Like Tree36Likes
Old 02-04-2015, 07:17 PM   #7006
TV
The '13 and '14 cars are extremely similar, and I believe all parts will transfer over between the two. The '15 car has the same suspension parts (basically the front and rear ends are the same), but the center/chassis is all different to accommodate the shorty pack, center diff, etc.
XRay | RCAmerica | AKA | FX Engines | MotivRC | P1Hobbies.com | Sidewinder | Airtronics | UpGrade RC
TV is offline   Reply With Quote
Old 02-04-2015, 07:58 PM   #7007
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by prosport View Post
I did not know that, thanks. We have a '13, I'd like to eventually pick up another XB4 so I was wondering what the differences are. I don't want to get a '14 or '15 if alot of parts are different, then my son and I would have to have different spare parts. It's more affordable if all our parts match, most of the cars I see for sale are '14's.
From what I can remember the 14 car had some parts like diff cases beefed up and the arms are narrower where the hinge pin goes thru so you can adjust the wheelbase. But they mostly share the same parts.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-04-2015, 09:14 PM   #7008
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Your prob better off buying a 14 and stormer had them on sale recently. As long as your ok with saddles.
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 02-04-2015, 09:43 PM   #7009
MaricopaAgent's Avatar
Can someone tell me the difference between a 2013 and 2014 XB4. I did some searching and didn't really find the answer. I have a '13, and I know the '15 has a center diff, just wondering about the '13 and '14.
Thanks!
13 to 14/15 arm
https://www.facebook.com/2015XB4/pho...type=1&theater
slipper set ups 13/14 , 15 slipper and gear diff.
carriers
https://www.facebook.com/RcKleinKram...665475/?type=1
MaricopaAgent is offline   Reply With Quote
Old 02-05-2015, 03:06 AM   #7010
ProfessorX's Avatar
Trader Rating: 17 (100%+)
I got my kit from AMAIN who I email ?????? For the replacements ??????
ProfessorX is offline   Reply With Quote
Old 02-05-2015, 04:10 AM   #7011
slakr's Avatar
Trader Rating: 28 (100%+)
I just went through the "contact us" link on the A-Main website...
http://www.amain.com/contactus
Below is the response I received:
"Thank you for your email. As soon as we get the parts in stock we will be contacting everyone who we sold XB4's to offer them replacement parts.
We will contact you as soon as we get them in stock. Thank you!"
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 02-05-2015, 05:29 AM   #7012
skeasor's Avatar
Good to know. Thanks for contacting them and letting us know
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 02-05-2015, 05:43 AM   #7013
Originally Posted by MaricopaAgent View Post
They do update every year. But most of the 14 parts interchange with the 15.. (and some 13 parts)
Arms, bulkheads, steering ,hubs, shocks, outdrives all work.
The chassis, center shafts and top plates are different. Plus a few minor changes like metal gears.
Looks like the '16 could be even better!
Thank you for the explanation!
logiqal is offline   Reply With Quote
Old 02-05-2015, 05:46 AM   #7014
skeasor's Avatar
I should have my '15 built for next week. If you're at the track I'll let you take a look at it so you can compare the parts to your kit.
Old 02-06-2015, 02:47 AM   #7015
Trader Rating: 22 (100%+)
Anyone see this and/or is planning to go to the ocrc one?
http://www.teamxray.com/teamxray/new...%20Tour%202015
littleZEN is offline   Reply With Quote
Old 02-06-2015, 02:55 AM   #7016
Daniel Kies's Avatar
Default XB4 handling problems...
Hey guys,
I am currently driving a XB4 2013.... i race on carpet and when i hit full throttle the car is very difficult to keep in a straight line...its like the rear goes down too much....
Shocks...
Front 37.5
Rear 27.5
What would you guys recomend to fix this issue...
my thought is to put harder shock oils in the rear?
*** KL Racing Team Driver ***
Team Associated * Jconcepts * Ko Propo * Hobbywing
Supercheap hobbies * Ace Hobbies
https://m.facebook.com/KL-Racing-110-Offroad-Electric-Team-573132579553215/
Daniel Kies is offline   Reply With Quote
Old 02-06-2015, 05:16 AM   #7017
BDRMBULLY's Avatar
Put some more internal limiters. In your shock. Def go with some thicker oils. Lay your shocks down.
Hand D Flooring
Old 02-06-2015, 10:04 AM   #7018
Trader Rating: 15 (100%+)
Originally Posted by Daniel Kies View Post
Hey guys,
Shocks...
Front 37.5
Rear 27.5
Check out the set ups on petitrc for good advice as well. But just from your description, ya, your oils are way too light, try the 2 hole 1.4 pistons with AE55 up front and tHree hole 1.3 pistons and AE35 in the rear. Use 4 dot springs (or AE or Kyosho equivalent to 4.2 to 4.8lbs) in the front and 2 or 3 dot springs in the back (3.5lbs). 2mm limiters in the shocks front and rear.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 02-06-2015, 12:57 PM   #7019
kevinpratt823's Avatar
Hey guys,
Shocks...
Front 37.5
Rear 27.5
Could try a little more anti-sqaut angle in the rear also.
May you always hold your line, and keep the rubber side down.
My private track- https://www.youtube.com/watch?v=XC3HpcDO4Ig
kevinpratt823 is offline   Reply With Quote
Old 02-06-2015, 02:28 PM   #7020
Trader Rating: 74 (100%+)
+1. My first change would be more anti-squat. 2nd change would be a stiffer spring, the 3 dot. When you go up in spring you must also go uo in oil weight.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
checo55
