Like Tree44Likes
Old 03-04-2015, 04:15 PM   #7426
suzukipro's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Norse View Post
That's good to know as I just received my bugleboy front bumper. Are the 2 screws holding it secure?
I initially bought three of them and still have two spares still in my parts box, it doesn't look like I'll ever need them at this point. The bumper is actually is attatched with (4) screws and the bumper has performed flawlessly and never have been an issue with a few race seasons and more crashes than I care to count on it.
Norse, if you ever make it to Innovative Hobbies I'll sell you one of the spares I have.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 03-04-2015, 04:37 PM   #7427
hows this car do on indoor loose clay med bite? just ordered one selling my d413
DIRT DIGGER is offline   Reply With Quote
Old 03-04-2015, 05:20 PM   #7428
Trader Rating: 30 (100%+)
Suzuki Pro,
Sounds like a deal brother. I plan on getting over to Innovation this month. I will let you know a week in advance thus maybe we run with you at the track.
Bugle Boy says their front XB4 bumper was for xb4 years pre 15. Thus the 15 models it has worked very well with the use of 2 screws. I haven't unpackaged it yet to see if it truly lines up to just 2 chassis holes or 4.
Thanks my friend
Norse is offline   Reply With Quote
Old 03-04-2015, 05:23 PM   #7429
Originally Posted by suby723 View Post
Paint scheme body in progress..
Like the white paint!! Probably painting mine white as well
Old 03-04-2015, 05:24 PM   #7430
Originally Posted by Canadianrage View Post
I like pictures...
Looks great!
Old 03-04-2015, 05:27 PM   #7431
Originally Posted by MaricopaAgent View Post
Mine
Looks great! Tires are cool as well.
Old 03-04-2015, 07:14 PM   #7432
suby723's Avatar
Trader Rating: 21 (100%+)
Just a little testing tip that I have recently found trying out shock orings for the xb4.. After not being very pleased with the associated xrings I have settled on traxxas orings. They work a lot better over the xring IMO. Only use the blue oring and you will need two packages and use 1mm xray spacer(same with xring)
http://www.amain.com/traxxas-shock-rebuild-kit/p45156
suby723 is offline   Reply With Quote
Old 03-04-2015, 07:33 PM   #7433
Originally Posted by rcgod View Post
Check your front cvd's for binding. I've seen this happen when the small pin is accidentally put through the center of the barrel and not the middle where the small hole is.
Checked them, and they are good. They feel smooth at all angles if I leave the axle in the bearings and spin by hand. I took them apart and re-greased just in case and double checked I had them right.
also make sure the steering rack is not catching the bulkhead screws.. They are pretty close, I have had them rub..
Yea, it is close. Not causing my issue though.
It gets a weird shake/drive-train noise when you combine certain rpm's and steering angles while holding the car off the ground. The diffs feel like butter and there is no notches to them if I rotate the drivetrain. It does fine with no drama if no steering is involved.
Hacksback is offline   Reply With Quote
Old 03-04-2015, 08:20 PM   #7434
Might have to buy one of those
Rico54 is offline   Reply With Quote
Old 03-04-2015, 10:48 PM   #7435
likea45's Avatar
Originally Posted by Motts97 View Post
They have a website T-bone-racing.net they make pretty good stuff. They make great skid plates for the rear end too.
I've been running these bumpers since my b44.2. Fantastic bumpers and having that small bumper on the xb4 this has saved the front of my car a few times as well. Also lifetime warranty. You break it, no questions asked they send you a new one. They also make a great rear skid pad as well.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 03-05-2015, 03:16 AM   #7436
just ordered one .... nice part for front
stdu007 is offline   Reply With Quote
Old 03-05-2015, 06:15 AM   #7437
Canadianrage's Avatar
No, but I'm currently running this one http://www.bugleboyracing.com/index.php?productid=24 and it has done a great job.
Does not fit on the '15 car, thing is indestructable as far as I can tell but sticks out pretty far, same as the T-Bone bumper which can be a problem if you land a jump nose down...
- Xray XB4 2015 VTXR10BE / Trinity D4 6.5 - Associated T5M R10 / Tekin Pro2 5800 -
Canadianrage is offline   Reply With Quote
Old 03-05-2015, 06:47 AM   #7438
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Not sure why it would not fit a 15.. Everything it bolt's to is exactly the same, minus the factory front bumper. Change that to a 14 or remove it and you would be good to go.
MaricopaAgent is offline   Reply With Quote
Old 03-05-2015, 07:31 AM   #7439
'15 car does not have the same holes in the chassis at the '14, you could still mount it using just 2 screws and dremeling down the plastic I suppose...
Old 03-05-2015, 07:54 AM   #7440
rcgod's Avatar
What holes does the 14 have that the 15 doesnt?
Dialed RC Hobbies
rcgod is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
