Like Tree38Likes
Old 02-27-2015, 11:44 AM   #7306
Trader Rating: 15 (100%+)
Originally Posted by littleZEN View Post
So after only 3 days of running my car I've noticed that the driveshaft pins show considerable wear. I've read that they do wear fast but I didn't expect it to be this fast. How often are you guys replacing the pins? Or rather, at what point should I replace the pins? I understand its cheaper to replace pins than outdrives but only after 3 days of running seems excessive to me. Are there any ways to prolong the life of the pins?
Whoa, that's not right. My '13 I have ran 25-30 races, and I only replaced my pins this winter. The centre cvd's were the worst, but still usable. 3 race days though?
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 02-27-2015, 11:48 AM   #7307
jmackani's Avatar
Trader Rating: 14 (100%+)
Did you put any grease on them?
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 02-27-2015, 11:58 AM   #7308
Trader Rating: 22 (100%+)
I'll try to take a picture and post.
I don't grease the pins and outdrives. Only the cvd portion. Instructions don't state to grease them either. Am I suppose to? I'd imagine it would just fling off and/or attract dirt.
littleZEN is offline   Reply With Quote
Old 02-27-2015, 12:08 PM   #7309
skeasor's Avatar
Originally Posted by big chris View Post
The zero offset 12mm hexes are not for B5/KYO offset rims, the axle barely has enough threads. They will work with 22 style perfectly though. The +1.5 is real close to stock and the +2.25 is a touch wider with B5/KYO style rims.
GSHobby has 1 or 2 center diffs in stock for the guys looking. Call 479-648-1994 I don't think they are on their website.
Exactly what I was looking for. Thanks!
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 02-27-2015, 12:28 PM   #7310
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Sounds like you need to turn your current limiter and brakes down to me
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 02-27-2015, 04:05 PM   #7311
rcgod's Avatar
Trader Rating: 27 (100%+)
The instructions say to grease the pins and outdrives. I use a lube called white lightning made for bicycle chains. It's actually not dry but waxy and doesn't attract dirt or fling off.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-27-2015, 06:04 PM   #7312
jmackani's Avatar
+1 if he does use grease it does not take much.
Old 02-27-2015, 07:13 PM   #7313
skeasor's Avatar
Thanks! I must've missed this step in my build too.
Old 02-28-2015, 12:14 AM   #7314
MaricopaAgent's Avatar
NO.. The outdrives and pins suck.. turn down your brakes is a lame response for poor outdrives.
Look at a D413 to compare.. They show NO signs of use, after 5x the drive time. ..
MaricopaAgent is offline   Reply With Quote
Old 02-28-2015, 01:02 AM   #7315
Little grease always helps. I've had mine since launch(UK) and I'm still on all original drivetrain. The pins are marked on mine but perfectly useable. I will change them soon. It's been used 1/2 times a week and it's been driven hard. I don't hit things too much but it's really been hammered. Look after things and service the car regularly and its gonna last for ages.
sime46 is offline   Reply With Quote
Old 02-28-2015, 07:37 AM   #7316
All I have to say it look at a HB outdrives.. They Win..
We have a better car overall. They have much better outdrives. NO COMPARISON.
Old 02-28-2015, 07:38 AM   #7317
Anyone call rcamerica to see when they will shipping the free replacement?
Rico54 is offline   Reply With Quote
Old 02-28-2015, 08:29 AM   #7318
crazy nick's Avatar
Trader Rating: 20 (100%+)
So as for switching hexes from 14mm to 12mm, I was going to order from amain the xrays , however they are on backorder. So I went to my local hobbyshop and bought a ton of different size plastic ones( not running just for fittment). So I came up with proline pro2 rear aluminum clamping hexes for the rear and scte hexes for the front. This give me stock xray width with 12mm associated wheels.
http://www.prolineracing.com/perform...-clamping-hex/
http://www.losi.com/Products/Feature...rodID=LOSB3493
Rcjuice.com
Hobbystar
"I use the tears of the people I hack to sauce my tires!"
- Chris Kline
crazy nick is offline   Reply With Quote
Old 02-28-2015, 09:18 AM   #7319
rcgod's Avatar
Nice find!
Dialed RC Hobbies
Old 02-28-2015, 09:42 AM   #7320
BDRMBULLY's Avatar
I used these on my scte . Same width and much cheaper...
http://m.ebay.ca/itm/351326422748?nav=SEARC
Hand D Flooring
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
