Like Tree39Likes
Old 02-15-2015, 05:08 PM   #7171
Boz
Trader Rating: 23 (100%+)
Is it recommended to use the steel 14t gear when using the steel or aluminum 35t diff gear?
Or are you able to use the composite 14t gear with them?
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 02-15-2015, 09:55 PM   #7172
TPR 1's Avatar
Trader Rating: 26 (100%+)
Anyone got any video footage of their 15 cutting laps on a
clay track?
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Old 02-15-2015, 11:05 PM   #7173
I've tried the composite 14t gear with the steel 35t gear, doesn't work, the steel gear is smaller then the std composite ones, so the 14t gear doesn't mesh.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 02-15-2015, 11:06 PM   #7174
suby723's Avatar
Trader Rating: 21 (100%+)
clay track?
https://www.youtube.com/watch?v=rDLi...ature=youtu.be
That's my car(white) on high bite clay. The car works extremely well on clay tracks with a shorty pack.
suby723 is offline   Reply With Quote
Old 02-15-2015, 11:15 PM   #7175
TPR 1's Avatar
Wicked ,i enjoyed that you should of heard me yelling
once you took the lead!
nice driving
-Adelaide RC -
-Game On
Old 02-15-2015, 11:23 PM   #7176
suby723's Avatar
nice driving
Haha thank you! That race had a lot of luck go my way but I was very happy getting the win. The car was so consistent all day it's such an easy car to drive hard. Shorty pack with center gear diff was the ticket.
Old 02-16-2015, 12:18 AM   #7177
werner sline's Avatar
great race!
werner sline is offline   Reply With Quote
Old 02-16-2015, 12:56 AM   #7178
BentKa's Avatar
The steel 14T (#365134) is recommended used together with either the steel (#364955) or the aluminum (#364945) 35T bevel gear.
We also make sure to pair up a steel 14T gear to whatever steel or aluminum 35T gear we use as they wear differently when used in combination with either steel or aluminum 35T gears.
For the composite 35T gear we only use the composite 14T pinion gear.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 02-16-2015, 01:15 AM   #7179
BentKa's Avatar
Originally Posted by blwaz23 View Post
What kind of gears do you run on carpet? Steel or Composite?
Also I run on low-medium grip dirt and we have a bumpy sweeper and all through the sweeper the rear end is all over the place because it bounces and also at different parts of the track. I've already tried smaller hole pistons in the shocks in the rear to try to give the rear more pack and it's still not getting the job done. Any suggestions?
Depends on the track layout and grip.
We usually start with steel 14T pinion, aluminum 35T bevel gear, alu. hard coated pins and steel bevel + satellite gears.
If we want a more agile handling car we usually throw in the composite 14T pinion, composite 35T, alu. hard coated pins and graphite bevel + satellite gears
Regarding your damper setup it might sound like you either are way too soft so that it bottoms out or you are way over damped and it packs up and starts bouncing instead.
What are you running for pistons, oils and springs ?
Originally Posted by UKracer1 View Post
Thanks Bent for taking the time for such a thorough reply, so if I understand correctly, if you were building the ultimate diff for really low grip conditions you would build it with heavy internal gears (steel bevel and satellite with alu pins) and then light external 35t gear (aluminium or possibly graphite if durability wasn't a concern?)
When it comes to the 14T bevel gear, purely from a grip point of view, would you choose to use the steel gear (2015) or the composite gear (2013 & 2014) again if durability wasn't a concern.
Our starting point for a really blown out low grip track is steel 14T pinion, steel 35T bevel gear, alu. hard coated pins and steel bevel + satellite gears.
Steel 14T gear is recommended used together with either the steel or the aluminum 35T bevel gear, not with the composite one.
We also use the steel 14T gear in pairs with the steel or aluminum 35T gears to ensure a perfect mesh between them as they have different wear characteristics
Bent
Old 02-16-2015, 06:52 AM   #7180
Default Malin's setups
Hey, im interested in Malin's 4WD setup for this track:
https://www.youtube.com/watch?v=9ZqqiMmPCvo
Didnt find any on teamxray.com (except XB42WD)
How center differential works on carpet compared to clutch.
What center diff oil you suggest for capter?
farm is offline   Reply With Quote
Old 02-16-2015, 10:49 AM   #7181
blwaz23's Avatar
I'm running stock pistons, oils, and springs.
blwaz23 is offline   Reply With Quote
Old 02-16-2015, 12:05 PM   #7182
Trader Rating: 30 (100%+)
Bent
Bent,
Thank you for all your help. Much appreciated!
Norse is offline   Reply With Quote
Old 02-16-2015, 12:14 PM   #7183
Sweet Race! and sweet driving my friend. Thanks for posting as there is not a lot vid footage of the XB4 running on clay compound tracks.
Thanks again as that was fun to watch.
Best,
Old 02-16-2015, 01:10 PM   #7184
suby723's Avatar
Best,
Thank you! here is the setup I was using at that race.
Old 02-16-2015, 01:53 PM   #7185
jmcelroy42's Avatar
Default XB4 VID
Best,
https://www.youtube.com/watch?v=UyBAmea6jRU
Here is another, Mine is the Blue/Pink/White with Pink wheels
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is online now   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
theclutch
