Like Tree45Likes
Old 02-20-2015, 11:24 PM   #7246
jmkalt's Avatar
M
Originally Posted by rcgod View Post
Looks like you need a different pinion gear with the set screw closer to the teeth. Or maybe a ball end hex driver will let you slide it in further and tighten.
I was actually thinking about dremeling out a notch in the cam,
but figured I'd wait for some responses here first.
Thought I may have assembled something wrong but after checking it over carefully, I don't think I have. Same issue with center diff and slipper clutch.
jmkalt is offline   Reply With Quote
Old 02-20-2015, 11:36 PM   #7247
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Originally Posted by jmkalt View Post
M
I notched my cam on the top.. But now I seem to be having spur gear issues.
Also, it looks like you Spur is backwards. Offset is not the same..
MaricopaAgent is offline   Reply With Quote
Old 02-21-2015, 01:26 AM   #7248
GregerL's Avatar
Okay guys, maybe I'm just up way too late building but I have run into a strange problem.
In order to line my pinion gear up to the spur, I need to move it a little bit down the shaft, closer to the motor.
Problem is, the motor cam (mount) prevents access to the pinion set screw. The pinion is also too large to allow the cam to slip over the pinion gear, so it needs to be in place first.
I'm sure that there's something simple I'm not seeing at this late hour, so I'm asking for some fresh eyes and ideas.
Here's a picture:
When you are running the center diff the spur does get a bit closer to the motor bulkhead. Had the same issue on ours, but was able to flip the pinion and mount it the other way around on the motor shaft.
Just a tip to try if you already haven't
Alexander Landén RC on facebook:
https://www.facebook.com/alexanderlandenRC
GregerL is offline   Reply With Quote
Old 02-21-2015, 01:26 AM   #7249
I dremelled a small groove in the cam. Also I shimmed the diff forward a little and when the slipper is fitted, I shim that back a little. This works perfectly for me. Just take care to note the orientation of the spur on the diff. The offset isn't equal.
sime46 is offline   Reply With Quote
Old 02-21-2015, 04:16 AM   #7250
kevinpratt823's Avatar
Here's a picture:
Like was said, I ran into this and found that the spur was on backwards. When I flipped it so that the tooth # marking was towards the front of the car it corrected it.
May you always hold your line, and keep the rubber side down.
My private track- https://www.youtube.com/watch?v=XC3HpcDO4Ig
kevinpratt823 is offline   Reply With Quote
Old 02-21-2015, 04:53 AM   #7251
jmkalt's Avatar
I did try flipping the spur around and the offset got worse, so I guess I already had it installed correctly on the center diff.
I guess I'll just try a different brand pinion and see if it's designed differently.
Old 02-21-2015, 05:50 AM   #7252
Ahh, bummer. I use Robinson Absolute pinions, it's tight but I can still get the allen in when they are meshed.
Old 02-21-2015, 08:49 AM   #7253
rcgod's Avatar
What brand pinion is that? I use Robinson no problems. Just looked online and most brands have the set screw closer to the gears than that one does.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-21-2015, 11:28 AM   #7254
All you needed to do was flip the pinion over so that the set screw is toward the outside and not toward the mount
evolution03 is offline   Reply With Quote
Old 02-21-2015, 11:30 AM   #7255
Have any of you guys received a center gear diff from stormer ? i preordered one in like december
Old 02-21-2015, 11:41 AM   #7256
Trader Rating: 15 (100%+)
There are none in stock anywhere....A Main included, but some were saying calling RC America directly as they have them? Not sure why they are not getting to shops if the US Distributor has them in stock....
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is online now   Reply With Quote
Old 02-21-2015, 12:06 PM   #7257
suby723's Avatar
Trader Rating: 21 (100%+)
Calling rc America is the way to go. I've had my gear diff for months now. Fast shipping and priced well.
suby723 is offline   Reply With Quote
Old 02-21-2015, 12:45 PM   #7258
Trader Rating: 30 (100%+)
RC America does have them in stock currently anD Absolute Hobbyz has them as well.
I ordered mine from the XRay shop in Austria which takes about 10 days to arrive to any state side location.
Norse is offline   Reply With Quote
Old 02-21-2015, 12:58 PM   #7259
Absolute Hobbyz received xb4 center gear diffs this past Wednesday the 18th. I think the are $61.
Old 02-21-2015, 01:45 PM   #7260
jmkalt's Avatar
I think its a muchmore pinion.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
A2Racing
