Like Tree44Likes
Old 03-04-2015, 01:15 AM   #7411
Originally Posted by walste View Post
Sorry for my poor/bad english.
I have just build my XB4 2015, and have trouble that the rear right driveshaft ist hitting the outdrive when the suspension is fylly compressed.
i built it after this setup
http://www.petitrc.com/setup/xray/se...petSetupV2.pdf
I have 3,5mm uptravel limiter on the shock as well.
The rear right outdrive seems to be longer out of the diff bulkhead than the left one (see picture). it looks the same in the front of my car, but the driveshaft in front is no problem.
Is not enyone else have this problem???
walste is offline   Reply With Quote
Old 03-04-2015, 04:12 AM   #7412
Mine do that but I haven't had any issues with it causing problems. Mine just barely contact. You can add more limiters so it gets better.
3DRCRACER is offline   Reply With Quote
Old 03-04-2015, 05:30 AM   #7413
Trader Rating: 15 (100%+)
Another guy was having this same issue. He posted it back 20 pages ago, please go back and read his threads. Maybe send him a PM.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 03-04-2015, 06:11 AM   #7414
BentKa's Avatar
We're running the hinge pin inserts in the inner and lowest positions and use 4mm + O-ring for up travel limiters.
Have been doing so for months now with no issues
Malin's setup here:
http://forum.teamxray.com/xform/inde...setup=xb4_2015
As the info below says the outdrives have been updated and have had material added which in turn have shortened the openings.
So any time you change shock positions and hinge pin inserts you want to check for down travel and up travel running smoothly without binding.
If you have binding add the appropriate number of limiters.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 03-04-2015, 06:45 AM   #7415
skeasor's Avatar
I saw this on ebay Anyone running one? May come in handy to protect the front end
http://www.ebay.com/itm/68009-TBR-Pr...item51cd0503f5
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 03-04-2015, 06:59 AM   #7416
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Hacksback View Post
Anyone's car do this too?
Car runs fine if wheels are straight, but if I turn the front wheels and give it throttle at certain rpms and steering angles I am getting some weird feedback.
also make sure the steering rack is not catching the bulkhead screws.. They are pretty close, I have had them rub..
MaricopaAgent is offline   Reply With Quote
Old 03-04-2015, 07:11 AM   #7417
TPR 1's Avatar
Trader Rating: 26 (100%+)
has anyone tried 6 hole 1.1 pistons front and rear
over the stock piston set up?
I'm going to be running on a low traction dirt track with
small jumps , was thinking it might give me more overall
traction ,seems like the 2 hole 1.4 and 3 hole 1.3 pistons
have a lot of pack.
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Old 03-04-2015, 11:35 AM   #7418
suzukipro's Avatar
Trader Rating: 22 (100%+)
No, but I'm currently running this one http://www.bugleboyracing.com/index.php?productid=24 and it has done a great job.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 03-04-2015, 12:25 PM   #7419
jpdgas's Avatar
I run one on my DEX410 and I really like it. I run it along with the stock bumper just because I can. It definitely helps if your car has an unnatural attraction to obstacles.
-XRay XB4
-Team Losi SCTE 2.0
jpdgas is offline   Reply With Quote
Old 03-04-2015, 01:16 PM   #7420
skeasor's Avatar
I like that design a little better. It's not as bulky.
Old 03-04-2015, 01:57 PM   #7421
They have a website T-bone-racing.net they make pretty good stuff. They make great skid plates for the rear end too.
Motts97 is offline   Reply With Quote
Old 03-04-2015, 01:58 PM   #7422
Plus they have multiple sizes on the website for badger and race specific almost any vehicle
Old 03-04-2015, 03:43 PM   #7423
Trader Rating: 30 (100%+)
That's good to know as I just received my bugleboy front bumper. Are the 2 screws holding it secure?
Norse is offline   Reply With Quote
Old 03-04-2015, 03:46 PM   #7424
Looks great!
Old 03-04-2015, 04:06 PM   #7425
have a lot of pack.
I've been running the Avids with great results. 2 + 2 1.5 front and 1.6 rear. The bottom of the link shows tips on how to use them.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
