Like Tree36Likes
Old 02-07-2015, 01:37 PM   #7036
Boz
Trader Rating: 23 (100%+)
Originally Posted by BDRMBULLY View Post
Yup . And a rear gear box inner one.
And far as metal ring n pinion it prob wouldnt hurt to open gear boxes and throw grease on tge gears from time to time even if not rebuilding. What kind of lube are you guys using on the metal gears. I just been using black grease but looking for something better.
I have been using this for years on the both the 1/8th and 1/10 buggies.
Eureka Pro
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 02-07-2015, 07:40 PM   #7037
slakr's Avatar
Trader Rating: 28 (100%+)
So... I have seen a few XB4 shots with a carbon brace that ties the front gearbox to the steering posts and eliminating the brace that stretches to the center diff/slipper mount.
Wonder if something like this will come available from XRAY or an aftermarket company?
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 02-07-2015, 09:54 PM   #7038
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Looks to be Xray parts.. But they are also running a thicker (3mm) chassis, from what I read.
MaricopaAgent is online now   Reply With Quote
Old 02-08-2015, 12:53 AM   #7039
They were running quite a few new parts at the EOS last weekend, the short top deck, 3mm chassis and a new steering rack with more holes to name a few.
I've seen they said the chassis and short top deck were aimed more at high grip tracks, so not sure if they're bits you'll need to worry about on dirt.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 02-08-2015, 07:22 AM   #7040
Trader Rating: 15 (100%+)
Well, no top decks, only an 'X' brace and a 3mm chassis is the same as a Yok BMaxIII, which they run everywhere, so I'd say once they get a chance to actually run it on clay we'll know what's what.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 02-08-2015, 08:05 AM   #7041
slakr's Avatar
Originally Posted by HeavyD99 View Post
Well, no top decks, only an 'X' brace and a 3mm chassis is the same as a Yok BMaxIII...
Which is what kind of prompted my question. I have a BMAX-4 III with the shorty configuration.
Old 02-08-2015, 08:11 AM   #7042
skeasor's Avatar
I built my xb4 this weekend...I took my time and started it Friday and just got finished this morning...This has to be the best build out of all of my kits.
I didn't have to trim anything, force screws in or anything...Just the simple things like on my AE and Losi kits that you need to apply a fair amount of pressure when putting the screw in just to get it started as on this kit I didn't have to.
I only ran into one issue and it's only because I overlooked a step in the manual.
I definitely will be buying more xray products in the future.
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 02-08-2015, 10:43 AM   #7043
rcgod's Avatar
Are you guys that are having bearing problems using the kit bearings? There was some issues with the 2014 bearings when I built my old car so I replaced them with avid and they held up great. Wondering if I should do the same on the 2015.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-08-2015, 01:35 PM   #7044
Jones Auto's Avatar
Is Xray going to come out with a updated 2wd model? I have the 2015 4wd and am very pleased with the buggy.
Tekno EB 48.3- Tekno ET48.3 -Xray XB4 Team Associated RC10 T5M
Jones Auto is offline   Reply With Quote
Old 02-08-2015, 02:22 PM   #7045
skeasor's Avatar
It appears so.
http://www.liverc.com/news/special_f...ype_uncovered/
Old 02-08-2015, 02:24 PM   #7046
BentKa's Avatar
All the new parts run at last weekends EOS race will be available shortly.
The new alu. 12* C-hubs and alu. rear uprights have already been released.
So far testing with the 3mm chassis and X-brace have been on medium to high grip tracks, but there's no reason this setup won't work on low grip tracks as well.
The 3mm chassis also allows you to run without the X-brace for added flex
The setup works really well and allowed Malin's best 5 minute final time to be only 0.867 seconds behind Martin Bayer's best A-final time at the EOS
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 02-08-2015, 02:34 PM   #7047
BentKa's Avatar
Yes…..the factory team is testing the new XB2 at races around Europe for the moment
And so far the performance is amazing
Bent
Old 02-08-2015, 03:01 PM   #7048
skeasor's Avatar
So, I'll be running the xb4 at the track for the first time this week. What are some parts I should stock up on? A-Arms, C Hubs, Steering blocks, shock towers? Any suggestions would be appreciated.
Thanks!
Old 02-08-2015, 03:53 PM   #7049
skeasor's Avatar
Bent
Is the new 2 wheel drive designed for high traction surfaces or clay? My xb4 built real well and I wouldn't mind getting a new 2wd buggy to replace my 22 2.0
Old 02-08-2015, 04:47 PM   #7050
Jones Auto's Avatar
Thanks for the update Bentka. Id like to add this to my rc stablenext year. Honestly Im getting tired of racing my 2wd SC Truck.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
