Like Tree37Likes
Old 02-19-2015, 03:04 PM   #7231
jmkalt's Avatar
Originally Posted by kevinpratt823 View Post
If you are in the USA then I highly doubt you got the updated part. I haven't heard of anybody getting it yet, and your kit was probably packaged at least 2 weeks ago before it found it's way to an LHS. Just measure each insert hole from the screw hole, or post a pic as most of us can see it by eye. Or assemble it and you will probably notice it.
Okay, so using calipers, I have verified that mine is indeed slightly out of whack.
I can't figure out which side, though, it not correct.
To get equal toe on both sides, which side gets the 0, which side gets the .5, and which way does the .5 go?
jmkalt is offline   Reply With Quote
Old 02-19-2015, 03:13 PM   #7232
Trader Rating: 16 (100%+)
Rc America said they are getting them at the end of Feb
Tekno: NT48, ET48, EB48, SCT410
Xray: 2 XB9E, XB9, XT9 E, XB8 E 2014, 808E, 2 T4, XB4, XB4 2015
Losi: SCTE 2.0, 8T 3.0E, 2 8T 2.0E, Mini8T, 2 Mini8,
Mullet1 is offline   Reply With Quote
Old 02-19-2015, 03:24 PM   #7233
skeasor's Avatar
I noticed on mine right away as soon as I took a picture (in's on the previous page) Hopefully the replacement part will be released soon. I'm racing my this weekend with the messed up rear toe though.
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 02-19-2015, 03:29 PM   #7234
Trader Rating: 22 (100%+)
Originally Posted by rcgod View Post
Ok guys I finally had time to take some measurements on the CMM with different combinations of inserts. I also measured the distance to the centerline of the mount insert pockets. It was worse than I originally thought. All measurements are to the centerline of the chassis. Here's what I found:
Inner hinge pin angles with 0 inserts:
Left 2.73 degrees
Right 3.60 degrees
Inner hinge pin angles with 0 insert right side and .5 insert out on left side:
Left 3.22 degrees
Right 3.60 degrees
Inner hinge pin angles 0 insert left side .5 in on right side:
Left 2.73 degrees
Right 3.08 degrees
Inner hinge pin angles 0 insert right side 1 insert out left side:
Left 3.69
Right 3.60
Centerline of chassis to centerline of insert mount pockets no inserts:
Left .9004"
Right .9280"
Offset of pockets to centerline of chassis:
.0138" towards right side.
I measured my mount at .010" offset with calipers, but looks like the holes in the case are also offset about .004" No bueno.
Again, thanks to rcgod for this. So for 3degrees of toe you'd want to run the left 2.73 or 3.22 and right 3.08
littleZEN is offline   Reply With Quote
Old 02-19-2015, 05:01 PM   #7235
jmkalt's Avatar
Thank you, very helpful.
Old 02-19-2015, 05:32 PM   #7236
Trader Rating: 30 (100%+)
Originally Posted by HeavyD99 View Post
Not 100% positive as there was no photo, but I think the new X brace is part number 361173. The description reads, "graphite front upper deck 2mm" and it is not one of the other '15 decks in the kit.
Heavy,
I am pretty positive your thinking on the X brace regarding part# 361173 being 2mm graphite front upper deck is correct. Just ordered one as well as the 3mm chassis from XRAY shop Austria. I Should soon receive a response to my email asking if indeed that part is the X brace.
Usually new parts the add to their site they either have or will have within 5 business days.
Norse is offline   Reply With Quote
Old 02-19-2015, 09:18 PM   #7237
Trader Rating: 14 (100%+)
I'm running on a carpet track and using proline and Schumacher mini-pin tires.
In general, is it better to use closed cell or open cell inserts for the tires on carpet?
Slippery Dan is offline   Reply With Quote
Old 02-20-2015, 08:58 AM   #7238
skeasor's Avatar
I just got an email from RCAmerica confirming that I'm on their list for the replacement suspension holder. w00t w00t
Old 02-20-2015, 01:01 PM   #7239
Trader Rating: 32 (100%+)
Originally Posted by BDRMBULLY View Post
Xray@rcamerica.com give them your address . Your serial number and where you bought it.
Where can find serial number?
raved007 is offline   Reply With Quote
Old 02-20-2015, 01:05 PM   #7240
suby723's Avatar
Trader Rating: 21 (100%+)
On your box.
suby723 is offline   Reply With Quote
Old 02-20-2015, 01:15 PM   #7241
skeasor's Avatar
Mine was on a fancy piece of paper in the box.
Old 02-20-2015, 01:21 PM   #7242
Originally Posted by suby723 View Post
On your box.
Thanks. Will check the box when I got home.
Old 02-20-2015, 02:39 PM   #7243
kevinpratt823's Avatar
The closest to equal to requires a full 1 deg increase on the left side vs. the right with the inserts. I found 3.5 deg toe to feel better than 3 deg on a clay track, I went with both 1 deg in lower inner corners in RF, and 1 deg lower inner corner on back right, with 1 deg down in the middle on back left.
May you always hold your line, and keep the rubber side down.
My private track- https://www.youtube.com/watch?v=XC3HpcDO4Ig
kevinpratt823 is offline   Reply With Quote
Old 02-20-2015, 10:52 PM   #7244
jmkalt's Avatar
Default Pinion Fitment Problem
Okay guys, maybe I'm just up way too late building but I have run into a strange problem.
In order to line my pinion gear up to the spur, I need to move it a little bit down the shaft, closer to the motor.
Problem is, the motor cam (mount) prevents access to the pinion set screw. The pinion is also too large to allow the cam to slip over the pinion gear, so it needs to be in place first.
I'm sure that there's something simple I'm not seeing at this late hour, so I'm asking for some fresh eyes and ideas.
Here's a picture:
Old 02-20-2015, 11:06 PM   #7245
rcgod's Avatar
Trader Rating: 27 (100%+)
Here's a picture:
Looks like you need a different pinion gear with the set screw closer to the teeth. Or maybe a ball end hex driver will let you slide it in further and tighten.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
