Like Tree52Likes
Old 02-24-2015, 02:12 PM   #7276
skeasor's Avatar
Originally Posted by ezlight View Post
Is there setup sheets anyplace to show a baseline setup? I just got a used XB4 2014, and want to try it out this weekend. Any upgrades I should make sure this thing has? Anything to look out for?
Yes, I know, I have a lot of reading to do. I'll catch up sooner or later.
I believe the carpet basic and clay basic are the baseline setups. I'm running the basic clay setup until I figure out what needs tweaking.
http://www.petitrc.com/setup/xray/Se...tsXrayXB4.html
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 02-24-2015, 04:16 PM   #7277
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
What thickness xray hex to use for rear losi 22 rims?
Thank in advance
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 02-24-2015, 05:12 PM   #7278
rcgod's Avatar
Trader Rating: 27 (100%+)
Thank in advance
22 rear are same offset as b5 so you want 7mm hex width.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-24-2015, 05:24 PM   #7279
BDRMBULLY's Avatar
So on xray tips it says we can use scte hexes to use ae wheels i have a scte im not using so i can use them hexes then
Hand D Flooring
Old 02-24-2015, 05:44 PM   #7280
BDRMBULLY's Avatar
So on xray tips on petit rc it says we can use scte hexes to use ae wheels i have a scte im not using so i can use them hexes then
http://www.petitrc.com/setup/xray/se...exAlternative/
Hand D Flooring
Old 02-24-2015, 05:54 PM   #7281
rcgod's Avatar
Scte hex is the right width for the front but the rear will be narrow by 2mm per side. I think the scte hexes are 5mm
Dialed RC Hobbies
Old 02-24-2015, 06:20 PM   #7282
BDRMBULLY's Avatar
So confusing lol if you look on the link they are mounted on the rear .
Hand D Flooring
Old 02-24-2015, 07:05 PM   #7283
Trader Rating: 22 (100%+)
Just measure your scte hexes. If they are 7mm you can use them in the rear.
littleZEN is offline   Reply With Quote
Old 02-24-2015, 08:01 PM   #7284
rcgod's Avatar
Losi just released optional rear scte hexes that are .5mm wider and they say they're 5.5mm so that's hiw I figured the width of the stock ones. Haven't measured them myself.
Dialed RC Hobbies
Old 02-25-2015, 07:07 PM   #7285
skeasor's Avatar
Does the majority of xb4 drivers change out the hexes? I was planning on just keeping the 14mm hexes on. However, it would be nice to use the same wheels/tires as my Losi 22
Old 02-25-2015, 07:29 PM   #7286
suby723's Avatar
Trader Rating: 21 (100%+)
I have 12mm hexes to use 60mm wheels. I just like knowing I will be able to buy wheels at my local track.
suby723 is offline   Reply With Quote
Old 02-25-2015, 07:30 PM   #7287
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
you can really only reuse the rears. the only reason to use 12mm is if that is what your LHS has. I am looking at maybe getting a 2014 car (with 2015 parts), and if i do, I will probably just run the 14mm wheels. Unless I can get the proper 12mm hexes on the cheap. Also, if you want to use 2.4 wheels, you might need 12mm hexes. not sure anyone makes those in 14mm yet.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 02-25-2015, 07:47 PM   #7288
suby723's Avatar
The 14mm wheels by Xray are great quality and hold up well. I have a lot of 14mm wheels still and it's very easy swapping out hexes if need be. I've been running 60mm dirtwebs with the 2pair of wheels you save a lot of $$
Old 02-25-2015, 08:20 PM   #7289
So is there any advantage to the 2.4 wheels an tires on clay besides them looking good?
Rico54 is offline   Reply With Quote
Old 02-25-2015, 08:39 PM   #7290
Originally Posted by Norse View Post
RC America does have them in stock currently anD Absolute Hobbyz has them as well.
I ordered mine from the XRay shop in Austria which takes about 10 days to arrive to any state side location.
RC America may have had the center gear diff in stock, but email response I received today from them (figured I'd try in the country first before going to XRay shop) confirms they're out right now:
Part number 364901 is currently on backorder with XRAY, but should be available in about three weeks. Once we receive them, any dealers who might have these on backorder will get them shortly after.
Juffo is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
