 6.5 - Associated T5M R10 / Tekin Pro2 5800 -
Canadianrage is offline   Reply With Quote
Old 03-05-2015, 09:18 AM   #7442
rraden's Avatar
Trader Rating: 234 (100%+)
Originally Posted by Canadianrage View Post
Does not fit on the '15 car, thing is indestructable as far as I can tell but sticks out pretty far, same as the T-Bone bumper which can be a problem if you land a jump nose down...
If you turn the front Xray bumper upside down and mount it that way the Bugle Boy bumper will fit.
Xray XB8E 2016 | Xray XB4 2017 | Xray XB2 DE 2017 | Xray XB8 2017
Dirt Burners - Livonia, Mi
The Track - Carleton, MI
rraden is offline   Reply With Quote
Old 03-05-2015, 09:23 AM   #7443
jmcelroy42's Avatar
Originally Posted by likea45 View Post
I've been running these bumpers since my b44.2. Fantastic bumpers and having that small bumper on the xb4 this has saved the front of my car a few times as well. Also lifetime warranty. You break it, no questions asked they send you a new one. They also make a great rear skid pad as well.
Nice, I thought I was the only one running the DMX body.
EB48.4 - TEKIN RX8 & SMC 2100
EB410 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 03-05-2015, 09:30 AM   #7444
Obviously you would need to remove the stock bumper, still can't mount it using 4 holes or without dremeling it to get it to sit flat against the chassis...
Old 03-05-2015, 10:43 AM   #7445
rcgod's Avatar
Trader Rating: 27 (100%+)
Sorry, meant what holes are missing that doesn't allow the use of the bumper without mods?
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 03-05-2015, 10:53 AM   #7446
im sure just the front 2 holes would be fine for bumper support,prolly help a good bit with slight nose now landings to keep the car moving forward rather than sticking in,seems like the lowered ground clearance would be negligible though from both those front bumpers,guess it depends on what level you are driving it at?
With exotech rear hubs,what hole are most using? how high can you mount the balls using the outside holes and not effect roll center so the plastic ball links dont touch the tops of hubs and bind suspension on the down travel?
ResultsRC is offline   Reply With Quote
Old 03-05-2015, 11:22 AM   #7447
MaricopaAgent's Avatar
I am still confused.. ALL of my 14 car bulk heads, bumpers,towers etc is bolted on a 15 chassis instead..No extra or moved holes..
The 15 bumper is the only difference in the front, and it will fit a 14.. You can remove it.
MaricopaAgent is offline   Reply With Quote
Old 03-05-2015, 11:46 AM   #7448
skeasor's Avatar
Well, it says this on bugle boy's racing website:
Note: This bumper is designed for the pre-2015 model. It will fit the 2015 XB4 if you trim the countersink protrusions from the rearward mounting holes and only mount it using the two front screws. This has been found to be a secure enough mounting.
I'm sure they've tested this hence the reason for the note
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 03-05-2015, 12:03 PM   #7449
I see where it is...
They are using the 2 middle holes from the bulkhead, which no longer are on the 15. The T bone bumper uses the 4 outer bulkhead bolts, not the center.
Old 03-05-2015, 11:43 PM   #7450
handyman77's Avatar
Trader Rating: 25 (100%+)
Default stripped pinion gear
I need some help with this problem I stripped 2 of the 14t bevel rear gears and I don't know what to do these are the metal ones part 365134
My xray is the 2015
handyman77 is offline   Reply With Quote
Old 03-05-2015, 11:56 PM   #7451
likea45's Avatar
It's a tight fit but I think it's the best looking body for the car. I have the 2015 body on order just to see what it's like but probably won't switch because nothing looks like the DMX.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 03-06-2015, 05:02 AM   #7452
BentKa's Avatar
Default New 3mm alu. chassis and 2mm front top deck
The new 3mm alu. chassis and 2mm top deck that we have been using for some time on medium to high grip surfaces have now been released by Xray:
XRAY Graphite Front Upper Deck 2.0mm #361173
CNC-machined front upper deck shim made from premium 2mm graphite for maximum strength and long life. Recommended especially for use with the 3mm alu chassis when the standard long front top deck is not used.
• Premium graphite material
• 2mm thick
• Adjusts chassis flex
• Maximum strength
• Long life
• Combine with alu chassis
New XB4 Alu Chassis - Swiss 7075 T6 (3mm)
CNC-machined chassis made from high-quality 3mm Swiss 7075 T6 aluminum, strategically machined in low-stress areas to make it as light as possible without affecting strength or rigidity.
Designed and recommended for use at high-traction tracks without graphite front and rear top deck. The 3mm chassis increases corner speed and overall stability - a “must have” option part for serious racers. Optional graphite body mounts are recommended for easy body mounting.
Note:
Swiss 7075 T6 is an extremely rigid aluminum material. In some rare cases some small cracks may occur (for example, around openings or on edges where tension in the material is highest). Those small cracks are a natural effect and have no negative impact on the performance, reliability, or lifespan of the product, and as such are not considered to be a defect.
• Premium Swiss 7075 T6
• 3mm thick
• Super-strong
• Extra-stiff
• Increases cornering speed
• Increases stability
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 03-06-2015, 06:47 AM   #7453
Trader Rating: 16 (100%+)
would love to see some new clay setup sheets!
Tekno: NT48, ET48, EB48, SCT410
Xray: 2 XB9E, XB9, XT9 E, XB8 E 2014, 808E, 2 T4, XB4, XB4 2015
Losi: SCTE 2.0, 8T 3.0E, 2 8T 2.0E, Mini8T, 2 Mini8,
Mullet1 is offline   Reply With Quote
Old 03-06-2015, 09:39 AM   #7454
Warranty RR hinge pin holders are starting to ship. One of mine is on the way from the Netherlands.
Old 03-06-2015, 10:42 AM   #7455
handyman77's Avatar
My xray is the 2015
ANYBODY??
MBX7TR....O.S. SPEC 3 .NOVAROSSI PALOMA 7
MUGEN SCTE CONV. TEKIN 4600 HD HOBBYWING XR8
MBX7R..NOVAROSSI DRAKE MOTOR
HOT BODIES D413 LRP VECTOR 6.5T
LRHhobbies.com in placentia, CA.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
