Like Tree36Likes
Old 02-08-2015, 05:04 PM   #7051
Trader Rating: 30 (100%+)
You can buy the new 3mm chassis from the X-ray shop iin Austria. Great store with great prices and service. Mr Binder whom I believe owns the store is a top notch person. If you sign in to their site you will see the prices per buyers both inside and outside Europe. No VAT for buyers in the U.S. thus the 15 xb4 is 375.00. There shipping prices are very reasonable as well.
Norse is offline   Reply With Quote
Old 02-08-2015, 07:38 PM   #7052
Trader Rating: 15 (100%+)
New 3mm chassis, p/n 361103.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 02-08-2015, 08:06 PM   #7053
Yeah part # 361103 new 3mm chassis. I believe it's priced at $87 give or take a couple bucks. XRAY shop in Austria. There shipping prices to the states are really reasonable and are based on weight.
I am not sure if shipping to Canada is more expensive. I ordered a center gear diff and a good amount of other parts with shipping only being $13.
Old 02-09-2015, 02:48 AM   #7054
kevinpratt823's Avatar
Originally Posted by rcgod View Post
Are you guys that are having bearing problems using the kit bearings? There was some issues with the 2014 bearings when I built my old car so I replaced them with avid and they held up great. Wondering if I should do the same on the 2015.
I had heard about the bearings on the '14 not lasting long, so I built this car with a set of Acer ceramics right off the bat. I run ceramics in all my cars except spots that have a significant thrust load, mainly just a shimmed rear diff in 1/8 and 4wd SC. For me the value is in having one less item to maintain, they last forever without getting sloppy.
I have had pretty good experience with Protek bearings also, ceramic and regular.
May you always hold your line, and keep the rubber side down.
My private track- https://www.youtube.com/watch?v=XC3HpcDO4Ig
kevinpratt823 is offline   Reply With Quote
Old 02-09-2015, 03:28 AM   #7055
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by skeasor View Post
So, I'll be running the xb4 at the track for the first time this week. What are some parts I should stock up on? A-Arms, C Hubs, Steering blocks, shock towers? Any suggestions would be appreciated.
Thanks!
The only thing I broke on my 14 car besides diff gears were arms, mostly front. I would get a spur gear, front and rear arms, hinge pins, and inserts. And a front diff case too. I've seen those break on a hard hit on the 14 car. I know the 15 has different ones but it's better to have it just in case.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-09-2015, 03:49 AM   #7056
Bentka, could you tell me what width 12mm hex's you are running with which brand of wheel? Thanks
goldy is offline   Reply With Quote
Old 02-09-2015, 04:23 AM   #7057
skeasor's Avatar
Thanks!
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 02-09-2015, 04:46 AM   #7058
BentKa's Avatar
So far we have only ran the 12mm hexes with the Schumacher Mini Pin pre-mounts on Schumacher wheels (front: U6791 / rear:U6792).
For these we use the 2 stripe / +1.5mm (#365356) for the front and the 3 stripe / +2.25mm (#365357) for the rear.
For everything else we are using the stock Xray wheels.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 02-09-2015, 04:54 AM   #7059
skeasor's Avatar
Anyone using these with Kyosho wheels? http://www.amain.com/jconcepts-xray-...ex-set/p357993
I wouldn't mind running the standard 14mm hexes but seems like the wheel are back ordered. Would the Team Durango 4wd wheels mount up OK if I decide to stay with the 14mm hex?
Old 02-09-2015, 05:55 AM   #7060
You need to open up the hole a little on the the Durango wheels to go over the axle, but other then that, they fit fine & come in yellow.
DE Racing do 14mm wheels for the XB4/Durango as well.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 02-09-2015, 06:17 AM   #7061
It's certainly handy to have 12mm hexes to run spec'd tires or handouts or if needed in a pinch, but for the most part I think I'll just run the 14mm. I only race 2-3 tracks and only need 3-5 sets of rubber ready anyhow. I think I'll pick up a 10 pack of wheels next time I order.
Daragh Slowey
Old 02-09-2015, 07:23 AM   #7062
suzukipro's Avatar
Trader Rating: 21 (100%+)
I run the 14mm XB4/DEX 410 - DE speedline wheels no modification required and prefer them over the stock wheels
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 02-09-2015, 07:26 AM   #7063
skeasor's Avatar
Thanks. Are these the wheels? http://www.amain.com/de-racing-speed...91079?v=292391
Old 02-09-2015, 07:40 AM   #7064
suzukipro's Avatar
Yep but make sure to get the 4wd fronts http://www.amain.com/de-racing-speed...91076?v=296193
and these in back
Eric
Old 02-09-2015, 07:40 AM   #7065
suzukipro's Avatar
Eric
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Jake S
