Like Tree39Likes
Old 02-21-2015, 02:35 PM   #7261
kevinpratt823's Avatar
Originally Posted by evolution03 View Post
All you needed to do was flip the pinion over so that the set screw is toward the outside and not toward the mount
Actually, when I tried this, because of the thickness of the motor mount the set screw was barely biting the very end of the shaft on my Tekin and I wasn't comfortable with it like that.
May you always hold your line, and keep the rubber side down.
My private track- https://www.youtube.com/watch?v=XC3HpcDO4Ig
kevinpratt823 is offline   Reply With Quote
Old 02-21-2015, 03:21 PM   #7262
jmkalt's Avatar
That was my experience as well.
Just tried some team durango pinions and they fit much better. Problem solved.
jmkalt is offline   Reply With Quote
Old 02-21-2015, 04:48 PM   #7263
Will rcamerica send us a email when the replacement is shipped?
Rico54 is offline   Reply With Quote
Old 02-23-2015, 03:22 PM   #7264
advpball's Avatar
Trader Rating: 27 (100%+)
does anyone run 17.5 in there xb4 15 we have small track not much for straights 20 ft maybe ,just looking for gearing with reedy sonic2?
Just trying to get my driving under control ... lol gonna try center gear diff with 17.5
Jeff
xray xb2 de and xsc2,eb410
eb 48.3 for sale artr 500
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 02-23-2015, 06:04 PM   #7265
Thinking real hard about racing dirt. Absolutely love my xray t4 15 for on road. Thinking about staying with xray xb4 . Question is this, current owners would you buy another or maybe something else ? I see comments about what a great car the 413 is,but to fix steering use the xray parts,etc etc...I s the xray adjustable enough to run on loose dusty tracks..or is it a car that is only good on a perfect track ?
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 02-23-2015, 06:11 PM   #7266
suby723's Avatar
Trader Rating: 21 (100%+)
The xb4 15 is an amazing car and great to wrench on. The 413 is a bit sloppy and not very easy to work on. I've ran my xray 15 shorty pack on a variety of track surfaces from low bite loose conditions to high bite clay and with minor setup changes the car works excellent no matter what surface it is on. It should be a no brainer honestly. I would and will be buying another Xray car.
suby723 is offline   Reply With Quote
Old 02-23-2015, 06:49 PM   #7267
Canadianrage's Avatar
Killed it outdoors last summer with my '14. '15 is better
- Xray XB4 2015 VTXR10BE / Trinity D4 6.5 - Associated T5M R10 / Tekin Pro2 5800 -
Canadianrage is offline   Reply With Quote
Old 02-23-2015, 09:55 PM   #7268
From what I have read the xb4 will run on any surface and do it with grace with the right setup. I let someone that use to be a pro run my xb4'15 and he could not believe how awesome it was. It's definitely the right chocie.
Old 02-24-2015, 12:02 PM   #7269
MikeXray's Avatar
Trader Rating: 73 (100%+)
I hope I didn't miss this, as I read through a lot of this thread, is there a chart that shows what hexes to run with what rims? Id like to run the AE style rims, the new 2.4/60mm stuff is coming with larger front hex, so 12mm all around correct? I want to keep the offsets stock.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-24-2015, 12:12 PM   #7270
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Excellent question. I was thinking the same thing. Getting closer to picking up one of these. Hoping to take some laps with one this weekend to see for sure
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-24-2015, 12:15 PM   #7271
rcgod's Avatar
Exotek 12mm hex converion. Use the 7mm wide rear hex for ae offset rims and fronts use kyosho offset rim. Exotek also makes a 9mm wide rear hex not sure what rims those are for maybe kyosho.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-24-2015, 12:18 PM   #7272
rcgod's Avatar
Also Avid makes 12mm hex spacers down to .5mm wide to fine tune the track width for different conditions.
https://www.google.com/url?sa=t&sour...eEEt1-5FcxzuTw
Dialed RC Hobbies
Old 02-24-2015, 12:24 PM   #7273
Is there setup sheets anyplace to show a baseline setup? I just got a used XB4 2014, and want to try it out this weekend. Any upgrades I should make sure this thing has? Anything to look out for?
Yes, I know, I have a lot of reading to do. I'll catch up sooner or later.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 02-24-2015, 12:31 PM   #7274
rcgod's Avatar
I ran the Tyler Vik setup on petitrc all last year on tracks from indoor clay to high bite sugar and it was dialed. Only changes I made were to ride height and steering dual rate.
Dialed RC Hobbies
Old 02-24-2015, 12:38 PM   #7275
MikeXray's Avatar
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
